Old Dec 20, 2011, 12:11 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Cool
BlueSkyRC Micro Spider Hex!
Qrome from BlueskyRC slipped this onto the site late last night. Hope you don't mind me making this thread Qrome! The link on the site was dead!
From Qrome first flying video!
BlueSkyRC Micro Spider HEX (3 min 5 sec)
Originally Posted by Qrome View Post
I will be starting a Micro Spider HEX thread very soon, but I wanted to share the product link here and now with the Micro Quad fans since the first run is limited.
http://www.blueskyrc.com/index.php?m...products_id=43
The kit comes with the nylon bolt package with:
16 - #4-40 x 1" bolts
16 - #4-40 nuts
4 - #4 - 1/4" riser for board mounting
Micro Spider HEX
$24.99
The Micro Spider HEX is laser cut from hand selected 1/8th plywood -- strong and light.
General Information
The Micro Spider HEX is a precision designed frame and laser cut from hand selected 1/8th plywood. Designed for 5 inch props. Strong and light.
The Mini Spider HEX is an original design by BlueSkyRC.com and is inspired by Terry Balling's Micro Quad. The frame is designed for up to 5 inch propellers, 6 - 10 amp speed controllers, and 10 - 15 gram 2000kv motors (or around that).
Standard motor mount holes are pre-drilled as are holes for mounting screws. The flight deck is pre drilled for the standard KK, MultiWii, and CopterControl flight control boards. Can easily mount any board. The frame comes with an optional halo plate that can be mounted over the flight control board.
* Kit includes plywood parts shown and the nylon bolt package containing 16 bolts, 16 nuts, and 4 riser mounts. Visit the Micro Spider HEX build thread on RCGroups.com for more building details and interact with other Micro Spider HEX flyers.
Micro Spider HEX PDF Manual.
Got my kit ordered last night!
Going to be running:
6x Park250 Motors
5x3x3 GWS Props
6x Dynam Detrum 12A ESC
Photoshipone Power Distribution
Openpilot CopterControl
And a full host of FPV gear!
Just need to add FPV gear and tune. I am looking for for a small OSD unit that will give me a GPS home arrow, distance, battery life, and the basics. Coordinates....
Love how she came out.[IMG]https://lh6.googleusercontent.com/-_...0/IMG_1578.JPG[/IMG]
Spektum Satellite Running Native through Openpilot. No receiver.... Bluetoth next to it.
Openpilot BlueskyRC Mini Spider Hexacopter with one motor out Coptercontrol (1 min 44 sec)
daign is offline Find More Posts by daign
Old Dec 20, 2011, 04:59 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
Mine is on order too. I ordered the Park 250 2200kv motors too, probably gonna be a rocket ship
AlPackin is offline Find More Posts by AlPackin
Old Dec 20, 2011, 05:20 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Are you going to do FPV with it?
Qrome is offline Find More Posts by Qrome
Old Dec 20, 2011, 06:23 PM
daign is offline
daign's Avatar
Joined Feb 2011
Same I'm super excited, and the A1510 motors are vibration machines. Out of 12 motors I have 4 that are bad!
I am for sure.
Anything smaller just lacks the lifting power or is too squirelly for FPV at this size. A Hex should resolve those issues especially with the park250s and 3s batteries. I have 850mah through 2350mah to play with. Will see what this little spider can lift!
1.2ghz 300mw, either 690tvl or 500tvl cmos depending on weight.
Inverted Vee Antenna
Eagletree OSD
Spektrum AR6115e w/ satellite
Spektrum TM1100 Fly By Telemetry
Dual Patch Antennas, Diversity, FPV-Japan DVR, Headplay Goggles
Super excited about it! I love my Blue Sky micro quad!
Old Dec 20, 2011, 06:35 PM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Looks very nice, i like it.
scousethief is online now Find More Posts by scousethief
Old Dec 20, 2011, 06:46 PM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
Great, another one to build.
TheX is offline Find More Posts by TheX
Old Dec 20, 2011, 07:44 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
That Qrome is a busy guy!
Art Newland is offline Find More Posts by Art Newland
Old Dec 20, 2011, 08:39 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
I'm hoping too.
I see in another thread that the hole spacing on the Park 250 is shown to be 22mm, that sucks. Even the 18mm of the A1510 mounting adapter was too big for the frame. Maybe I'm missing something ...
Old Dec 20, 2011, 08:43 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I'm hoping too.
If I can get the exact spacing, I can update the files for the next batch. However, I know that others have been mounting the Park 250 motors without any problems.
Old Dec 20, 2011, 08:51 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
yeah I know, that's why I bought them .... but I see post #4 here
http://www.rcgroups.com/forums/showt...6#post20191848
and don't see how it fits
Old Dec 20, 2011, 09:15 PM
daign is offline
daign's Avatar
Joined Feb 2011
I'm hoping too.
In pictures in the Micro Quad thread, the Park 250 motors are mounted using the diagonal holes.
Then again those are e-flite park 250's not turnigy.....
also:
The updated Micro Quad arms now (since the last batch) have two holes for mounting directly to the A1510 motors. You can use the original screws if you trim in to the wood just a hair so they recess into the bottom of the arm. The Micro Spider HEX also has A1510 direct mounting holes as well and can be seen in the photo. Don't stress if you don't have the pattern directly for your motor as the wood is easy to drill and mount on.
Old Dec 20, 2011, 09:21 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
also:
and the A1510 holes are not for the 18mm pattern of mounting adapter but for the 9mm holes where the adapter mounts to the motor
Old Dec 23, 2011, 04:46 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
alright, the mailman just dropped off the micro hexa frame ... it's going to be florescent green with florescent yellow highlights
Old Dec 23, 2011, 04:59 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Awesome! I should be getting some 5030 Tri-blade props in Green as well!
Old Dec 23, 2011, 05:45 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
I'm in
New Product xRotor Spider HEX by BlueSkyRC Qrome Multirotor Talk 344 Oct 26, 2014 08:40 AM
New Product ** Micro Quad / Funsize Quad ** BlueSkyRc.com braindead4554 Multirotor Talk 2195 Sep 04, 2014 10:46 AM
New Product xRotor Spider QUAD by BlueSkyRC Qrome Multirotor Talk 845 May 23, 2014 02:10 PM
Build Log BlueSkyRC Spider HEx Build Log Borneoben Multirotor Talk 38 Dec 28, 2011 01:02 PM
Discussion Skye Spider Hex NaterPin Multirotor Talk 0 Jul 07, 2011 01:47 PM
