Old Dec 25, 2011, 08:12 AM
Robert Burson is offline
Find More Posts by Robert Burson
AZ Outback
Robert Burson's Avatar
Joined Dec 2000
New Years Day F5J,X5J,and SOR 2011
First Merry Christmas to everyone. Second a Happy New Years.
No Rule changes for 2012. Fly them if you have them.
TO ENTER, please post to this thread your ship and power train information, before the days of the contest. During the day of the contest post your scores.
You may fly any or all of the classes below. In general, all classes use flight time - motor time and up to 30 points for landing.
The goal has been to minimize the rules to stress a Unlimited nature for these events, so everyone with an electric sailplane will have an airframe and motor that will meet the rule requirements.
TASK: Fly three 10minutes rounds unlimited and 5 minute rounds in SOR, using only thermal updrafts with an electric motor powered sailplane.
X5J eXtreme UNLIMITED rules:
1. Any airframe, motor, battery, ESC, and prop maybe used.
2. Flight time has motor run time subtracted from it.
3. 30point landing tape, in 1 meter increments worth 3pts/m
X5J eXtreme SOR rules:
1. Any airframe, battery, ESC, prop, motor with 28mm diameter and 17mm
magnet bell length or less.
3. 30 point landing tape, in 1 meter increments worth 3 pts/m.
General Rules:
1. Any part of the airframe maybe used to determine max. landing points.
2. Round motor and flight times to closest second.
3. Motor must be running at launch.
4. Each second of flight time is one point, seconds greater than 10minutes are subtracted.
5. First and additional motor runs, one point per second, loss of landing points on second motor run.
FAI F5J generalized
TASK: Fly three 10minutes rounds, using only thermal updrafts with an electric motor powered sailplane.
1. Any airframe, battery, ESC, prop, motor maybe used. To FAI limits.
2. 10:00 minute window, with flight points starting on launch. Over flying window 0 landing points.
3. A device to record flight starting height, after a 30s or less motor run, at the beginning of the window. To establish starting height fly level for 10s after motor run.
4. .5pts subtracted for each meter of starting height, 3pts subtracted for each meter above 200M, from possible 10minute flight time ((600pts or number of flight seconds) - (starting height(.5 or/and 3))).
5. Same landing tape but 5pts per meter with 50pt possible. Landing points will just be added on since you are not flying in a group to normalize scores.
This event is to establish a general data base and look at different recorded flights to see if there are any concerns on determining starting height.
If you look at these rules you can fly any e sailplane with a logger.
Example: flight time 9:58 seconds, starting height from logger 156M,, 1.5m from end of tape.
598-(156*.5) + 45 = 565pts
This is the same event as X5J just using starting height as the negative value instead of motor run time.
Hope you can joins us for the fun.
The Best Soaring
Robert
Robert Burson is offline Find More Posts by Robert Burson
Old Dec 25, 2011, 04:23 PM
jawarejj is offline
Find More Posts by jawarejj
jawarejj's Avatar
Madrid, Spain
Joined Feb 2005
I'm in
Pulsar 3200, MVVS 46 840 sport, 70a esc, 2650mAH-3s-nanotech, 13x8
jawarejj is offline Find More Posts by jawarejj
Old Dec 26, 2011, 06:55 AM
ohmite is offline
Find More Posts by ohmite
ohmite's Avatar
Eden NY
Joined Sep 2001
If the weather cooperates, I am in too. Art Hobby High Aspect for the Unlimited event and Omega 1.8 for the F5J event using my logger.
Best Regards and Happy New Year!
-Eric
ohmite is offline Find More Posts by ohmite
Old Dec 26, 2011, 01:38 PM
Juan Supra is offline
Find More Posts by Juan Supra
Joined Oct 2011
For FAI F5J
Supra 340, Hyperion GS3025-10, 60 A esc, 3300 mAh - 3S- 45C-90C 14x8 1850gr
Regards from Spain, Juan Ramos
Juan Supra is offline Find More Posts by Juan Supra
Old Dec 28, 2011, 08:43 AM
mcramer is offline
Find More Posts by mcramer
Goshen, IN
Joined Dec 2003
SOR if it's fairly calm, X5J otherwise. The forecast is for wind and rain but who knows, they have been wrong many times in the past.
Happy New Year everyone.
mcramer is offline Find More Posts by mcramer
Old Dec 28, 2011, 02:18 PM
DingoII is offline
Find More Posts by DingoII
Czech Rep.
