The Bantam was not covered in white first, just the coloured Esaki over the mylar. The Mamba was covered in white first as I wanted to use a particular colour scheme involving white dividing strips. As to weight, the whole of the covering on the Mamba, which is quite a large area, mylar, white tissue, coloured overlays and four coats of thinned dope only added an ounce to the uncovered weight of 16 ounces. |
Joined Sep 2007
You’re very kind Cem, thanks a lot! |
Joined Sep 2007
I'm proceeding slowly but I made the parts that gave me more problems; the motor cowl and the battery hatch. Here are the pictures of the motor cowl, I hope to post the pics of the battery hatch tomorrow.
United States, IL, Chicago
Joined Dec 1996
Hi Guizzo
Love the model, but the pilot really sets her off! Where did you get the original plan from? I keep thinking I've seen it before somewhere, but that happens a lot as the years pile up Really must build a canard one day!Regards Dereck |
Joined Dec 1996
Thank you, Guizzo, checked it out.
Real easy to make it to whatever size is fancied! BTW - if you want to learn lots about canards, have you read this thread: http://www.rcgroups.com/forums/showt...ghlight=canard Possibly more than many of us need! But real good info and some very knowlegable contributors though, if you don't already read this thread D |
Joined Sep 2007
Thanks so much Derek for showing where the canard thread is! I knew it was in RC Groups but I wasn't able to retrieve it!
![]() It's a very interesting thread and I guess I’ll post there a link to my thread. Beg your pardon but I've been a bit busy so the pictures I promised will be posted ASAP |
Joined Sep 2007
Some more pictures!
Joined Sep 2007
I appreciate Owl!
I went ahead another bit. I covered the elevators, ailerons and rudders with paper. I used Hallmark “papier de soie” tissue. I like this paper albeit requires a bit more attention while applying since it shrinks more and has shorter fibers than Esaky, but the final result is definitely pleasant! I like threaded hinges and I did them on the wing tip mounted rudders. I installed a torsion bar on each rudder for I want only the inward turn rudder to move. The torsion bar is a 8cm long piano wire with a diameter of 0.5mm.
Joined Dec 1996
Good to see that you glued the sewn hinge thread into the control surfaces.
Many years ago, I built a 'pseudo vintage' tailless model and stitch hinged the elevons. I didn't glue the thread in at all. After a couple of minutes on what looked like a good first flight - it was my own design and thus I didn't know how the model would fly - the elevons slipped around on those thread hinges. They both moved under the wing bottom surface, which deprived the model of not only pitch and roll control, but the essential upwards reflex it needed to fly level in pitch. There wasn't much left after it dived into the ground. Your rudders are not going to do anything like that. Will be interesting to see how they work on outwards movement only. Lovely workmanship on your model too. Regards Dereck |
Joined Sep 2007
What a pity Derek!
![]() I remember that something similar happened to me with a C/L model. I made the hinges with a cotton band. I did glue the band but I soaked it and the band became brittle! I let you imagine what happened after few flights! ![]() Oh well! It was many many years ago! ![]() ![]() For what concerns my rudders, if you go to post #8, you’ll see the central servo in the wing that will be connected to the rudders via thread. When the servo rotates, it pulls one thread while the second thread slackens so, only the rudder connected to the first thread may deflect. Once the servo returns in the neutral position, the torsion bar realigns the rudder with the fin. Hope I made myself understood, anyway I'll show how it works as soon as I finish the wing. It won't be in few days though since it's time for a sidetrack. The weather is good now and the temperature allows me to stay outside and use my airbrush to paint a GWS Zero I restored this winter. Thanks again, Derek! |
| Thread Tools | |
| Discussion Canard Kits | RC Man | Electric Plane Talk | 6 | Dec 06, 2011 12:02 PM |
| Discussion Premier RC Canard | AC5FF | RC Kites | 6 | Oct 04, 2011 08:13 PM |
| Discussion VR Canard Warm cheepie! | LS6 Tommy | RC Kites | 2 | Sep 19, 2011 10:21 PM |
| Video canard snowgoose and snowflake | phil alvirez | Electric Plane Talk | 11 | Sep 09, 2011 05:50 PM |
| Video Canard Addict's Giant Canard Glider | rcflyer11 | Electric Plane Talk | 7 | May 01, 2010 09:21 PM |
