Old Dec 20, 2011, 03:06 PM
tbroeski is offline
Find More Posts by tbroeski
Afton VA
Joined Sep 2002
Build Log
Duster mods
Here are a couple Duster modifications.
I wanted a bolt on tail for transportation.
1) Drilled and tapped then inset block using Gorilla glue. Set incidence and level with wing buy putting wax paper over block and mounting tail while it set. Came out perfect.
2) Bent control rod at 90 deg. It is held in place under tension. Must insert rod before bolting on the tail.
3) Cut vertical stab slot, lined slot with epoxy, covered tail with plastic wrap, inserted, leveled and let set. Nice and tight.
4) Made small music wire pin. Pushed though fuse and stab. Hardened area on stab around pin hole with CA. Easy to install and remove. No need for tape. Holds very well.
tbroeski is offline Find More Posts by tbroeski
Old Dec 20, 2011, 03:14 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Eat My DUSTer
Old Dec 20, 2011, 06:08 PM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
I'm pretty sure that says 'Fat my Duster'
Obviously your maid's version of 'Pimp my Ride'
mr_editor is offline Find More Posts by mr_editor
Old Dec 20, 2011, 08:50 PM
tbroeski is offline
Afton VA
Joined Sep 2002
You need to enlarge the thumbnail since the tapered letters represent twisters also
Old Dec 21, 2011, 02:19 AM
No Pants Island
Joined Feb 2007
If you have to explain it …
Old Dec 21, 2011, 02:40 AM
FSD is offline
FSD
Find More Posts by FSD
FSD
Definite Flight Risk
FSD's Avatar
United States, CA, Crestline
Joined Apr 2008
So...do you want them to "Eat Your Duster?" Or do you want them to "Eat Your Dust?"
-P
FSD is offline Find More Posts by FSD
Old Dec 21, 2011, 02:52 AM
tbroeski is offline
Afton VA
Joined Sep 2002
-P
I guess this is keeping the post going......... er
Old Dec 21, 2011, 11:05 AM
FSD is offline
FSD
FSD
FSD's Avatar
Joined Apr 2008
Sorry...It is all in good fun. At least that was the intent.
Old Dec 21, 2011, 11:46 AM
tbroeski is offline
Afton VA
Joined Sep 2002
I know. That's DUST....er
Discussion Thoughts about building a BJ-1b Duster? oopsicrashed Scale Sailplanes 21 May 05, 2012 11:08 AM
Sold Team Duster Air Tractor EDFPILOT Aircraft - Fuel - Airplanes (FS/W) 1 Dec 12, 2011 08:11 PM
F-27 Stryker - MODS MODS MODS vstrandberg Foamies (Kits) 8 Dec 30, 2009 01:20 PM
E-Dimond Duster flight report Ryan Nau Sport Planes 2 Sep 13, 2002 08:07 PM
Profile Crop Duster t-turley Parkflyers 0 Aug 08, 2001 07:26 PM
