Old Oct 08, 2012, 07:17 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
thanks! ok...all batteries soldered...escs hooked up. adjusted escs test ran motors on 8s then installed the fans and ran them both on 12s without tail pipes so i could check motor yemps. i also left the escs uninstalled and i ran it up with the model on the stand so i really couldnt feel the thrust but it sounded awesome and there was lots of air blowing out. judging by the temps of the escs id say its pulling around 100~110a or about 10kw total. the escs are now installed with heat sinks in ducts. they are pretty far fwd of the fans so they shouldnt hurt thrust much. they will stay nice and cool in there. so next ill put tail pipes in and maybe test once more. the motors got warm but probably not over 130 deg or so. pretty safe. up next after tail pipesare the wing mounts and then figure out battery placement for cg. also.....i weighed it. lools like ill be right around 42-43 lbs. thank goodness its not more lol
corsair nut is offline Find More Posts by corsair nut
Old Oct 08, 2012, 08:54 PM
tehachapi, CA
Joined Jan 2006
installed tail pipes. did a test run. holy crap thats a ton of thrust! it might fly lol. i did pick up the fuse with the packs in it and i almost threw a muscle lol. so i need to install the wing mounts and my servo for gear valve. thats the majority of the work left.
Old Oct 08, 2012, 09:43 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I`m logged back in now and I`m looking forward to reading/seeing your fun in Vegas.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Oct 08, 2012, 10:20 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
good news i was worried about those 4-5 ft long tail pipes. maybe we should do the madien on the lake bed at edwards wed ?...either that or just go for it at vegas,it's a big gamble due to no over run if you have to abort,but it is vegas .....make sure those wing hold down are bonded good ....i guess im just a worry wart
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 08, 2012, 10:28 PM
tehachapi, CA
Joined Jan 2006
if i took it anywhere it would be buttonwillow...hmm....thats a good idea......
Old Oct 08, 2012, 10:34 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i think it is closed ...or it was kast week ,buttonwillow would be good ...but would take half the day .the lake bed would take a couple of hours,maybe talk to the glider port they have a paved strip.
Old Oct 08, 2012, 11:10 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i believe the shedule at BW does not allow flying on mon ,tues ,weds. you'd have to call the pres to get permission. you should have gott'n a E-mail for the month of oct flying days.
Old Oct 09, 2012, 12:27 AM
tehachapi, CA
Joined Jan 2006
ill just wait eh. it will be fine
checked cg, packs ended up beeing cuple inches farther forward than i thought, no biggie. my esc wires still reach, and i wont ahve to add any glass to the battery area.
your right andy, i had to get under my holding stand and bench press it to get the cg haha. thats a first.
got retract servo hooked up and installed. got wing mounts glued in, but still need to "wet tie" them into the structure. once ive got that done, i need to get the batteries velcroed up, and get a strap in there. after that, ill hook everything up, and do a full systems check. my gear have a leak when they are up, but it holds enough pressure to drop the gear for about 20-30 min. so no biggie. ive got 2 tanks in there, so it will be fine. though i may be required to roll inverted to retract gear. it retracts them at about 120psi ok, but not with enough power that i feel they will work in airflow. inverted will fix that in a jiffy lol. its hoaky, but you got to do what you got to do sometimes.
its getting close, and to be honest, i never thought id ever finish it haha. im feeling a little better after my full power test, it felt pretty awesome. never felt 26-27 lbs of thrust before!!! im also glad im not going to be over 43lbs. we already know andy's flies sweet at 43-44lbs. now we just need to be able to land and stop on a 700ft runway. i wouldnt be too worried if it wasnt for the poles and chains at the ends of the runway. yikes!
Old Oct 09, 2012, 12:42 AM
tehachapi, CA
Joined Jan 2006
so i went back and watched all of the flights again. im feeling better! the 7500w first flight takeoff wasnt that long at all, and i have to remember that Z's alt is way up there, and that realy hurts! especially takeoff and landing speeds. also, after watching all of Z's landings, they all seemed to be at almost the exact same AOA, which was pretty flat, and i know Z-man isnt using much flaps yet. that coupled with a aoa of another 3-4 deg on touchdown, and i think it will be going pretty slow! the good thing about T-38's is they arnt going to tip stall, just mush, so if i get it too slow, and it starts sinking, just add power sound seasy right! haha. man, im pumped. i cant wait!! on andys video #4, you can make out a wicked cool takeoff where he rides the mains for 50 ft or so before liftoff....oooh yeah! gangsta!
Old Oct 09, 2012, 03:21 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
man you sure got a lot done ,we might get it loaded by sundown ,and get a good nights sleep nah we will be fixing somthing i just need a few paint details and silicon the smoke generators on .and solder some bullets on my new batts.
Old Oct 09, 2012, 06:17 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Great speed building CN! WOW
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 09, 2012, 08:20 AM
tehachapi, CA
Joined Jan 2006
thanks kev! it wouldnt have been possible without columbus day, and a understanding wife! lol
Old Oct 09, 2012, 09:49 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Cool Brent sounds like your well on the way to an on time wheels in the well maiden of Thursday afternoon.
Yeah we sure do have some understanding better half's.
Two of Charlottes friends both aeronautical engineers are making a special trip up from L.A. to see the T-38's. I asked oh so they will be in town that weekend and want to stop by the field ? the answer was NO, they are driving up to see the T-38's. They have hotel rooms and everything.
Have a good trip gentelman..see ya Friday.
Bring a light jacket, temps show a high of 64 and a low of 43 Friday and 69/44 on Sat.
We will have density alt on our side for sure
falcon5 is offline Find More Posts by falcon5
Old Oct 09, 2012, 01:21 PM
tehachapi, CA
Joined Jan 2006
man, i checked the weather, and its looking great!!!!! sweeet!
slight snafu! i was only planning on working today, and having the afternoon to work on the talon. sadly work has taken me out of town, and i wont be back until tomorrow morning....grrrrrr......looks like a tradtitional late wed night before vegas is in order.
Old Oct 09, 2012, 02:45 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
That right there is one of the keys to life. Good luck with the flight guys!
scatsob is offline Find More Posts by scatsob
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
