Old Feb 09, 2012, 04:39 PM
SwissBoy is offline
Find More Posts by SwissBoy
No, you can't fly it.
SwissBoy's Avatar
United States, WI, Menomonie
Joined Nov 2006
Is all this tip work really necessary? I thought maybe I'd just do a patch of glass on the tip to make it last longer.
Originally Posted by wgeffon View Post
Today I glued on the vertical fin and got the peg mounted in the wing tip.
I notched the rear part of the cut in the fin so the boom would slide in and not be butt glued to that joint.
Once the fin was glued on I glassed both sides of the fin to boom joint.
For the peg I wanted to be sure it was never going to get loose or rip out.
I decided to inlay a piece of hardwood. That piece has the hole for the peg and its glued into a cut out I made in the wing tip.
I also didnt want the angle of the peg to be at 90 degrees to the tip panel so I drilled the hardwood at an angle to get the peg close to 90 degrees to the center panel.
This will help with straighter launches because the plane will remain flatter throughout the discuss launch.
After the peg was secure in the hardwood and the hardwood piece was glues into the wing tip I
overlayed some CF cloth on top and bottom.
The peg is extremely secure in the wing tip and should never come loose or rip out.
SwissBoy is offline Find More Posts by SwissBoy
Old Feb 09, 2012, 04:57 PM
wgeffon is offline
Find More Posts by wgeffon
wgeffon's Avatar
United States, IL, Bloomington
Joined Feb 2002
Certainly not required to do all that work on the tip.
Ever have to repair a throwing blade in a foam wing? I have.
Much easier to overbuild it than to repair it.
I look at it this way... There was a 50/50 chance I'd loosen up the peg over time.
I'd rather overbuild it and know I'll never have to fix it and that I can throw the plane as hard as I can.
wgeffon is offline Find More Posts by wgeffon
Old Feb 09, 2012, 05:12 PM
OldVic56 is offline
Find More Posts by OldVic56
Did I do that?
United States, AL, Dothan
Joined Sep 2011
Being married to a nurse has it's advantages. Blemtape for the crew
OldVic56 is offline Find More Posts by OldVic56
Old Feb 09, 2012, 05:22 PM
wgeffon is offline
wgeffon's Avatar
Joined Feb 2002
I agree.
My wife is an ER nurse.
Old Feb 09, 2012, 05:26 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
Haha, well then...I have a girlfriend, but she a hair stylist. No help. lol so what width tape?
And makes sense, I'll do what I can to beef it up in my own way.
Old Feb 09, 2012, 05:36 PM
wgeffon is offline
wgeffon's Avatar
Joined Feb 2002
I used 1/2" tape.
1/4" on each side is plenty.
My plane is done except for finishing up the surface ends of the pushrods. I'll do that this evening and post pics of the finished plane after that.
Old Feb 09, 2012, 09:10 PM
wgeffon is offline
wgeffon's Avatar
Joined Feb 2002
All finished.
Old Feb 09, 2012, 11:47 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
Wooo Hi-vis! What paint did you use and how much weight did it add?
EDIT: nvm, is that covering?
Old Feb 10, 2012, 06:28 AM
wgeffon is offline
wgeffon's Avatar
Joined Feb 2002
Ultracote Park Lite covering.
Old Feb 10, 2012, 07:44 AM
OldVic56 is offline
Did I do that?
Joined Sep 2011
It looks good!
Old Feb 10, 2012, 07:53 AM
RCROBBY is offline
Find More Posts by RCROBBY
Laser Cutter Guy
United States, PA, Greensburg
Joined Oct 2009
Looks awsome!
RCROBBY is offline Find More Posts by RCROBBY
Old Feb 10, 2012, 08:31 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
It looks like someone could become impaled!
Quick61 is offline Find More Posts by Quick61
Old Feb 10, 2012, 12:02 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
I guess it is not F3K legal for nose radius.
Talk about sticking a landing.... right into your hand!!
LOL
Fly2High is offline Find More Posts by Fly2High
Old Feb 10, 2012, 01:22 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
Got mine this morning, everything looks fantastic, and can't wait to start the build later today! Bob finished the wing for me before it was shipped, and it's gorgeous. Definitely going to only do a partial trim scheme....the wood is really pretty.
Old Feb 10, 2012, 09:03 PM
rcbobcat55 is offline
Find More Posts by rcbobcat55
sailplane nut
Herminie, PA 15637
Joined Apr 2007
Wow, your color scheme is breathtaking-even I could see that in the air. Do you have any idea how much weight the covering added? It would be helpful to know-it sure would be less time consuming than 4 coats of polycrylic and less likely to ding up too-it looks beautiful-good job. I can't wait to see what color schemes other people come up with. Let me know how it flies.Bob M.
rcbobcat55 is offline Find More Posts by rcbobcat55
Sold 1M DLG disser wing pyrsly Aircraft - Sailplanes (FS/W) 2 May 12, 2011 05:03 PM
Sold NIB Arthobby Bobolink 1m dlg Beauregard Aircraft - Sailplanes (FS/W) 2 Jul 13, 2005 03:09 PM
FS: NIB Boblink 1M DLG Lance Prior Aircraft - Sailplanes (FS/W) 1 Dec 06, 2004 02:26 PM
FS: NIB Art Hobby Bobolink 1M DLG Lance Aircraft - Sailplanes (FS/W) 3 Nov 08, 2004 03:51 PM
