Old Dec 25, 2011, 04:08 PM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
Kv problems. scorpion 4035 and 4025 12N8P, rewind issue.
Previously, i rewinded a scorpion HK-4025 12N8P motor with 3 strands, 0.8mm wire, 10 turns delta, Kv is 930.
Today, i rewind a scorpion HK-4035, 12N8P motor, with 8 strands, 0.64mm wire, 6 turns delta, Kv is 1028.
Both my rewinded motor have higher Kv than original scorpions with same turns.
Motor is tested of Kv before rewind, and match the labelled Kv on the motor. So i assume magnet is fine. Everything keeps original except the wires.
Any thought why this is happening?
modisc is offline Find More Posts by modisc
Old Dec 25, 2011, 11:46 PM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
looks like everyones outta town
lectroglide is offline Find More Posts by lectroglide
Old Dec 26, 2011, 12:50 AM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Same wind ABC x4?
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Dec 26, 2011, 02:56 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Originally Posted by manuel v View Post
Same wind ABC x4?
Manuel V.
i noticed, when i get rid of the original winding, that scorpion maybe has 1/4 or 1/2 turn cross winding to switch from one teeth to the next, such as from teeth 1 to teeth 4, and to teeth 7, then 11. Or maybe I am wrong, not sure. I guess this is to save some room at the bottom of the stator. While my winding does not, winding looks like as shown in the pic. besides that, winding is exactly ABCABCABCABC.
Of course, no shorts, motor runs perfectly. besides the nearly worn bearing, will replace as soon as i receive my order in a few days, finally, as well as new shaft.
for the 4025, 27% more copper cross section area than original
for the 4035, 50% more copper cross section area than original
Old Dec 26, 2011, 12:52 PM
manuel v's Avatar
Joined Aug 2004
modisc.
All wires across nut count.
Fore same Kv is necessary copy all half turns.(make a clone)
Parasite wire across nuten, count.
In one 6turn motor one 1/2 turn in any teeth count very mush.
Maybe Scorpion, do not have 6 wires nuten motor, maybe have 7.
if you rewind with real 6 turn wires,, has big differences.
Manuel V.
Old Dec 26, 2011, 02:16 PM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
good. That is a reasonable explanation! But need to make sure of that! I am hoping anyone has similar experience!
Old Dec 26, 2011, 06:00 PM
Alan Hahn is online now
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
As I recall, when I wound several of the Scorpion motor kits a few years back, I also tended to come out with a somewhat higher KV than you would infer from the stock count.
I recall asking the same question as yours in the Scorpion Kit thread in this particular subforum. I think I concluded that the difference was how I counted winds as opposed to Scorpion's definition, particularly the way to go from one tooth to the next.
I have forgotten some of the details, but that was an interesting thread in general.
Alan Hahn is online now Find More Posts by Alan Hahn
Old Dec 26, 2011, 06:49 PM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Good to know someone has the same experience. Can you share the link of your thread? Thanks^^.
Old Dec 26, 2011, 07:17 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Could the difference be explained by the way you are measuring the Kv as opposed to how Scorpion measures it?
I know the quick and simple full throttle RPM divided by the voltage at the same moment it time is considered to be a "raw Kv" and close enough for out purposes. I think I've also read that it will be a little higher than the "real" Kv.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Dec 26, 2011, 08:05 PM
manuel v's Avatar
Joined Aug 2004
Jack
The difference is very little.
check my test:
http://www.rcgroups.com/forums/showt...777998&page=82
820 RPM/Volts vs 829 Kv with formula.
Manuel V.
Old Dec 26, 2011, 08:49 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Manuel,
OK, I had read those tests and forgotten how close they came out. That is only about a 1% difference.
modisc,
On your 930 and 1028 Kvs on your rewinds, what did Scorpion have on those for the Kv with the original winds?
Jack
Old Dec 26, 2011, 09:05 PM
Chicago 'burbs
Joined May 2006
Here is the link to the overall thread.
http://www.rcgroups.com/forums/showthread.php?t=681251
Surprising to see how far it has fallen back.
At the time it was quite active.
Old Dec 26, 2011, 11:40 PM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Jack
check my test:
Manuel V.
Exactly. If you are concerning about the voltage reduction I times Rm in the kv formula, yes, even when I is huge, the production will be quite small, since Rm is usually pretty small, such as 50mΩ.
So, Kv test even under some load will not be far from the actually Kv.
Old Dec 26, 2011, 11:42 PM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Originally Posted by jackerbes View Post
Manuel,
modisc,
Jack
check out the pictures. 4035 is rewinded 6 turns delta, so the original is the 4035 800Kv, which is also 6 turns delta.
4025 is rewinded 10 turns delta, so the original is the 4025 740Kv, which is also 10 turns delta.
Old Dec 26, 2011, 11:46 PM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
that's quite a long thread^^. I rewinded another 4025 just now, with 6 strands 0.64mm, 8 turns delta, about 50% more copper again. standard ABCABCABCABC winding, no cross turns. so i am expecting roughly 1175Kv, according to my 940Kv 10 turns delta 4025.
I'll see what is the Kv soon
Discussion Scorpion 4025-550kv 12n8p rewind lennyk Electric Motor Design and Construction 36 Dec 20, 2011 08:57 PM
Discussion Scorpion hk-4025 rewind. 6N8P replacing original 12N8P, 5X0.8mm, 5 turns. 1700Kv modisc Electric Motor Design and Construction 53 Dec 15, 2011 04:39 PM
Sold Scorpion 4025-630 KV motor orlampa Aircraft - Electric - Power Systems (FS/W) 0 Jan 04, 2011 12:37 PM
Sold Scorpion HK-4025-630 kV motor egiraldo911 Aircraft - Electric - Power Systems (FS/W) 0 Jul 12, 2010 10:09 PM
Sold Scorpion 4025 - 1100 KV Aobid Aircraft - Electric - Power Systems (FS/W) 2 Sep 14, 2009 08:37 AM
