Hobbico FlyZone Cessna 182 Skylane EP 2.4GHz RTF 47.5" Review
Flyzone boosts the Cessna 182 Skylane by upgrading the included radio system to a Tactic 2.4GHz TTX600 Six Channel Transmitter and TR264 Six Channel Receiver
Wing span: 47.5 in (1205mm)
Length: 39 in (990mm)
Weight: 37 oz (1050g)
Battery: 3S 1800mAh lipo
Motor: 1400kv
Radio: Tactic TTX600 2.4GHz
Distributed by: Tower Hobbies
Price: $259.98
Hobbico has revised their Flyzone Cessna 182 RTF by dropping the 72MHz radio system that used to come in the box and replacing it with a 2.4GHz radio system. The radio that now ships with the Skylane is the Tactic TTX600 six channel 2.4GHz transmitter, which is paired with the Tactic TR264 six channel 2.4 GHz receiver. The Tactic is not just a stripped down, basement level radio system but a 2.4GHz spread spectrum radio system that includes a surprising number of nice features. These include dual rates, channel reverse switches (mechanical and programmable), digital trims, fail safe mode, V tail mixing, wireless trainer/buddy box capability, and the ability to use NiCD or NiMH batteries and charge them using the included charge port. The Skylane is manufactured using Flyzone's proprietary AeroCell foam and features corrugated control surfaces, a pre-applied Cessna graphics scheme, a 7 LED lighting system, working flaps, a pre-installed brushless power system and a 3S balancing charger that can be connected to either an AC or DC power source. There is a lot to look at in the box! Let's get started!
I was surprised at the size of the long narrow box. I expected it to be quite a bit larger. Flyzone packs almost every component into it's own bubble bag. The kit comes out of the box in an advanced state of pre-assembly. The power system and servos are all pre-installed. Assembly is almost tool-less. Most of the Skylane goes together using uniquely engineered fasteners that require nothing other than your hands to assemble. The exceptions are the wing struts, main landing gear, propeller and spinner, which will require a Phillips screwdriver and adjustable wrench. The assembly manual has a list of additional items that are required to complete assembly of this model. Though it says that a set of dry AA cells must be purchased to power the radio transmitter, my kit included a four pack of AA cells in the box. This small detail means that everything you need to fly this model IS included in the box! You will only need to supply a few basic tools to assist with the assembly.
In The Box:
  • Fuselage, with nose gear and brushless power system installed
  • One piece wing, with aileron and flap servos installed
  • Horizontal and vertical stabilizers, with elevator and rudder pre-hinged
  • Vertical stabilizer, with rudder
  • Main landing gear assembly
  • 16 page B&W photo-illustrated assembly manual
  • One page manual addendum (radio system)
  • Propeller and spinner assembly
  • Tactic TTX600 six channel 2.4GHz radio system
  • Great Planes 3S AC/DC balancing charger
  • 3S 11.1V 1800mAh LiPo Battery
Additional Items Required for Completion:
  • Nothing!
The 16 page black and white assembly manual that came in the box with my Cessna was labeled "RXR" (receiver ready) on it's title page, though I had received the "RTF" version of this kit. The manual still references the original 72MHz radio system that originally shipped with the model. The changes that replacing it with the Tactic 2.4GHz bring to the table are covered in the included two page addendum.
All versions of the assembly manual and the addendum are also available in electronic format on the Flyzone web site. Both the manual and the web site are a good place to find information and part numbers for obtaining any necessary spare or replacement parts, should you find yourself in need. The links along the right hand column on Flyzone's main page for this model provide an abundance of useful information, including the factory video, additional photographs and even some Flyzone Cessna 182 Windows wallpaper in several different resolutions if you just cannot stop ogling your new model! Links are also provided to several reviews of the original 72 MHz version of this airplane.
EZone's own Mike Llewellyn reviewed the 72MHz version of this kit back in February of 2009, if you would care for a read. Additional information on the Tactic 2.4GHz radio system may be gleaned from the review written by Dr. Dave in June, 2011.
