Old Dec 21, 2011, 02:15 PM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
Question
Some questions that have not been answered
Allright, mabey some of these questions have been answered,, but in my reading of the countless pages,,, typical of most forums,, mostly what I find is fluff and links to other pages,, containing some useful info,, and alot more fluff.
So, some basic questions about quads or multis in general.
Center of gravity? Is it better to have the copter balanced "high" as in weight concentrated up higher , or "low", as in the battery and and heavy components mounted as low as possible. Im refering to stability,, which is preferable for best stability?
What is the most stable, "beginner friendly" platform? Quad? Hex? Tri? X? +? Concerned with hands off stability here,, best for beginners.
When positioning the counter rotating props on a quad,, how are they arranged?
Whats better for a beginner, SMALL or LARGE? To expand on this,, what about a long span, lightweight frame? or?? Whats best for a beginner size and weight wize?
What about high power in a compact size,, such as high power motors turning 3 blade props on a smaller frame? Is that good for a beginner? Weight would be higher, and mass more centrally concentrated. Would it be better"more stable" to spread the motors out farther?
Questions regarding arm length and stability would tie right into the sensitivity of the gyros on the control board,, so what do the popular KK and HK boards prefer? Long arm,, short arm? Does it even matter??
So, beginner multi set up: Quad? High center of gravity? Lo CG? Long or short arms? Higher or lower power to weight? Tri? if quad, then X or + better for beginner?
Thanks!
topforce is offline Find More Posts by topforce
Old Dec 21, 2011, 02:30 PM
OLDTOM is offline
Find More Posts by OLDTOM
OLDTOM's Avatar
United States, TX, Waxahachie
Joined Jun 2011
Quads are simlper,no servo...cg, a little below center works great....arms, a little longer than your props is a good starting point for beginners....x/+?, get a radio that allows elevon mixing and it is a simple flip of a switch without making a bunch of other changes...
that choice is a personal thing, makes little difference.
hope this helps, good luck..
OLDTOM is offline Find More Posts by OLDTOM
Old Dec 21, 2011, 04:34 PM
JanHenning is offline
Find More Posts by JanHenning
JanHenning's Avatar
Norge, Vestfold, Tønsberg
Joined Apr 2010
My thoughts:
Quad + is the easiest to get right.
CG: a little below center, like OldTom said, or in center if you can manage that.
Arm length: It might be easier to get a stable KK setup with long arms, but not too long, because that can give you problems in wind. 1.5 x prop diameter is a good starting point. FC's with accelerometers and advanced PID setup are not so sensitive about this.
Power: Underpowered multis are never easy to fly. You need a reserve, so my advice is to make it slightly overpowered and switch to smaller props until it hovers at mid stick.
JanHenning is offline Find More Posts by JanHenning
Discussion Now THERE'S a wing that should have been on 2.4... mr_editor Slope 82 Dec 19, 2011 11:44 AM
Sold Rc magazines There have been no replies or questions rcjimi Non R/C Items (FS/W) 0 Sep 14, 2011 04:28 PM
Discussion Not exactly an electric but I have some questions... 98grand Electric Power Cars 11 Aug 08, 2011 09:35 AM
Discussion Motor/prop questions that have been really confusing me Mike4192 Power Systems 7 Oct 12, 2008 12:53 PM
