| Wingspan: | 57in. / 1450mm |
| Wing Area: | 362 sq. in. / 23.3 dm. sq. |
| Weight: | 2.25 lb. / 1020g |
| Length: | 38in. / 965mm |
| Wing Loading: | 14 oz./sq. ft. / 43 g/sq. dm. |
| Servos: | 4 micro |
| Transmitter: | Tactic TTX600 2.4 GHz |
| Receiver: | 6 channel Tactic |
| Battery: | 1800 mAh 11.1v 15C LiPo |
| Motor: | Brushless outrunner |
| ESC: | 30 amp |
| Composition: | Aerocell Foam |
| Wheels: | 1.5in. / 38.1mm |
| Prop: | 9 x 5 |
| Typical Flight Duration: | 10 minutes + |
| Manufacturer: | Flyzone |
| Available From: | Your Local Hobby Shop or Tower Hobbies |
| Price: | $279.99 (RTF) $179.99 (RxR) |
The Cessna 350 Corvalis (yes, with one "L") was introduced in 2009 after Cessna purchased Lancair. Originally designed by Lancair as the Columbia 300 and then the Columbia 350, the name Corvalis comes from the name of the community west of Bend, Oregon, the original production location of the Cessna 350. The cowling of Corvalis is reminiscent of the Lancair with the two round cooling ports up front.
Flyzone’s Select Scale RTF version of the Corvalis is an exceptional rendition in not only looks, but also flying qualities. The Flyzone Corvalis is constructed of proprietary Aerocell foam, and the molding is outstanding, right down to the door handles, hinges and wing cuffs. Decals are applied so in about an hour your Corvalis RTF is indeed ready to fly. Included in the package are a Tactic TTX600 6-channel transmitter and receiver, plus a charger and 1800 mAh LiPo battery. This is indeed an excellent product offered as well in a receiver ready version.
A few months ago I reviewed the Tactic TTX600, so check that link for more details. This is a high quality FHSS Spread Spectrum radio with Secure Link Technology, dual rates, digital trims, analog throttle trim, servo reversing, one proportional dial for flaps, one non-proportional on/off, LED power indicator, built in charge jack, and a trainer system. The TTX600 weighs in at about 5.2 ounces (602g). The Corvalis is also available in a receiver ready version. Here is a link to the TTX600 manual.
Includes
Kit requires
As always, take some time to read through the instructions. The Corvalis has an intuitive build, but make sure you understand the build before starting. I would also encourage you to get the battery charging, as you will want to fly in a short period of time. The manual is fully illustrated. I have provided a few more detailed photos.
The two-piece wing has the servos installed and the navigation lighting. The lights include navigation, avoidance and a landing light. Instead of installing a servo near the ailerons and having to install another set for the flaps, the designers placed both servos opposite each other at the wing root. A heavy joiner is used and as one slips the wings together the linkages join too at the EZ link on the servo arm. Take your time, and if necessary, use a pair of hemostats to hold onto the linkage wire as you align the flaps and ailerons.
The Corvalis includes functional flaps which are much more than just aesthetically pleasing. You will enjoy the control they provide both for landing stability and short field takeoffs. Keep in mind the smooth skin of the full-scale Corvalis results from the use of composite laminates. The select scale provided by Flyzone is just as realistic and employs a similar smooth skin through accurate molding. It's an aircraft that wants to fly, wants to go fast and wants to do so with very little drag. The flaps will allow one to land with steeper glide slopes and at reduced speeds.
Not much to do to complete the fuselage other than adding the main gears. The nose gear is pre-installed. Here are a few pictures of the fuselage:
The landing gear will mount to plastic plates glued to the fuselage. The nose gear is installed, but you will need to install the nose wheel.
Many times when you build an RTF the tail becomes permanent, and there is no way to get the plane back into the box to store it when not flying. Not the case with the Corvalis; the tail slips together and two screws securing the tail into place.
The RTF version has the radio installed and is indeed ready to fly.
Setup
Follow the directions and your CG will be right on target. Take a look at the battery port, and as you look to the back towards the firewall you will see a slight ledge. The ESC should be below this ledge, and your battery should be pushed all the way back and on top of that ledge. If you have small fingers you can help guide it or just turn the plane upside down as you slide the battery back, and it will seat fine. Use the provided Velcro to strap it into place. Be careful not to pull too hard on the Velcro because it may tear loose from the foam. You do not have to have a strong cinch to hold the battery, just a light cross over of the Velcro and then slip the extra into the slot on top of the fuselage. I also made sure I had the battery aligned correctly so I created the easiest route to the ESC plug, which will be just behind the motor. The cowling will slip back to the firewall, and then as you push down, it will very securely click into place
The Corvalis right up front is a wonderful flyer. Of course I have no experience in the real full-size plane, but if stability, ground tracking and glide slope are comparable, Flyzone’s Corvalis is right on target as a scale rendition. The wingspan is huge and notable. Ailerons are on the outboard of the wings with flaps on the inboard section. Flap-style hinges that use an offset hinge point for realistic flap movement actuate the flaps. The dial on the TTX transmitter operates the flaps. The elevator has excellent authority, but not too much to cause porpoise flight, and the rudder deflection provides for coordinated turns and cross-wind approach control, without setting one up for stall.
