Old Jun 10, 2012, 09:43 PM
amtpdb is offline
Find More Posts by amtpdb
amtpdb's Avatar
Fontana,Ca.
Joined Aug 2005
Isn't there some way to check for a vacuum inside the inlet at full power? We used to check the inches of water vacuum on a supercharger with a tube fastened to the inlet and draped down and then back up with water partially in it. Start the turbines and measure the difference in the height of the water on each side. At least you could be sure if the turbines are getting 100% of what they need.
Just a thought.
amtpdb is offline Find More Posts by amtpdb
Old Jun 10, 2012, 09:51 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
After conferring with the engineering department Corsair Nut and R/C groups I made a few changes to the plane and will take her out in the morning for some more test runs. I put a 1 1/2" square cheater hole in front of each fan. Increased the exhaust diameter to 80mm from 76.
Tomorrows runs will be at the bigger lake bed so I will have more room than the one in the vid.
Plan is to see how she accelerates, if she looks better than today and with a little back pressure she rotates freely I will let her go and attempt flight. I won't force her into the air though as I feel that would be asking for trouble. If she rotates with gental back preasure it's a go..if not i will abort.
falcon5 is offline Find More Posts by falcon5
Old Jun 10, 2012, 09:55 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Looks good rolling along in the sunshine. If the nose doesn't lift with half of your elevator thro shut down and let it roll out to a stop when you are on your take off roll. I posted as you were saying the same thing lol
alpea 41 is offline Find More Posts by alpea 41
Old Jun 10, 2012, 10:01 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
I was working with a twin jet this weekend and couldn't believe how low the thrust was, less than half bench numbers after rigging up a scale
Opened thrust tubes to 90% FSA and it takes off at 3/4 throttle now and flys like bat outtah hell...I prolly got FSA numbers all wrong on that one..
erh7771 is online now Find More Posts by erh7771
Old Jun 10, 2012, 10:13 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
I wish you the best Falcon! Good luck tomorrow.
jetcaptain is offline Find More Posts by jetcaptain
Old Jun 10, 2012, 10:19 PM
A10pilot is online now
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Andy:
Best of luck.
Ed
A10pilot is online now Find More Posts by A10pilot
Old Jun 10, 2012, 10:22 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
do you have a wall between the inlets of the fans ? could be you need a bit of a wall to seperate them .seems to have a lot of rolling drag too
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 10, 2012, 10:43 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Delta
Joined Oct 2006
Good testing, Andy. Maybe when she gets some ram pressure, she'll open up and give you some thrust.
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Jun 11, 2012, 02:48 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Full credit to you Falcon for beautiful build but just looking at that model it is wrong contender for an EDF. With your intakes and those tiny wings being a foamy it would probably fly well if it was bellow 12kg (26lb) AUW. At 18kg take off weight I would expect minimum static pull on flat surface 13-14kg, (which I doubt you are getting) otherwise I wouldn't waste my time to atemp to fly it, because it still will be bit of a flying brick.
You are probably much better off installing 160 size turbine and keep AUW to minimum.
Sorry for being negative but trying to be realistic. Another thing I would do is to build new wings at least 50% bigger area (its only a model, who gives a "fak" about scale) and number of grills in fuse not to starve turbine of air. Joe.
jofro is offline Find More Posts by jofro
Old Jun 11, 2012, 03:06 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Turbines don't need so much air, that's what the jet fuel and fire is for, it makes the thrust not the air from the inlet. A P-160 probably has an inlet of about the same size as a single 90mm EDF, this thing has plenty of excess inlet air if he goes to a turbine.
But really let's give the man some space to make his own evaluations for the EDF. He's in the only reliable place to make a valid observation - in front of the actual airplane.
Eddie P is offline Find More Posts by Eddie P
Old Jun 11, 2012, 03:45 AM
MaHö is online now
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Keep on going Falcon!
It will fly.
My Mig 29 with twin 120 flies on 10kW @ 14kg really nice. 18kg is also a good weight.
Could you perhaps go up to 11 or 12S with your 100er Stumax?!
The 8000mAh packs can handle for sure more current.....
We always say: With turbine everyone can do it, with EDF not
Good luck with your testing.
regards Martin
MaHö is online now Find More Posts by MaHö
Old Jun 11, 2012, 07:11 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
+1 on the inlet separator wall. Without it, you are robbing each fan of efficient inlet air (like two kids fighting in the back seat for the same toy). Good luck Monday morning. Mark
alexandermh is offline Find More Posts by alexandermh
Old Jun 11, 2012, 12:06 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
should be getting a report soon! cant wait to hear how it went!
corsair nut is offline Find More Posts by corsair nut
Old Jun 11, 2012, 12:41 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Today's test went much better with the 1.5" x 2" rectangle cheater holes added. She had much more get up and go and appeared would have flown but I kept her on the ground due to what I found out with a little more testing I did with the fans prior to the high speed runs and more thurogh test after the high speed runs.
OK here are the numbers I got after the test runs with batts around 3.95V per cell after about 5 high speed runs. It would appear I need a longer spliter plate to separate the fans. Interesting indeed as one fan seems to get better with the other one running while the other fan does better alone and has worse numbers when both fans are running.
I only have a 4" splitter separating the fans, and the jet is back in the shop to get that corrected. But what has me a little baffled is there must be some interesting aerodynamics going on in there for one fan to compliment the other while degrading itself.
Fan 1
Alone= 3500W , 99A 39volts
Both = 3800W ,107A 39 Volts
Fan 2
Alone= 3300W , 93A 39 Volts
Both= 2600W 74A 39 Volts
So the high speed test in this latest video is with one fan 1000watts short on power. I feel when I get that corrected she should fly beautifly.
What I learned, First after I mounted the fans I really didn't do a thorough enough test and I just put them on the meter and took a quick look. I really should have dug a little deeper and tested things better. Live and learn.
Old Jun 11, 2012, 12:44 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Pass 3 and 4 if you look close I am able to lift the nose off the ground with about 3/4 elevator. These passes are with fan 2 running 1000Watts short so once corrected and with a grand of watts more i think she will fly
T 38 high speed run test 2 (1 min 21 sec)
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
