continued using the PS post script print settings for a large plan rather than tiled pdf
The above illustrations were downloaded from the internet.. Then worked on in sketchup..
For making nice curves in SU I use the bezier.rb plugin I do all my simple plans in SU as its an easy CAD program to work with.. For additional add on tools look to the sketchucation site and others.. For more info on using SU on simple plans and for starters ..see here... http://www.rcgroups.com/forums/showthread.php?t=920416 Use the version7 pro download here.. because thats the version the plugins are for.. Below is a link to a direct download of the 7pro version which will reset back to free after 8 hours use Remove any free SU8 if its installed then install the older version http://support.google.com/sketchup/b...n&answer=60107 and for dxf out.. http://sketchuppluginreviews.com/201...plugin-review/ and dxf in direct from google.. on this page under workflow enhancements is a link to the importer..click on windows or mac to get it.. do a save as in case it later disappears http://sketchup.google.com/intl/en/d...ugins.html#dwg or http://forums.sketchucation.com/viewtopic.php?t=22199 you need to register with sketchucation to get the downloads going there are a few dxf importers and exporters so try and find one that does what you want .. |
Cutepdf is available here...free...for outputting pdf's from any program on your PC
http://www.cutepdf.com Gimp is here...free.... for cleaning up your image files ...a powerful open source photo and image editor..much as photoshop http://www.gimp.org/downloads Inkscape vector graphic design program...pdf to dxf an open source program called Inkscape is a vector editor.. A powerful program, but for me just used as a file converter as I prefer sketchup which is so simple for rescaling and working in.. http://inkscape.org/download/ ....free |
Sorting other image files...
There is a good tutorial on cleaning up your image files here.. http://www.outerzone.co.uk/tutorials/02/index.asp It was made using photoshop but Gimp will do much the same, so I sugest you have a read here first, then find out how Gimp does it my personal choice would be to import an image into sketchup then trace over, but thats a slower process.. days rather than hours.. More printing quirks from sketchup Ive been bringing in an image file, cleaned up and converted to black and white in gimp and saved as a psd..photoshop.. I used SU to scale the model plan to a 48" span span.. all ok at this point.. On the print out to a pdf using the usual print settings the image dissapeared... It was the HLR setting... when using images rather than a dfx file, having the HLR checked on in the print box makes the image vanish. . So uncheck the HLR box and go for large format.. higher resolutions wont improve the look and only take a lot longer to process And the large format makes for the smallest Mb file The main problem with image files is you are stuck with whatever quality they were produced or scanned at.. the final plans can be poor , blocky is common, and difficult to work from..thats why I said its always better to do a trace over in sketchup, then the end result is crisp and fully scaleable |
| Thread Tools | |
| Question Is a 60" Yak 54 okay to put in here? | kpilot786457 | Giant Electric Planes | 2 | Nov 27, 2011 05:47 PM |
| Discussion I don't know where to put this BUT here's what happened. (UPDATE) | mtdoramike | Trader Talk | 23 | Jun 05, 2011 03:17 PM |
| Help! i got some pic of my titan i wanna put on here | razerunner | Mini Helis | 6 | Feb 01, 2009 07:01 PM |
| Discussion Throw me a bone here...Tryin' to ID some models | slopetrashuk | Slope | 26 | Sep 19, 2007 05:06 AM |
| Any plans for a S400 PBF? Anyone want to go in on some Fan Fold around here? | Duane | Foamies (Kits) | 1 | Mar 27, 2003 10:41 AM |
