Old Dec 26, 2011, 07:45 AM
Vernon Hunt is offline
Find More Posts by Vernon Hunt
Vernon Hunt's Avatar
Florida
Joined Mar 2005
Thermal wing
Hey! This is good for us flying wing enthusiasts.
I'm currently building a thermal glider based on a wing that I experimented on almost 13 years ago. I'm still playing with the idea light weight is better, so this wing is carefully constructed from light foam cores, and light 1/16" balsa. Some carbon tow acting as spars.
Vern
OOOps its not a Horten wing NEVERMIND
Vernon Hunt is offline Find More Posts by Vernon Hunt
Old Dec 26, 2011, 10:33 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Vern
That's the cool thing about the Nurflügel forum. ANY wing only is welcomed. Tip rudders are fine. A little pod fuselage is fine. I use the German forums as an example of what is and is not a Nurflügel type plane.
I'd suggest the we error on the side of "anything goes" just to be sure we don't restrict imagination.
I'm subscribed!
So Vern, this one looks done already. Sweet. What's the story behind this one....
Will it have tip rudders? All the other skinny wings like this have tip rudders. I know that mine needed them.
Is there any twist in that wing?
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Dec 26, 2011, 02:05 PM
Tail Saw is offline
Find More Posts by Tail Saw
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
No problem Vern,
as Kent wrote, any wing is welcomed. The transition from pure wing to any other wing is smooth.
The green Horten wing project called "Dogma" has very small wingtips.
Is this still a Horten or not?
My colorful RES-Wing Ares has a nearly bell shaped lift distribution
at small angles of attack, but it has winglets. Horten, flying wing, Nurflügel, tail plane without tail...what is it?
I see winglets as wing components, not as tail parts, but where is the border?
As long as it flies well, the definition does not really matter.....
ARES, 2. Tag der Flugerprobung (6 min 23 sec)
Please report here about your project, this is the right category
Regards,
Uwe.
Tail Saw is offline Find More Posts by Tail Saw
Old Dec 26, 2011, 02:19 PM
Florida
Joined Mar 2005
Yea! Thanks guys.... Just didn't want to gum up a good thing.
I will keep reporting on my progress. Yes, it has tip rudders.
Vern
Old Dec 26, 2011, 04:21 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Closed Account
Joined Dec 2005
Regards,
Uwe.
Uwe,
The wing in the third und fourth photo are the wing type I am interested in. Can you tell me more about that wing please?
Lou is offline Find More Posts by Lou
Old Dec 26, 2011, 04:44 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Originally Posted by TestUser01 View Post
Uwe,
Here you go...
http://thermik-board.de/nurfluegel-f...asse-t421.html
Brian
cpdude is offline Find More Posts by cpdude
Old Dec 26, 2011, 07:39 PM
Florida
Joined Mar 2005
Here are a few specks for this wing. 100" wingspan, 25deg. of sweep. So far it weighs 21ozs. The cores are cut in 3 sections per panel. It has progressive twist, ending at 4.5 degs.
I plan to cover this wing in Esaki yellow tissue, maybe blue rudders. I spent the past year re-learning my old stick and tissue days as a kid. This gave me the hope of building light for my new wings. I hope it doesn't flutter like my first version 13 years ago. That wing had no spars and would flutter like a swim fin on the tow line till it slowed down, very funny. This wing has carbon tow top and bottom in forward and rearward position.
Vern
Old Dec 26, 2011, 07:57 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
That's what I call beauty.
What airfoil(s) does it use?
biber
biber is offline Find More Posts by biber
Old Dec 26, 2011, 11:05 PM
Lou is offline
Lou
Lou
Closed Account
Joined Dec 2005
Originally Posted by cpdude View Post
Thanks!!
Old Dec 27, 2011, 02:41 AM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
as Biber says...it looks beautiful Vern
miniphase is offline Find More Posts by miniphase
Old Dec 27, 2011, 04:02 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Me too
nmasters is offline Find More Posts by nmasters
Old Dec 27, 2011, 07:25 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Originally Posted by nmasters View Post
Me too
Me three!
Shedofdread is offline Find More Posts by Shedofdread
Old Dec 27, 2011, 09:57 AM
Florida
Joined Mar 2005
Thanks! Biber, miniphase,nmasters,shedofdread,tailsaw,
I think I got you all. The airfoil is a modified SD 7037/ S7003. I made the templates years ago and I'm still using them.
I wanted to do removeable tip rudders, but they were to flimsy. I also wanted to do a two piece wing so I could fit it into my tiny car, too heavy. So I've glued it all together with a spar at the center. Today I'll try and get the tow hooks ready. I use two hooks outboard for less stress and safer towing.
Vern
Old Dec 27, 2011, 10:07 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
You just couldn't leave the SD7037 alone, could you
Old Dec 27, 2011, 11:11 AM
Florida
Joined Mar 2005
Kent,
It was there for the picking, and I couldn't resist.
vern
Discussion 3.2m thermal 'wing miniphase Flying Wings 63 Feb 29, 2012 06:01 AM
Discussion sig Thermal Dart wing covering ? larryg Free Flight 7 Dec 14, 2011 11:16 PM
Question EPP plank or swept wing for thermal sky_surfer_fra Foamies (Scratchbuilt) 1 Nov 10, 2011 02:05 PM
Discussion McClain Wing Cores MWC 48"-Thermal Flying cliffo Flying Wings 0 Nov 02, 2011 02:51 PM
Wanted Speedo Thermal wing cores Twyl Aircraft - Sailplanes (FS/W) 9 Oct 27, 2011 11:26 PM
