Old Dec 31, 2011, 05:35 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Looks great wing man!!!!!! Awesome!!!!
Man my vacuum is going to need therapy after this build is over
falcon5 is offline Find More Posts by falcon5
Old Dec 31, 2011, 08:52 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Foam question. In the early pages, it was said you are using blue foam? Blue is by Dow, pink by Owens-Corning, both polystyrene. Just wondering if you have tried 3M 78. Its made just for polystyrene foams. Has a built in 3- width spray. I used it on laminating the pieces for a plug. Works great. About $10.00 here.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 31, 2011, 08:54 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i didnt see any 78. probably cant get it in cali if i tried too late now, the deed is done..but, ill keep my eyes open for it!
corsair nut is online now Find More Posts by corsair nut
Old Jan 01, 2012, 06:42 AM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
What wing loading are you expecting? I suppose the first question should be what is your expected/hoped for AUW?
Lberry.88 is offline Find More Posts by Lberry.88
Old Jan 01, 2012, 09:28 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
WOW!....now that is a big plane. I had thought about building a foam plane at one time but I don't believe I have the talent you have. I did construct some foam intake (cheek)tube for a plane and I used Liquid Sheeting to cover the foam........worked great. The Sheeting is a liquid which you mix in two parts and then brush onto the foam. The sheeting is self leveling so it smooths out really well on the surface and is fairly light weight. Once dry it can be painted. WOW Planes stocks the Liquid Sheeting.
http://www.wowplanes.com/product_inf...f10a737d4ab5bc
Madmax1965 is offline Find More Posts by Madmax1965
Old Jan 01, 2012, 12:03 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
I hope to be 25 pounds AUW, Brent I think is shooting for 20 pounds.
Root chord is 31" tip chord is 9" so 40 devide by two = 20 so 20" is the average chord. Wing span is 81" I am a little fuzzy on how to figure it from here, I think it's somthing like average chord x wing span will get the wing area then devide by the weight of the plane or somthing like that, sorry..I realy should get my head around the numbers a little more
Old Jan 01, 2012, 12:12 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Got side tracked a bit and started doodling around with a seat. OK back to work on the fues again. I added the air vents on top of the rear fues and did a little blending
Old Jan 01, 2012, 12:33 PM
tehachapi, CA
Joined Jan 2006
whoa sweet! hey, what thickness foam is that on your turtle deck? is that 1/2" ? it looks thinner.
really ticks me off i rounded my edges too much...im trying to figure out how to fix that.
ive been looking at difernt ED T-38 pics to make sure i dont screw up again.
Old Jan 01, 2012, 12:57 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Naw ..it's 1" on the turttle deck also. It was just thinned quit a bit in the rounding process.
From your pics it dos not look rounded too much but it could be the pic, Well if it's a tad too round you could do a spackle build up in the effected area or maybe a 3mm depron build up if it's off by allot but looks pretty good from the pics
Old Jan 01, 2012, 01:00 PM
tehachapi, CA
Joined Jan 2006
i think i came up with a good idea
Old Jan 01, 2012, 02:26 PM
TPfingston is offline
Find More Posts by TPfingston
Retired and Lovin' it!
TPfingston's Avatar
United States, KY, Sturgis
Joined Jul 2007
81x20=1620 sq in divided 144=11.25 sq feet. 25 lbs x 16 oz = 400 ozs. 400 oz / 11.25 sq ft = 35.5 oz/sqft
If I've done my arithmetic correctly, you're looking at about 35.5 oz/sq ft.
Tony
TPfingston is offline Find More Posts by TPfingston
Old Jan 01, 2012, 02:39 PM
tehachapi, CA
Joined Jan 2006
not including all the lift from the flat fuse. even at 25 lbs these will land like feathers...
Old Jan 01, 2012, 02:57 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Yep, they will be real floaters.
Nice work guys.
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 01, 2012, 07:41 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Thanks John,
Did a scale hight check. Main body 12" off ground, nose gear section 11"
Old Jan 01, 2012, 08:01 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Just for fun I put my old 81" long F-4 fues next to the 38. I had to chuckle a bit, the T-38 canopy is as big as the main body of the F-4.
Also the Callie graphics look great, she did an exellant job on them
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