Joined Aug 2006
Count me in - Unlimited and/or SOR and/or F5J depending on weather and a venue I will choose.
I will fly either AH Castor (2.5 m, 980 grams, Axi2814/10 + 9.5x5 + 2S1800), or LS Virus (2m, 580 grams, TG2826-1650 + 10x6 + 2S1500).
Happy New Year and strong thermals throughout 2012,
Jan
DingoII is offline Find More Posts by DingoII
Old Dec 28, 2011, 02:35 PM
rdwoebke is offline
Find More Posts by rdwoebke
Panda Panda Panda Panda Panda
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Not sure if I can get out to fly this year but if I can i'll either do SOR with e Allegro Lite or maybe F5J with e allegro or Paragon.
rdwoebke is offline Find More Posts by rdwoebke
Old Dec 29, 2011, 12:02 AM
Luis Moya is offline
Find More Posts by Luis Moya
Luis Moya's Avatar
Mexico
Joined May 2004
in
F5J
Radian (stock) or with flaps.
All the best
Luis
Luis Moya is offline Find More Posts by Luis Moya
Old Dec 29, 2011, 12:48 AM
steveburns is offline
Find More Posts by steveburns
steveburns's Avatar
Chipping Norton, UK
Joined Jan 2005
I'm in.
Will probably try both XFJ and F5J but that's weather dependent.
Stork 2, Kontronik 480/5.2:1 box, 3s 2200.
Good luck,
Steve.
steveburns is offline Find More Posts by steveburns
Old Dec 29, 2011, 09:47 AM
AZ Outback
Joined Dec 2000
I'm in with the Pike Superior and will be flying FAI F5J, but it looks like 24mph winds according to Windmapper so it does not look good for New Years. Hope your weather is better, and of course HAPPY NEW YEARS. I will be traveling on New Years day so, it maybe a Thursday or Friday before I can post the results.
The Best Soaring to Everyone
Robert
Old Dec 29, 2011, 05:40 PM
Japicasa is offline
Find More Posts by Japicasa
Japicasa
Madrid, Spain
Joined May 2010
Getting in
F5J FAI
Model: Langostino V (345cm) 2190gr
Pwr train Aeronaut 18x10 Turnigy kv480 50A ESC 3S 2600mAh
Japicasa is offline Find More Posts by Japicasa
Old Dec 30, 2011, 04:54 AM
jawarejj is offline
jawarejj's Avatar
Madrid, Spain
Joined Feb 2005
Another Spanish Pilot
Our friend Carlos asked me to put his details:
Carlos Pereira:
Estileto, Hacker B2015L, 11x6, 1200mAh, ESC 25A
Extreme Unlimited and F5J FAI
We (Japicasa, Juan Supra, Carlos and myself) will fly together but we also feel we fly with all together with people around the globe.
Happy Holidays for everybody.
Old Dec 31, 2011, 04:31 AM
jawarejj is offline
jawarejj's Avatar
Madrid, Spain
Joined Feb 2005
More guys for the Gang ;-)
Julio Contreras
X5j unlimited
Astra 2,15m
Turborix 28-30
Esc 30a
Paco Puebla
eSupra
hacker bl50s
Jeti 66a
3s 2200
Antonio Tirado
eSupra
X5j and F5J
Kontronic 480
Kontronic 80a esc
1500mah 3s
Paco and Antonio will provide power plant
Regards, Javier.
Old Dec 31, 2011, 12:18 PM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Robert
Looking at 20-30mph winds and gusts to 52 here. Good day to stay inside.
Good luck to all that have good weather and can fly!
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Dec 31, 2011, 12:48 PM
AZ Outback
Joined Dec 2000
Ed
You just dig the trench at little deeper. Now we are up to 35mph for New Years, not looking good.
Robert
Contest Last X5J SOR F5J for 2011 Nov13th/14th SignUp Robert Burson Electric Sailplanes 23 Nov 16, 2011 08:35 AM
Discussion New Years Day X5J eXtreme 2011 Robert Burson Electric Sailplanes 53 Jan 03, 2011 02:28 AM
Contest X5J eXtreme NEW YEARS DAY Sign-up Robert Burson Electric Sailplanes 54 Feb 01, 2008 04:12 AM
Discussion NEW YEARS DAY, X5J eXtreme 2007 Sign-up Robert Burson Electric Sailplanes 60 Jan 04, 2007 08:02 PM
Discussion X5J eXtreme NEW YEARS DAY 2006 SignUp Robert Burson Electric Sailplanes 77 Apr 06, 2006 09:47 AM
