Old Jun 10, 2012, 09:33 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Very exciting stuff. No pressure Andy. Do it for youself, the way you want to do it. Then sell the video, LOL.
You could put it on private youtube, then for a donation of a couple of bucks, add the donor to the private list. Did I just say that? I`m such a DA sometimes.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jun 10, 2012, 10:06 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Good luck Andy!
Been a pretty smooth road to the finish considering this is the first of its kind and the size,,,well enough said....
One question,,where are you guys getting the tiny cams?
I'm tired of the helmet cam as its impossible to comfortably fly with that weight on my head....lol
Thanks..............Chris
Hover or die is offline Find More Posts by Hover or die
Old Jun 10, 2012, 10:47 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Thanks John, yeah looks like a nice day tomorrow,
Too funny
Here ya go Chris, I got mine on e bay. Carefull there a few much cheaper imitations out there that I hear are not as good.
http://www.ebay.com/itm/Mini-DVR-808...item2a1721820c
falcon5 is offline Find More Posts by falcon5
Old Jun 10, 2012, 12:36 PM
bd5wingnut is offline
Find More Posts by bd5wingnut
Oh wow, good Nyborg.
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
Falcon
Since you are waiting for the right conditions. Why not order up another 808 and mount it on the tail. Hell, why not go for a couple of the older (cheaper) key-chain models and have a tail and wingtip or belly cam...
These are dirt cheap now.
http://www.rcgroups.com/forums/showthread.php?t=1362692
Best of luck , Wolf
Leslie Nielsen maneuver - Airplane! (0 min 9 sec)
bd5wingnut is offline Find More Posts by bd5wingnut
Old Jun 10, 2012, 03:28 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Range check and high speed taxi test today. She doesn't look quite so massive out there on the lake bed.
Not sure if I have enough power though..I lifted the nose wheel off on one full throttle pass but not sure if it's enough to fly her safely. Uploading video of it to analyze further but my gut says marginal at best. The jet is beging for a turbine...hmmmm
Old Jun 10, 2012, 04:03 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Lack of inlet duct and/or rolling resistance may be your issue or even CG, if there is one. I would stay the course don't give up on the EDF setup yet
Beautiful work!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jun 10, 2012, 04:53 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
There is more EDF power available. Put a couple of 5kw JetFan 90mm`s in that baby. It`ll fly.
Old Jun 10, 2012, 04:55 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Three full throttle passes. Pass one is just a moderate speed steering run, pass two I stay in the throttle a bit longer.
I may still try and fly her tomorrow at the larger lake bed and give it a longer takeoff run.
T 38 taxi test (2 min 13 sec)
Old Jun 10, 2012, 05:04 PM
Joined Mar 2011
Andy,
It does seem to be dragging a little and I feel your concern...Just not as much thrust as expected from the noise generated by the fans...Seems like/it would come up to speed quicker..Do you think lack of inlet ducts could be the gremlin?
That thing does look incredible rolling by!!
Take/care.............chris
Old Jun 10, 2012, 05:05 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Falcon,
If those were full throttle passes I would have to agree with you about the lack of power. It's going to take a good distance to get to liftoff speed. Gotta love lakebeds!
pdawg is online now Find More Posts by pdawg
Old Jun 10, 2012, 05:37 PM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
^ +1 but what do I know?
mike2663 is online now Find More Posts by mike2663
Old Jun 10, 2012, 05:50 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Yesterday I maidened a much smaller, 8lb ProJet A-10. I did what I thought were high speed taxi passes, and had the same feeling as you do now. When I finally decided to take off, it used the entire runway. I finally forced it into the air at the end of the runway. A combination of forward CG and elevator trim. Once in the air, with enough (a lot!) of trim-- and she flew beautifully, at about 2/3 throttle.
ysolomon is offline Find More Posts by ysolomon
Old Jun 10, 2012, 06:00 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Looks really nice on the lake bed, Andy! Still hoping you can get it in the air tomorrow. Maybe try the trick of heating up your packs under the sun a bit?
Don't know about swapping the fan out for a turbine yet. It will of course be a great candidate for turbine. Don't know about you, but I'm quite a bit more stuborn before I give in.
Been doodling a bit with some numbers & just using bits of info on this thread, I figure your hav a good chance of taking about 3-lbs off your model; assuming you used the lay-up schedule your father posted for the wings? An 8% weight reduction can help your accel.
It shud be safe to go fly as it is, but being more anal, I wud probably do some static load testing before hand; as it will give some indication of your wings strength. A quick stress analysis will also give an idea.
Cheers,
Phil
PhilLin is offline Find More Posts by PhilLin
Old Jun 10, 2012, 06:18 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
With all of the work you have invested, don't rush it now. Step back and take another look at everything, all of the trim options, power, thrust, efflux speed .... everything. Don't let us in the peanut gallery cause you to rush the maiden.
Old Jun 10, 2012, 06:22 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Btw, I'm only assuming (didn't read the entire thread carefully)-- you have done a static thrust test, to see how many pounds you are pulling? I don't know what the magic number is, but I would probably not fly unless I had at least 2/3 of the plane weight in static thrust...
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion I knew it wouldn't be long!!!!!!! Flightbox FPV Talk 8 Sep 29, 2011 05:17 PM
New Product 1/6 HETZER JAGDPANZER 38(t) Sd.Kfz. 138/2 r/c full metal BIG TANKS PLANT RC Tanks 0 Sep 28, 2011 02:38 PM
Sold Hangar Sale E-Flite P-38 rtf, GP Fokker, WM Miss America EP, Easyglider EZ T-38 ScaleBrad Aircraft - Electric - Airplanes (FS/W) 15 Jan 02, 2008 01:22 PM