My initial flights, like all flights, took a few clicks of trim to get the plane straight and level. The TTX 600 has digital trims that you can easily hear as you bump them. The big Corvalis is fun to fly and has plenty of power in flight. You are never feeling as though the plane is underpowered. In fact, the hollow body of the Corvalis provides some realistic sounds as it resonates the brushless motor. Tracking is straight after trimming, but you need to recognize the value of the rudder in maintaining that straight flight. Before you leave the ground make absolutely sure your trims are centered and your control surfaces are centered. Look down the fuselage at the tail to ensure your rudder and elevator are centered.
Ground tracking is excellent (see video below). The Corvalis will turn in tight circles and the spring loaded nose wheel is absolutely strong enough to handle those tight turns. The main wheels are intimately joined with the fuselage across a plastic member and held in place with screws. The well designed combination of the main wheels and nose wheel provide perfect stability on the ground with no tendency tip or become unstable even with a hot landing or sharp turn.
Power up for takeoff has options. First, if you want to get the Corvalis in the air quickly, just firewall the throttle. This is probably the only aspect of flight that is out of scale. If you enjoy scalelike takeoffs be gradual and gentle on the throttle, and the excellent tricycle ground tracking will keep you easily centered with little stick pressure on the rudder. If you want an even more scalelike experience dial in some flaps on takeoff and practice your short field takeoffs.
Landings are where the Corvalis really shines. The flaps give you options, but realize they are not an absolute for a safe landing. If you have a long runway the glide slope is still very controllable, but much shallower than with flaps. Think about the full size version and landing process. Flaps are slightly dialed in on the downwind leg, a little more on the crosswind and then the final degrees of flaps are involved after you turn to your final approach. When you quickly maximize the flaps, the nose will rise in response to the lift over the wings. By gradually adding flaps you can trim the nose down in steps until your final approach is almost hands off. I really liked the authority the rudder provided, and you can see in the video how I could control the cross wind easily with rudder input.
Loops are big and lazy as one would expect, and barrel rolls are even bigger. The wingspan, as well as the plane's low wing configuration, are doing all they can to get you back over right side up. The TTX 600 does have dual rates, and you do have the option of using the outermost servo arm positions, but I am not sure why one would do this. The plane flies so well in the factory configuration that one should enjoy what the engineers have created. Inverted flight is not a normal flight configuration, but the Corvalis does this fine with elevator input.
No doubt the Corvalis flies like a beginner airplane. The ground tracking is excellent, rollout is straight with little rudder required, and once in the air, the plane handles like a dream. There are no negatives within the flight envelope. As you know, I am somewhat cautious with the word "beginner," and I think with some dual instruction, anyone can fly, but do it alone, and be prepared for failure. I highly recommend this as a first time plane if one gets some help. For those that have soloed, this is a perfect complement to your hangar.
I would be remiss in not mentioning the flaps again as these do really help with the landing, but also help with the overall slow flight stability. With some time in the pilot's seat, you learn to feel for the other flight controls on the transmitter and fully understand the need to trim for stable flight. Without a trimmed plane or as a beginner not knowing how to trim a plane, getting to the flap dial inflight might take some learning.
IMG_7498.jpg: Use those flaps and have some fun. IMG_7526.jpg: Slow fly is excellent. IMG_7541.jpg: On approach, the Corvalis is supreme. IMG_7551.jpg: Great turning control.
For me, the true value and character of this plane is in the way it looks and flies. It is a breeze to take off, fly and land, so you get a great solid package. I think the designers have done a wonderful job of recreating the Corvalis, and in the RTF version, you have all you need to get into the air quickly. The build is quick and easy and nothing is left for you to figure out or possibly get wrong. The battery is enough to get you up and into the air for some very long flights of ten minutes plus. The tricycle gear is placed perfectly and provides ground stability with a spring loaded nose wheel. This is a plane well worth the cost and one that will provide some great flights.
The good:
The not-so-good:
| Thread Tools |
sterling, Illinois
Joined Feb 2006
Flown this beauty for sometime even full night flights but it shines on it's smooth touch down landings a plus for my otherwise ruff landings with less forgiving models, great.
This is a very cool bird. Motor mount I re-build and I also modded with a GoPro
I use a 3-blade 8.2 x 6 (or maybe 5.5 or 6.5, I don't remember exactly; it's a VarioPROP and the pitch is adjustable). |
Joined Jun 2012
The flaps help it out alot! Watch --
| Thread Tools | |
| Article Review of Hobbico Flyzone Cessna 350 Corvalis Rx-R 57" | Michael Heer | Scale Electric Planes | 11 | Mar 26, 2012 12:22 PM |
| Discussion Help a noob out - Hobbico FlyZone Cessna 182 Skylane Select EP RTF 47.5" | RCGDave | Electric Plane Talk | 14 | Jan 25, 2012 06:06 AM |
| For Sale Flyzone Cessna Corvalis 350 | Jae14 | Aircraft - Electric - Airplanes (FS/W) | 9 | Oct 03, 2011 10:02 PM |
| Video Flyzone Cessna 350 Corvalis | Diesel6401 | Electric Plane Talk | 0 | Sep 13, 2011 08:50 PM |
| New Product Hobbico Flyzone Cessna 350 Corvalis Thread | Endlesslag | Electric Plane Talk | 18 | Aug 10, 2011 05:19 PM |
