Old Mar 29, 2012, 11:31 AM
Keenan smith is online now
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Yourrrrrr welcome!
Keenan smith is online now Find More Posts by Keenan smith
Old Mar 29, 2012, 11:37 AM
RAMFlyer is online now
Find More Posts by RAMFlyer
United States, FL, Orlando
Joined Sep 2003
Here is a discussion thread that has some interesting ideas/info... "Most" turbine guys focus most on the rigidity of the servo to flying stab and flying stab to pivot set ups rather than balancing the stab. On my ducted fan Byron F16s I balanced the stabs on the one that had Byrons' half ring connection to the servo, but didn't balnce the stabs on the direct servo control version. Never had a flutter problem either way.
http://www.rcuniverse.com/forum/m_68...%2Cstab/tm.htm
RAMFlyer is online now Find More Posts by RAMFlyer
Old Mar 29, 2012, 02:05 PM
Eddie P is online now
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Originally Posted by gbmoore View Post
Yeh ... it's fun
just finished an evening with the neighbor-kid (now 1st year masters in Aero at Univ. of Colorado) talking about pivot points.....
When CU did the DreamChaser for NASA, the pivot point was placed about 5% in front of MAC (which rang a bell from the thread I mentioned earlier).
When we took the stab from my (lamented) Tam's F-16, the pivot point was about 48% of the root, which calculated to about 20-21% of MAC.
He (of course) was talking about the Beta movements and the ??? factors, of which I only understood the Greek word "Beta"......
Soooo........looks like both of your stabs are in the ball park.
Keep up the PHENOMENAL work!
Greg
"Beta" is a generic term for negative.. it could mean angle of attack, or stability with pitching moments, etc depending on the context. I'd guess he was referencing static/dynamic stability of the stabilizer as it relates to MAC, center of lift / center of pressure... where the pivot point is, and how that plays out. This is a generic symmetrical subsonic airfoil so the variables are fewer, that helps.
Most model airplanes are built with massive servo torque relative to the control surface compared with a full scale. This is good enough to over come small build and engineering errors that are hard to really know exactly how to iron out without wind tunnel and extensive flight testing. Besides we need a strong structure to withstand transportation and abuse real planes don't get. So if we put in a "powerful enough" servo and very strong control support and linkage "for a little extra" we are good (experience shows what works in the past for some models of certain types). I think in this case even if there is some argument about where the actual pivot point should "mathematically" be, it's probably safe to say as long as you have a very strong flight control actuator and supporting structure you could probably get away with some considerable setup "deviations" and never really be the wiser.
Eddie P is online now Find More Posts by Eddie P
Old Mar 29, 2012, 02:34 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
[QUOTE=Eddie P;21178491as long as you have a very strong flight control actuator and supporting structure you could probably get away with some considerable setup "deviations" and never really be the wiser.[/QUOTE]
Well that's the plan anyway. Going to try and make it as tough and slop free as possible. Ball bearings, thrust bearings, aluminum servo arms, and steel rods and links. We will see,
I will be Johny test pilot on maiden day
falcon5 is offline Find More Posts by falcon5
Old Mar 29, 2012, 03:37 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
that will cover it!
corsair nut is offline Find More Posts by corsair nut
Old Mar 29, 2012, 06:54 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Apologies
Sorry for mix-up. Flyingfitz was closer to correct answer. I made a mistake with my addition, as usual Attached was my sketch of your T-38 Stab, I almost erased just now.
PhilLin is offline Find More Posts by PhilLin
Old Mar 29, 2012, 07:08 PM
j32driver is offline
Find More Posts by j32driver
Joined Nov 2008
Originally Posted by rcnats View Post
I'm retired now but here are some pics of my "VIP" flight
That reminds me of the best part of a VIP flight brief. "If you hear me say 'EJECT, EJECT, EJECT' if you say 'What?'... you'll be talking to yourself!"
j32driver is offline Find More Posts by j32driver
Old Mar 29, 2012, 07:57 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by corsair nut View Post
that will cover it!
+1 I think you hit the nail on the head. If you have a slop free, strong linkage and spindle setup it will be fine. I am sure that is Avonds secret.
scatsob is offline Find More Posts by scatsob
Old Mar 29, 2012, 08:49 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
The stab servos came today and they are pretty sweet. No slop in the gear train so that's good.
I got the flaps and ailerons hinged and mounted today, and just about servoed up and ready to go.
Hmmm ...I was kind of looking at what's left to do before it can techniqly go for a maiden and really there is not that much. The hard stuff is pretty much done. If I had fans I could darn near have it flying in a couple weeks, a month at most..
Main items to do yet is mount the vertical stab, install horizontal stab stuff, mount the fans, build a balancer,( I don't think I can put my fingers under this one) hack out a temporary foam canopy. A couple days of going over stuff, and taking care of the little things .. pre flight inspection..Go fly..
Old Mar 29, 2012, 08:54 PM
Endlesslag is online now
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
Joined Jan 2011
Sounds great! Painting it before maiden or not?
Endlesslag is online now Find More Posts by Endlesslag
Old Mar 29, 2012, 09:05 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Well it depends on fans. I f eveything is done and still no fans..then into the paint shop it goes.
Old Mar 29, 2012, 09:18 PM
Endlesslag's Avatar
Joined Jan 2011
Sounds great! this thing has made it so far from a few chunks of foam...wow
Old Mar 30, 2012, 07:46 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Hotchkiss
Joined Oct 2006
Looks good. I'll be watching...........
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Apr 02, 2012, 10:13 AM
Backwall is offline
Find More Posts by Backwall
Racquetball Lives!
Backwall's Avatar
United States, AL, Prattville
Joined Jul 2010
Ground testing
After all is said and done, maybe you should build a wind tunnel before maiden! Or you might attach it to the roof of your F-150 and get up to about 120mph and see if the truck's front wheels lift off the ground. Make sure you have an emergency release for the T-38. You wouldn't want it to be smashed when you roll the truck!
Dave
Backwall is offline Find More Posts by Backwall
Old Apr 03, 2012, 07:19 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
That's one spicy meatball
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
