Espritmodel.com Heli Air
Old Jul 09, 2001, 06:41 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Modeltech ME 109 Electric Conversion Which Prop?
Well I bought my ME 109 today and the specs are pretty close to what I had guessed. 45 inch wing and 360 inches of area. Weight with a 25 glow is supposed to be 3.2 pounds. The plane is pretty lightweight for an ARF. My question is that I will be using my AStro 805G Brushless 05 with Superbox. The Ratio is 3.3 to 1. What prop do you think I can use on the plane? Astro says to run a 12x7 but if I could get it down to a 10x8 that would be great on 8 RC 1900 cells and 2400's/
Thanks Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Jul 09, 2001, 11:05 PM
Folsom,Ca,USA
Joined Apr 2001
Old rule of thumb states:
Decrease diameter by 1" and increase pitch by 2" and it will turn the same rpm
Difference will be higher level flight speed with less vertical.
I'd guess you would need more like a 10/10 if you want to stick to that diameter.
An 11/9 would be the same ( see rule above ) as the 12/7
DaveW is offline Find More Posts by DaveW
Old Jul 09, 2001, 11:46 PM
rcastab's Avatar
SF Bay Area, California, USA
Joined May 2001
I want to plug in your parameters into electricalc to see which is best. What turn is your motor, or what is the rpm/v?
rcastab is offline Find More Posts by rcastab
Old Jul 09, 2001, 11:56 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Stab my motor KV is 3500 RPM/Volt. I am not sure how many turns the motor is.
Thanks Much Joe
Old Jul 10, 2001, 12:31 AM
rcastab's Avatar
Joined May 2001
If you want to use the 10x8, 10 cells is best. If you want to use 12x7, 8 cells will be fine. Assuming you end up with a 3.5lbs airplane after conversion, you can get 80 to 70 watts per lbs, respectively to the mentioned setup above. And your wingloading will be about 24-25 oz/sq feet, and about 19-20mph stall speed, so when you land you might have to fly it down. Also both setup will draw a maximum 29.5 amps, so it's okay.
And the figures are from electricalc version 2. Good luck and let us know how it goes.
[This message has been edited by rcastab (edited 07-10-2001).]
Old Jul 11, 2001, 12:21 AM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Thanks allot Stab, I emailed Astro Bob last night and he also advised me to use the 10x8 or even 9x8 props. He also said to try an 11x8 and that I can add a cell with the 9x8 and 10x8 props. So I will try 8 cells on a 10x8 APC first and see what kind of performance I get. I also ran some numbers through E Calc 2 and got about the same as you.
Thanks Allot Joe
Old Jul 09, 2002, 07:34 PM
Joined Jul 2002
ME-109 + 805G experience
I have been flying this plane with the 805G in it now for
about 6 months with a 12-8 APC prop on it and 10 2400mA
cells with no problems.
I did make new landing gear wires 1/2" longer an raked 1"
more forward than stock for the large prop and to improve
ground handling.
I also added an exaust scoop on the bottom of the fuse behind
the wing which really helps to cool the batteries and motor.
After a 5 minute flight at full power, the batteries are warm and
the motor is not too hot to touch.
Good luck!
Patrick McElroy is offline Find More Posts by Patrick McElroy
Modeltech Me-109 Conversion FAA Scale Electric Planes 145 Jan 04, 2010 01:27 PM
For Sale ModelTech ME 109 sloper/Electric dr.E Aircraft - Sailplanes (FS/W) 2 Feb 13, 2006 08:16 PM
ModelTech Magic 3d Electric Conversion rvillegachapa 3D Flying 31 May 12, 2004 02:26 PM
Modeltech ME 109 25 Maiden Video Reverend Fuel Warbirds 1 Dec 19, 2003 09:42 PM
Modeltech ME 109 fs dr.E Aircraft - Electric - Airplanes (FS/W) 8 Jan 02, 2003 09:35 PM
