interest in a kit??????
![]() Quote:
Bob's kit is first rate and fits the bill for either power system but it does have a steep price in comparison to what Fahim can do with his CNC foam. My A10 kit from Fahim is a perfect example of this in that a fully molded plane from Chris Graham of similar size is as much as a small turbine and well worth the cost. Having a less expensive alternative but with some work added in on the customer side can be a big savings. After all this is a Hobby!!!!!! So, what interest could there be for a LARGER than 70mm single type airframe?? An airframe that can be easliy converted to many variants in the T-38/F-5 family ![]() Out of respect for Andy's build i started another thread in the Foam EDF forum here http://www.rcgroups.com/forums/showt...8#post21901212 Feedback and interest being shown!!!!!! check it out! 6-15-12 sw |
i finnaly got to watchthe video, man, it accelerated much better than the first couple tries! just cruizes around great! it looks to have a great presence in the air, and not far off the scale speed you would see one flying at in the pattern. that landing could be really slowed down, especially with flaps on the next try. man, what a beauty! all this exitement really got me cooked up on my build. this week i cut out all my control surfaces on wings and rudder, capped all of them with balsa, and shaped the balsa on the hinge area. adding the 1/2 balsa to the hinge line on the wing really stiffened it up. my whole way of building this has changed big time as far as how much beef im adding to the structure after seeing andy's fly. i really think i can hit 30 lbs with mine if i really watch the build, and ill have 9kw as well. should do well.
andy's upgrades in power and a few other things we talked about over the phone should really help andy's wake up on the performance side. andy, how many mah did you put back after the flight? |
Hi Wingman, Great progress report and keep us posted on your build. Great talk on the changes to make and glad you got a chance to see the vid. Retracts shipped yesterday and the new batts shipped today. I can't wait to fly her again!!! After landing the cells were 3.85 volts per cell on 8000mah packs and I left hem there seeing they were right at storage voltage, but from the other test runs and taxi test and such I did when they were at 3.8 volts per cell it took 4400 mah to get them to full charge for a ball park estimate. The flight was done with the throttle from 3/4 to full the whole flight. Can you imagine two of these cruzing around in formation. Mine is soooo stable and solid in flight it should make a great formation bird. Man if you hit 30 pounds as an AUW that would be Sweeeet!!! On a windy day you will have to add balast so it dosn't blow away....kidding
yeah your laps were @ one min.
you were way out there. did you see my post about nomex felt,if you lined the inside of your fuse with that and paint some of that ceramic that bvm sells that should take care of your heat issues. goggle nomex felt see if you can find some . we use a cerammic at work that looks just like the bvm stuff.he just sells it in a smaller bottle.
A type of welding blanket or soldering blanket would potentially work to shield the foam from heat.
I have used them when using an open flame during soldering and it is amazing how they prevent heat transfer. I believe a lot of the blankets are ceramic based.. http://www.ebay.com/itm/Flame-Protec...item1e6f21b17e |
Yeah first flight I took it real easy and was very gental with it so the laps were kind of wide. Not knowing how the bird would handel and knowing I was under powered I was makeing very shallow turns until I got a feel for her. It won't be the normal flight pattern on future flights. |
It looks good, Andy. I wouldn't put a Kerosene burner in there if I were you. It would defeat the whole purpose. The cool part is, with enough power, the bird will perform. It sounds amazingly authentic on electric and you don't need a waiver or a type rating to fly it. That is the coolest part about it.
Randy |
My 2C on the turbine issue - turbines = meh.
![]() Don't get me wrong - nothing like the scale sound of a turbine, but they often seem to be just a "big hammer" approach in some instances. Now a guy that can scratch out a BIG jet with conventional EDF's (out of foam no less) that sounds sweet and fly's good - that guy gets my respect all the time every time. Turbines just need money - yours needed finesse! (although a foamy turbine is a BIG challenge....)
![]() By the way what was the sound difference once you added the fan ducting walls / separator duct? |
Latest blog entry: The Gas Turbine Engine (with images)
| Thread Tools | |
| Cool Micro F-5/T-38 Parkflyer Build | boingk | Pusher Prop Jet Models | 2 | Oct 17, 2011 09:58 PM |
| Discussion I knew it wouldn't be long!!!!!!! | Flightbox | Video Piloting (FPV/RPV) | 8 | Sep 29, 2011 05:17 PM |
| New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal | BIG TANKS PLANT | RC Tanks | 0 | Sep 28, 2011 02:38 PM |
| Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 | ScaleBrad | Aircraft - Electric - Airplanes (FS/W) | 15 | Jan 02, 2008 01:22 PM |
