Espritmodel.com Heli Air
Old Jan 14, 2012, 10:51 AM
Capt. Z
falcon5's Avatar
Tonopah, Nevada
Joined Dec 2004
Originally Posted by alexandermh View Post
Question for you "foam masters." When I glue foam box sections together (like you have), and then round the corners, I have a ridge of whatever glue I'm using (hot glue, epoxy, or whatever) which runs right down my nicely rounded corner. How are you getting rid of that problem? Thanks. Mark
Hi Mark,
This is my second major scratch build so I am still kind of a noob on much of the technical stuff and maybe the more experienced guys can pipe up on this one but I try and use the softest glue I can when I know it's going to be sanded like in a corner. The 3M-77 I used for this project is very soft and sands real good. Uhu Por is another good glue that sands well. I think the ridge comes from the soft foam is sanded away easily but the hard glue is more resistant to sanding so the ridge forms.
falcon5 is offline Find More Posts by falcon5
Old Jan 14, 2012, 11:53 AM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Mark, also what works really well is elmers rubber cement. Comes in a jar with an attached brush, you can get it at wally for like $1.60 in the craft section(Elmers also makes a more expensive type for pictures for like a $1 more, but the original works real good). Brush on both surfaces, let dry(about a min) put together, make sure your lined up, works like contact cement so no adjusting when you put them together.. and the bonus is it sands like it isn't even there!!! Give it a try! Good luck! w.
Waltjg is offline Find More Posts by Waltjg
Old Jan 15, 2012, 01:24 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sorry guys.....no progress today other than cutting my fuses' in half. ended up spending 4 hours fixing my sister in laws car because some dip s$%^ put locktite on her oil drain plug...had to drill it out....that was fun...then, got roped into helping my wife paint the inside of the house for the last 4 hours. grrrrrrrr.....
corsair nut is offline Find More Posts by corsair nut
Old Jan 15, 2012, 02:38 AM
skyracer068's Avatar
Henderson, NV
Joined Jan 2006
Welcome to the real world. "Should of taken the blue pill......."
skyracer068 is offline Find More Posts by skyracer068
Old Jan 15, 2012, 04:26 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Jan 15, 2012, 07:09 AM
Ham Call Sign: KK4KGJ
Buzz Bomb's Avatar
United States, GA, Stone Mountain
Joined May 2006
hehe
Buzz Bomb is offline Find More Posts by Buzz Bomb
Old Jan 15, 2012, 08:46 AM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Ok,,, so you had last night, and ALLLL day today! Let's see some headway and some pics by the eod today! w.
Old Jan 15, 2012, 10:18 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
nope...church now and i have to go into work tonight....
Old Jan 16, 2012, 05:40 AM
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
"I think the ridge comes from the soft foam is sanded away easily but the hard glue is more resistant to sanding so the ridge forms."
That's the problem. Thanks guys. I'll try some of your suggestions. For the projects already underway with a hard epoxy ridge, I think I'll use my dremel grinder and take it out and just spackle for shape. Now back to our regularly scheduled program. :-)
alexandermh is offline Find More Posts by alexandermh
Old Jan 16, 2012, 07:03 AM
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
alexander,
you can also use a fresh new razorblade and cut the ridge off and use a little spackle to get the shape back to what you like..Since you have already glued this might help to fix the proflem and try something different for next round like the glue Walt suggested....
Take care............................Chris
Hover or die is offline Find More Posts by Hover or die
Old Jan 17, 2012, 12:23 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
found 2" thick sheet of pink foam today for wing cores. with any luck well habe cores in a week or so......
Old Jan 17, 2012, 12:53 AM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
CN, is that foam Owens-Corning Foamular? The 150 or 250? The 2" now is 23.88 for a 2"x4'x8' . When I bought mine it was only 18.00. What's the going rate down your way?
We have it avaliable all year long, they use it a lot for insulating basements up here. I used the 3M 78, and it works well, but a definate hard ridge on the glue joint. Great build. Will stay tuned.
CoolerByTheLake is online now Find More Posts by CoolerByTheLake
Old Jan 17, 2012, 06:59 AM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Ok you guys,,,, where are the pics?? and the progress reports?? we're waiting here... w.
Old Jan 17, 2012, 10:48 AM
Capt. Z
falcon5's Avatar
Tonopah, Nevada
Joined Dec 2004
Well allot of plotting and planning done this weekend with a small amount of building. Got the gear door bays cut and made the doors. Also got the wing tube position plotted and drilled with all the ply parts made to support the tubes. All the nose gear mounting ply parts also made. Waiting on struts to get here before I do a final nose gear mount then I can start servoing up the doors.
Yeah Like Brent said anyone wanting to fly flight simulator with us it is soooo addicting. They have come such a long way with the flight sims these days that with a few add ons they are pretty realistic.
Last night we did a simulated engine failer in a T-33 in formation with strong cross winds and bad weather and after we landed I had a little white knuckles going on.
Old Jan 17, 2012, 11:06 AM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Understatement.
AceMigKiller is offline Find More Posts by AceMigKiller
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox Video Piloting (FPV/RPV) 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
