Old Jun 10, 2012, 06:47 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by ysolomon View Post
Yesterday I maidened a much smaller, 8lb ProJet A-10. I did what I thought were high speed taxi passes, and had the same feeling as you do now. When I finally decided to take off, it used the entire runway. I finally forced it into the air at the end of the runway. A combination of forward CG and elevator trim. Once in the air, with enough (a lot!) of trim-- and she flew beautifully, at about 2/3 throttle.
I agree that the CG could be an issue. My gut is that the jet will rotate and lift off at a much slower speed than what we are use to seeing. (The scale effect will be strong in this one ) If the CG is too far forward it just won't rotate, and without rotation it won't have the lift needed to fly. Don't forget to include the fuselage and stab areas in the CG calculations. Otherwise it will be nose heavy for sure.
PS... The video was still very cool! !
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 10, 2012, 06:54 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Originally Posted by Knife Liddle View Post
There is more EDF power available. Put a couple of 5kw JetFan 90mm`s in that baby. It`ll fly.
More like two 127mm Ramtec's for that wing loading, Joe.
jofro is offline Find More Posts by jofro
Old Jun 10, 2012, 06:55 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
More Power Baby! !
Old Jun 10, 2012, 07:15 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
theres already minimal fsa for 100 mm fans much less two 127's. i did the math because i was originally going to go with a single fan and theres barely enough fsa for one 127mm
corsair nut is offline Find More Posts by corsair nut
Old Jun 10, 2012, 07:42 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Nut:
What do you think the 100% FSA is for the Stumax 110's? What is the intake area for one of the intakes for this size T-38?
Ed
A10pilot is offline Find More Posts by A10pilot
Old Jun 10, 2012, 07:46 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Well, there ya go, huh.
Old Jun 10, 2012, 08:04 PM
tehachapi, CA
Joined Jan 2006
andy is using 100 mm stus
tehachapi, CA
Joined Jan 2006
i think thetes only about 15-16 sq in between both inlets...those are some tiny ducts
Old Jun 10, 2012, 08:28 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Just checked the StuMax 100-45. 62.64sqcm or 9.7092sqin FSA
http://www.espritmodel.com/edf-stuma...het-motor.aspx
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 10, 2012, 08:29 PM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
The force is strong with this one....
Reco is offline Find More Posts by Reco
Old Jun 10, 2012, 08:37 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
If you have the opportunity and light winds, would you be able to test your acceleration on the taxiway at TPH? Of course I'm not saying to do massive high speed runs or to try to fly it there with the narrow pavement strip. The threat is a narrow strip of pavement and rough side terrain and taxiway lights- not good for high speed runs if you get into a Tokyo Drift scenario. Acceleration only tests however may give you some insight as to weather to push for a liftoff or not on a bigger dry lake bed. If those narrow tires are adding a lot of rolling drag on the playa you'll see it right away on the taxiway.
All earlier kidding aside, I also favor a "yellow light" strategy at this point (not that I have a say on anything, just what my own experience tells me). Extend the "internal pressure" expected "fly by date" and be real methodical at this point. You have nothing to lose but a few extra days of deliberation at this point by being conservative.
Eddie P is offline Find More Posts by Eddie P
Old Jun 10, 2012, 09:03 PM
tehachapi, CA
Joined Jan 2006
andy what about those other tires you tried? they may look funny but might work better beeing wider on the lakebed
Old Jun 10, 2012, 09:04 PM
Joined Dec 2008
+1 on that. As much as all of here would love to see it fly, there's not one of us who wants it to crash either. Take the time it takes to be sure and safe.
Old Jun 10, 2012, 09:12 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Hotchkiss
Joined Oct 2006
More batteries? Hotter motors?
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Jun 10, 2012, 09:21 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
At 9.7 x 2, and I'm guessing you want inlets to be some 120-125% of the FSA. That would be 23-24 sq in. I would be nervous flying with what you have. I know that "cheater holes" sound terrible, but starving those fans is worse...
ysolomon is offline Find More Posts by ysolomon
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
