Old Dec 27, 2011, 04:42 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
How did you go about selecting the amount of washout used? The old-fashioned way, or by one of the tailless design packages?
Shedofdread is offline Find More Posts by Shedofdread
Old Dec 27, 2011, 04:46 PM
Knoll53 is online now
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
...opps
Knoll53 is online now Find More Posts by Knoll53
Old Dec 27, 2011, 05:35 PM
Vernon Hunt is offline
Find More Posts by Vernon Hunt
Vernon Hunt's Avatar
Florida
Joined Mar 2005
This wing was designed before I even knew what computers were. I used the black art method .... guess, untill it flew. I did find out quickly that 2 degs. of washout made the tow exciting. But, they flew very fast. I must have made 12 wings that only lasted 1 flight. Once I had success with the tow everything was right with the world. Computers have made things so much easier.
Vern Attached is one of my wing works of art
Vernon Hunt is offline Find More Posts by Vernon Hunt
Old Dec 27, 2011, 05:46 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I was under the impression that such swept flying wings, with tip rudders, where typically designed with no washout. Is this current one at zero degrees washout?
Kent
Old Dec 27, 2011, 06:19 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
Kennt, there's an overview of a number of european tailless rc models:
http://www.aerodesign.de/modelle/3S_NF.htm
It's from Hartmut Siegmanns website http://www.aerodesign.de .
You can find planform sketches of many models there with additional informationon the washout used.
biber
biber is offline Find More Posts by biber
Old Dec 27, 2011, 06:41 PM
less is more
Knoll53's Avatar
Joined Sep 2006
Thanks biber. Those are great links and all new to me. I'm clearly going to have to learn some German.
For example, does this wing have 1.0 degree washout at the end of the inner elevon and 2.5 degree washout at the tip?
Kent
Old Dec 27, 2011, 06:52 PM
biber is offline
biber's Avatar
Joined Dec 2004
Incidences according to the description are:
0.0° at 0/3 (half-)span (center)
-1.0° at 1/3 (half-)span
-2.5° at 2/3 (half-)span
-4.5° at 3/3 (half-)span (tip)
biber
Old Dec 27, 2011, 06:56 PM
less is more
Knoll53's Avatar
Joined Sep 2006
Of course, I see it now
Thank you.
Old Dec 29, 2011, 06:55 AM
Spekd'out is offline
Find More Posts by Spekd'out
Spekd'out's Avatar
Canada
Joined Aug 2004
I built a vacuum bagged wing using a HS 522 airfoil.I studied Hartmut's website ( right click and translate ). Not good as knowing German but a big help. I made it very light with a glass skin and minimal carbon spar. It was electric powered but weighed about 27 oz. It was a great thermal bird! I only used 3 degrees washout and should have used more. It flew with up trim on the elevons. Handling was relatively good but it took full stick in turbulence.I was inspired by an article by Neil Pollock in Feb/ March 2006 Quiet Flyer. I did a little build thread here http://www.rccanada.ca/rccforum/showthread.php?t=82290
Spekd'out is offline Find More Posts by Spekd'out
Old Dec 29, 2011, 09:57 AM
less is more
Knoll53's Avatar
Joined Sep 2006
Originally Posted by Vernon Hunt View Post
. It has progressive twist, ending at 4.5 degs....
I hope it doesn't flutter like my first version 13 years ago.
Vern
So from your previous comments, when you used less washout, you had handling problems on tow but it was a cleaner/faster ship. Is that about right?
Flutter is a tough nut to crack. I also had a "flapping" swept wing like this until I added so much carbon and glass that it wouldn't fly. Just like bending forces, I think that flutter resistance is best handled by focusing reinforcements at the root area. Any thoughts?
Kent
Old Dec 29, 2011, 03:38 PM
Florida
Joined Mar 2005
Kent,
Less washout makes the glider very squirley on tow. Maybe if I had taken it to a slope it would have proven to be a very good fast flyer. But, I was looking for a soaring ship I didn't need to drive for an hour to fly.
The first skinny wing had no spars.... so it flapped on tow. Once off tow it was a dream to fly. So I started to put spruce spars in (I had no carbon) this did wonders in eliminating flapping. I now use carbon tow 1/3 of the way back from the leading edge, top and bottom.
I sand a shallow ditch about 1/32" deep and 1/2" wide with a narrow sanding block. That way the carbon fills the ditch and does't leave a lump in the sheet balsa when bagged. Along with that I now I put carbon tow just ahead of the line that the ailerons and flaps are cut. Sometimes I'll put 1 strip off carbon tow at the trailing egde to keep it straight and ridgid.
The root needs to be strong but light, so I use 1/4" plywood with carbon tow top and bottom bagged before setting it into a ditch carve into the 2 halves. There's not much room in these narrow chord wings so careful planning in where the spars and wiring for the servos go.
I hope this makes sense. I bagged some of my wings with 2 oz. carbon cloth, but that became so expensive I went back to using balsa. Now carbon cloth is crazy expensive and I haven't used any for years.
Vern Flying wings need to be light for great flatland flying.....
Old Dec 29, 2011, 04:33 PM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
Any anhedral Vern? also any suggestions on optimum hook position relative to cg?
miniphase is offline Find More Posts by miniphase
Old Dec 29, 2011, 06:30 PM
Florida
Joined Mar 2005
Paul,
Yes, 1 deg. of anhedral per side. That seemed to work pretty well. I put my hooks about 1/2" ahead of the CG.
How's your thermal wing coming along?
Vern
Old Dec 29, 2011, 06:43 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I'm obviously the noob in this group. I've noticed that these wings often have anhedral in the tips, which in conventional aircraft would make it roll unstable.
Can someone explain this one to me? A link to a German website would be fine. No doubt some thing to do with the sweep.
Kent
Old Dec 29, 2011, 07:06 PM
biber is offline
biber's Avatar
Joined Dec 2004
Winglets are basically a very extreme form of polyhedral.
Adding to that, sweep does act like dihedral, whenever the swept wing does create lift.
So at low speed, the dihedral effect of the sweep contributes noticably to the whole and at high speed it hardly does at all.
With sweep and winglets you have lots of effective dihedral already and in many cases less would be better.
Then you build some anhedral into it to have just the needed amount.
biber
Discussion 3.2m thermal 'wing miniphase Flying Wings 63 Feb 29, 2012 06:01 AM
Discussion sig Thermal Dart wing covering ? larryg Free Flight 7 Dec 14, 2011 11:16 PM
Question EPP plank or swept wing for thermal sky_surfer_fra Foamies (Scratchbuilt) 1 Nov 10, 2011 02:05 PM
Discussion McClain Wing Cores MWC 48"-Thermal Flying cliffo Flying Wings 0 Nov 02, 2011 02:51 PM
Wanted Speedo Thermal wing cores Twyl Aircraft - Sailplanes (FS/W) 9 Oct 27, 2011 11:26 PM
