Old Aug 14, 2012, 10:16 PM
mwoneal is offline
Find More Posts by mwoneal
United States, CO, Denver
Joined Apr 2012
Found this thread over the weekend, read through all 140+ pages, simply fantastic model you've built! I just got into rc planes this year, and have started experimenting with building simple prop planes from blue and pink core foam. Was wondering how you cut your foam, I've been using a box cutter with fresh blade, but it seems to catch and tear little bits out along the seam every so often.
mwoneal is offline Find More Posts by mwoneal
Old Aug 14, 2012, 10:24 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Use an xacto knife and change the blades frequently. Otherwise, you could use a hotwire setup.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Aug 14, 2012, 10:28 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Orange plastic box cutter from 99 cent store works well . Don't just drag the blade thru the foam try to make a slicing motion. Change the blade often with 9mm break off blades from Home Depot and for goodness sakes don't get your flesh in the way.
alpea 41 is offline Find More Posts by alpea 41
Old Aug 14, 2012, 10:51 PM
mwoneal is offline
Joined Apr 2012
Thanks, I will try out these methods on some scrap foam.
Old Aug 14, 2012, 10:59 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Originally Posted by mwoneal View Post
Found this thread over the weekend, read through all 140+ pages, simply fantastic model you've built! I. Was wondering how you cut your foam, I've been using a box cutter with fresh blade, but it seems to catch and tear little bits out along the seam every so often.
Hi mwoneal,
Welcome to the T-38 thread and welcome to R/C airplanes. Wow, you read through all 140+ pages..pretty cool!!
Due to the 1" thick foam used in this T-38 build I used the X-acto #5 blade for cutting out most of the parts. To make a cut I would use a streight edge and take my time and the first cut only goes about half way through, then the next cut a little further and by the third pass I would usualy be all the way through and have a clean cut.
Thinner foam say 1/2" thick may only take one or two strokes.
Welcome aboard.
Andy
falcon5 is offline Find More Posts by falcon5
Old Aug 15, 2012, 08:30 AM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
Originally Posted by falcon5 View Post
Hi mwoneal,
Welcome aboard.
Andy
A true surgeons tools
Reco is offline Find More Posts by Reco
Old Aug 15, 2012, 09:48 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I haven't put in a new xacto blade in a couple of years now! I keep a stone on the bench, a few licks across it, and better than new, yes, sharper than a new blade! and yes I have a whole box of blades up on the shelf somewhere! Another trick learned right here on RCG!!!! w.
Waltjg is offline Find More Posts by Waltjg
Old Aug 15, 2012, 11:38 AM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Well there ya go,, cool tip Walt.
Gona head on over to the post office and see if those clear plastic thingy's are there yet.. should be gettin' close
Old Aug 15, 2012, 01:15 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
oh man, i hope you post pics when you get them!
corsair nut is online now Find More Posts by corsair nut
Old Aug 15, 2012, 01:52 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Will do...my middle name is Paparazzi...
No yellow card today..I saw the big mail truck leaving the post office as I was driving up. If it is on that truck by the time they sort and put the cards in the boxes I won't know til tomorrow.
Old Aug 15, 2012, 08:40 PM
mwoneal is offline
Joined Apr 2012
Andy,
Thanks for sharing, appreciate the information. That is a big X-acto blade. Great job again on the jet.
Mark
Old Aug 16, 2012, 11:16 AM
tehachapi, CA
Joined Jan 2006
a little update, wing spars made (43"x1.2"x1/8") carbon fiber spars, 2 for wing, 1 in vertical that runs down and connects with stab spar. wings are glued together, and belly pan glued on. just about ready to glass belly pan, and start final body work on the wing/belly pan. i also installed the nose gear mount, and used 2 layers of 6oz C/F cloth on the inside of the wing sadle area. pretty damned strong. i also made the rudder mech to operate it from a servo inside. still need to install it though. man, i tell ya what, when you stand this wing up on end, its way taller than me. and im 6-2! crazy stuff! i need to weigh everything today to see where im at. i think i can hit 30 lbs if i dont get crazy on paint and glass work...... if i hit 30 lbs, this thing will be a serious leaf! lol.
andy, those canopies should be there today i rekon!
Old Aug 16, 2012, 01:33 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Great update!!!...yea if you hit 30 pounds she sure will be a floater on landing..good work!!
Old Aug 16, 2012, 01:45 PM
tehachapi, CA
Joined Jan 2006
no canopies yet?
Old Aug 16, 2012, 04:28 PM
tehachapi, CA
Joined Jan 2006
so, some good news, i weighed what i have so far. the wings/stabs/vertical all all glassed, and most of the structure is in the airplane so far. i also weighed the retracts with struts. so far im up to 12.6lbs. thats not too bad, since my power system (fans/esc's/motors/batts) is about 12 lbs. so to hit 30 i have to keep the rest of the airframe and servos down to 5.4lbs. i figure ive got 1.40 lbs of servos/rx. that leaves me with 4lbs for glass on fuse/light coat of primer and paint, and the cockpit. thats pushing it, but i feel i can keep it under 32lbs for sure. i think 32lbs is the max weight at which ill still maintain good performance given the power setup. and thats 10 lbs less than andy's so we already know how sweet his flies, even at 42 lbs. that leaves me pretty stoked, but also lets me know i cant get crazy with fuse glassing and paint if i want to hit the mark.
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
