Old Jan 05, 2012, 07:43 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Very nice
Your cockpit detailing is already looking so nice it would be a shame not to open it up to show off your work
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Jan 06, 2012, 01:57 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
they always taxie the real one with the canopies open ...not sure they have good airconditioners for ground duties.there is a lot of lift on the canopies so they need to lock down real good.
Originally Posted by J Morgan View Post
"Ail, Elev, Rud, Retracts, Flaps, gear doors, not sure on speed brake, but toying with the idea of a manualy opening canopy. I think It would look cool sitting there with both canopys open."
And it would keep the cockpit from overheating on hot days, always a problem.
J
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 06, 2012, 05:29 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Yep, a canopy that popped open in flight and didn't detach would be a nightmare.
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 06, 2012, 07:32 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
One way of getting a light coat of glass or epoxy over the cloth is to blot it with a paper towel to absorb all the excess liquid...just a thought..I've done tons of boat and surfboard glassing over the years and this is a good way to keep it from pooling in areas..
Hover or die is offline Find More Posts by Hover or die
Old Jan 06, 2012, 09:19 AM
flyingfitz737 is offline
Find More Posts by flyingfitz737
United States, IL, Edwardsville
Joined Dec 2011
I have had success with unrolling bathroom tissue over the wetted glass cloth under a little pressure to soak up excess resin. Give it a few seconds to absorb then carefully pull it off. You are left with a nice even layer of glass with no excess.
Another way I have heard of but not tried is to determine the amount of resin required by weight. Weigh the cloth. The weight of resin to use is around 40% of the total weight of cloth plus resin. The theory goes that if you spread all this resin over the area of the cloth it should soak/wet evenly and correctly. Let me know if it works if you try it!
flyingfitz737 is offline Find More Posts by flyingfitz737
Old Jan 06, 2012, 10:17 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Good info, thanks guys. All my glassing stuff should be here next week. I think I have a good design for the canopy lock down, I will work on building the opening canopy frame this weekend.
Thanks again for all the GREAT info..
falcon5 is offline Find More Posts by falcon5
Old Jan 06, 2012, 11:30 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by flyingfitz737 View Post
I have had success with unrolling bathroom tissue over the wetted glass cloth under a little pressure to soak up excess resin. Give it a few seconds to absorb then carefully pull it off. You are left with a nice even layer of glass with no excess...
Thx! This is worth a try, I've seen some nice lightweight glassing work over foam and it looks incredible...tap resistant, hard shelled and light.
erh7771 is online now Find More Posts by erh7771
Old Jan 06, 2012, 11:33 AM
wilmracer is offline
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
I've done similar using a whole roll of paper towels. Think of it like using a lint roller to gently pick up the excess resin. When the outside layer of the paper towel roll is wet pull it off and continue.
wilmracer is offline Find More Posts by wilmracer
Old Jan 06, 2012, 12:40 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Hummm,,, not sure where all this picking up too much epoxy came from but while your brushing it on, just don't put too much on, then you won't have to worry about picking it up... JMHO.. w.
Waltjg is offline Find More Posts by Waltjg
Old Jan 06, 2012, 03:41 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
had to reglue a couple seams in the coke bottle section with gorilla glue today...set it out in the sun to dry..went back in the garage to work on a sabre....kids playing...walk around the corner...one of my sons is poking tons of holes in the bottom with a stick...ahh the joys of parenthood.
corsair nut is offline Find More Posts by corsair nut
Old Jan 06, 2012, 03:52 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
J
Old Jan 06, 2012, 03:53 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
I was using spackle yesterday and thought:
Ahhh spackle my good friend, you are there for me when I bump my foam airplane against the wall as I move it from place to place, When the file slips out of my hand and mashes a gash in my creation, when the screw driver slips off the screw head and pokes a hole in the work I just spent 6 hours shaping Ahhh spackle my good friend where would I be without you. I propose a toast, what ever drink is your hand raise it high to our good friend...spackle
Also good for kids poking holes in dads plane.
Old Jan 06, 2012, 04:04 PM
tehachapi, CA
Joined Jan 2006
waka waka waka!
Old Jan 06, 2012, 06:07 PM
skyracer068 is offline
Find More Posts by skyracer068
skyracer068's Avatar
United States, CA, Sacramento
Joined Jan 2006
Absolutely amazing!!! You guys have definately "raised the bar" with EDF's in this unique build. Now I know why mom likes you more there bro! Are these monsters going to be ready for Superfly? I know how thin the original T-38 wing is and was wondering what retract you were going to use that would fit.
Well, I'm very impressed and can't wait to see it.
skyracer068 is offline Find More Posts by skyracer068
Old Jan 06, 2012, 06:13 PM
tehachapi, CA
Joined Jan 2006
thanks man! yyeah im hoping to be done by summertime.
going to try and keep the wing as thin as possible...i havnt nailed down the retracts yet...
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
