Joined Jan 2010
I only wish best of luck to "Falcon" with his model, that I find very in-efficient with the figures he showed so far. I would still like to know how much it actually pulls statically on the ground while being hooked to the digital scale. I'm aware it could fly nicely at 130m/h but you have to reach that speed first, Joe. |
Joined Nov 2005
The full sized T-38 was a dog, they even did some variable AOA with it for take off like the A-4 and that's with more powerful engines. SOMEHOW the thing did mach 1.5 but wasn't a good turner because of lower power to weight. IIRC thrust was around .55 to 1 ! |
Joined Jan 2010
I was working out your 18 pounds AUW at 4000watts, which gives you some 220watts per pound. You didn't say anything about your "supposed" 12lb thrust, which is all subject to your inlets, outlets and other factors. Did you test your thrust? If you get 1320g/Kw you are laughing. I find the easiest way to check my real thrust, by holding the model in vertical position with exhaust 4-5 feet above the ground or higher and get someone to advance full power. If she hovers I'm happy chap. My 17kg "Triptych" pulled out of hover between 3/4 to full stick, meaning it must pull over 18kg. 10.5kg "Panther" almost but not quite hangs there on 9300watts at some 200 amp draw with 127mm fan. So both models produce some 400w/lb. With your 18pound Hornet it shouldn't be any problem to do vertical test to see what she really pulls. But then again, there is static and dynamic thrust and to get best of both takes some experimenting, Joe.
Thanks jofro. You were talking about 220w/lb and not 220g/lb. that's where I lost you... None of my EDFs ever hovered, as I never had one with 1:1 thrust to weight... At the same time, the ratio I have is typically 0.66 to 0.8 and I'm happy with the scale flying. Haven't checked static thrust yet. Working on the inlet to fan tube now...
| Thread Tools | |
| Cool Micro F-5/T-38 Parkflyer Build | boingk | Pusher Prop Jet Models | 2 | Oct 17, 2011 09:58 PM |
| Discussion I knew it wouldn't be long!!!!!!! | Flightbox | Video Piloting (FPV/RPV) | 8 | Sep 29, 2011 05:17 PM |
| New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal | BIG TANKS PLANT | RC Tanks | 0 | Sep 28, 2011 02:38 PM |
| Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 | ScaleBrad | Aircraft - Electric - Airplanes (FS/W) | 15 | Jan 02, 2008 01:22 PM |
