Old Jun 12, 2012, 01:02 PM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
Originally Posted by jofro View Post
I was working out your 18 pounds AUW at 4000watts, which gives you some 220watts per pound. You didn't say anything about your "supposed" 12lb thrust, which is all subject to your inlets, outlets and other factors. Did you test your thrust? If you get 1320g/Kw you are laughing. I find the easiest way to check my real thrust, by holding the model in vertical position with exhaust 4-5 feet above the ground or higher and get someone to advance full power. If she hovers I'm happy chap. My 17kg "Triptych" pulled out of hover between 3/4 to full stick, meaning it must pull over 18kg. 10.5kg "Panther" almost but not quite hangs there on 9300watts at some 200 amp draw with 127mm fan. So both models produce some 400w/lb. With your 18pound Hornet it shouldn't be any problem to do vertical test to see what she really pulls. But then again, there is static and dynamic thrust and to get best of both takes some experimenting, Joe.
Along the same line as Joe here, I have always wondered if hanging the model from the tail attached to a digital fish scale and having full throttle brought up then taking the thrust from the reading would work? If I ever tried this I would probably use saddle straps around the wings to hold it up. Just a thought..
Reco is offline Find More Posts by Reco
Old Jun 12, 2012, 01:10 PM
JurassicJet is offline
Find More Posts by JurassicJet
JurassicJet's Avatar
United States, WI, Chetek
Joined Jul 2011
Hanging an aircraft from the tail and running it full power would be a really bad idea. If the aircraft weighed 35 lbs and you added 25 lbs of thrust you are talking 60 lbs of stress on the aft fuselage and empenage area.
Better to put I nice thick strap around it while sitting on the ground and use a fish scale for a static thrust reading. even a strap around the leading edge of the wings would be better IMHO.
JurassicJet is offline Find More Posts by JurassicJet
Old Jun 12, 2012, 03:36 PM
buzzfly is online now
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
To check the thrust in turbine model aircraft, I know of guys who placed a bathroom scale against a wall (or other immoveable surface), placed the nose of the aircraft against the plenum of the scale with the aircraft on its wheels on the ground, and ramped it up to full power.
Assuming that the nose of your T-38 is stout enough, this would be an easy way to determine the static thrust.
-- Mark
buzzfly is online now Find More Posts by buzzfly
Old Jun 12, 2012, 03:53 PM
Reco is offline
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
True if you hung it from the tail, I was talking about using straps around the wings. I think the wings could hold that weight. Using the ground method would suffer from the drag of the wheels.
Old Jun 12, 2012, 04:12 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I'm sure this is a great idea, but don't forget this is 12 feet long!! He may have to rent some hanger space to do it. How many of us have a 15-16 ft ceiling you could hang it from. Then there is reading the scale!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 12, 2012, 04:26 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
CONGRATS ON THE MAIDEN! Looks like it flies like a pussycat!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jun 12, 2012, 04:32 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Well I took the day off from work today and guess were I went...yep back out to the lake bed. I flew the T-38 and she fly's beautifully. Yeah a bit under powered as we expected but that can be fixed. I will give a detailed flight report a little later but for now enjoy the video..My only request is you crank up the volume to neighbor busting levels on the two low passes...man those two Stu fans and that big airframe sound SWEET!!!
My retracts are not up to the challenge of a 40 pound plane rated for only 20 pounds and it showed. Nose motor not strong enough to retract the gear against the head wind, Right main only retracted 3/4 of the way up. I cut the flight short seeing this and worked on getting the gear back down. Mains came down nose gear only 3/4 of the way down due to a striped jack screw but did not fold on landing. Phew!!
I am going to invest in a real nice set of retracts for the jet that are properly rated for 40 pound planes,
Quick run down:
Fly's like it's on rails, a real SWEET flying airplane!!!
Aerodynamically the airframe absolutely does not care it weighs 40 pounds and from how it handles I would guess it wouldn't care if it weighed 50 pounds as long as it had the proper power plant.
Lands like a feather.
T-38 maiden1.wmv (4 min 25 sec)
falcon5 is offline Find More Posts by falcon5
Old Jun 12, 2012, 04:42 PM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľký Krtíš
Joined Dec 2006
Flying beauty...congratulation...I especially like smooth landing...It fliees like a glider
pajlotmato is offline Find More Posts by pajlotmato
Old Jun 12, 2012, 04:43 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Quick run down:
http://www.youtube.com/watch?v=WBF_Pf2uGFQ
Freakin AWESOME!!!!!
I've been following since the beginning, and this made my day! Keep it up! MOAR POWAH! And now that it flies, get a film crew with a really nice camera out there to capture it in it's full glory
Endlesslag is offline Find More Posts by Endlesslag
Old Jun 12, 2012, 04:47 PM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Absolutely bloody fabulous mate ,well done glad I stayed around to see the end result. Power is not my normal outlet but this was something special. Excellent ,ok what next then ?
Cheers
SteveW
steve wenban is online now Find More Posts by steve wenban
Old Jun 12, 2012, 04:49 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Congrats!
Keenan smith is offline Find More Posts by Keenan smith
Old Jun 12, 2012, 04:53 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Great flight and so so well deserved...We are all sorry for working your nerves over the last few days Andy..
I bet the after beer was especially good!!!
Take care and tell me........What's next.....lol.....
Hover or die is offline Find More Posts by Hover or die
Old Jun 12, 2012, 04:55 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Way to go falcon! Congrats!
jetcaptain is offline Find More Posts by jetcaptain
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Yeehaa!! Nice one Falcon. So great to see it in the air. Congratulations. Was that on 10s?
aerophilia is offline Find More Posts by aerophilia
Old Jun 12, 2012, 04:59 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
curse you youtube work filter block!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
awesome andy!!! how did the cg feel?
you should have rolled it over and retracted them lol. thats what i do when they arnt strong enough.
i have to wait for friday to see the video now...you suck lol!!!
i guess my home brew airfoil works after all haha.
we need a in depth report wingman
corsair nut is offline Find More Posts by corsair nut
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 10:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 06:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 03:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 02:22 PM