FlyZone Cessna® 182 Skylane™ Select RTF Review
Hobbico Tactic TTX600 2.4GHz 6-Channel Spread Spectrum Radio Review
The one piece wing comes fully assembled. The flap and aileron servos are pre-mounted to a plastic support tower. The ailerons and flaps feature a corrugated surface molded into the foam to more closely simulate the real Cessna 182. All of the control linkages are already in place, as are the hinges and control horns. Four LEDs are mounted on the wing, in addition to the white landing LEDs located on the leading edge of the wing. A pair of red lights are mounted on the top of the wing, with the standard red and green navigational lights mounted out at the wingtips. All of the lighting on the wing terminates in a single three pin male connector that is plugged into a pigtail attached to the lighting module, which is located in the fuselage near the receiver. The aileron control horns and cable connections are almost invisible. The hinges on the flaps are somewhat of an offset style of hinge and allow the flaps to pivot cleanly downward.
Mounting the wing to the fuselage involves routing the three electrical connections down through the wing saddle opening atop the fuselage and into the bottom of the fuselage. The manual suggests measuring and marking for the recommended range of CG before attaching the wing to the fuselage. All of the servo leads are clearly identified via small labels, so the chances of making any wrong electrical connections are minimized if not eliminated.
Flyzone engineered a unique means of securely fastening the wing to the fuselage. Two large, white plastic locking pins, with wing nut style lobes, pass through the wing and into the fuselage. Circular foam disks serve as washers of a sort. Several spares are included in the box. Once the plastic locking pins have been aligned and fully seated in the receivers located in the fuselage, a ninety degree locks them (and the wing) into place.
The fuselage is 80% assembled right out of the box. The other 20% involves mounting the main landing gear and attaching the prop and spinner to the motor shaft. The fuselage features a large, removable access hatch. The receiver and flight battery can be accessed through this hatch. The nose gear is already mounted and comes with a suspension strut. Flyzone applies a detailed instrument panel graphic to the inside of the cockpit. It is clearly visible through the top of the fuselage before the wing is attached but the smoked windows somewhat obscure this cool feature.
A foam filler block is friction fit into the main gear groove, located on the underside of the Skylane. This filler block is removed to expose the mounting surface for the main landing gear. Once the gear is attached using two small screws, the foam filler block is replaced. It is held in place with double-sided tape.
Tail
The tail of the Flyzone Cessna assembles in a modular fashion that requires no adhesive. This means the tail can be removed and the entire model repacked into the original box, should that ever be a desire. Several hard plastic pieces are embedded into the foam horizontal and vertical stabilizers. These pieces serve to properly align the tail pieces as they are assembled to the fuselage. As the tail is slid into position on the rear of the fuselage, the elevator and rudder push rods need to be attached to the respective control horns and then threaded into the push rod sleeves that lead forward to the elevator and rudder servos, factory mounted in the center area of the fuselage.
The wire lead that is connected to the red LED on the tip of the vertical stabilizer must also be threaded into position at the same time. A clear tube is installed in the fuselage, to serve as a pathway of sorts for this LED lead to get routed forward to the receiver and lighting controller. The servo horns are equipped with EZ connectors. I used a small dab of thread locking compound on the set screws to ensure that they would remain tight in flight. The entire tail assembly is held in place via a plastic clothespin type clip. I applied a piece of clear tape over the clip after it was in place, on the off chance that it could pop off in flight.
Tactic 2.4GHz Radio System
The original version of this Flyzone Skylane included an entry level 72MHz transmitter and receiver. Flyzone has upgraded the transmitter and receiver to a more state of the art 2.4GHz spread spectrum system. This brings added peace of mind to those who would purchase this model, knowing that they now do not have to worry about other nearby pilots accidentally powering up another transmitter on the same frequency and possibly inducing a crash. The Tactic TTX600 transmitter, though not programmable in the same way that most modern transmitters are, still offers a nice feature set for beginning pilots. All channels are reversible, channels one through four being done with a simple flip of a mechanical switch, and channels five and six reversed via the left hand stick being manipulated on a power up condition. The gimbal lengths are adjustable. A wireless trainer mode is supplied. The transmitter can be bound to several different tactic receivers, meaning that a pilot could pick up a spare receiver or two and use one transmitter to fly several different planes.
The TTX600 is designed to use four AA dry cells but there is an upgrade path in place to allow the use of either NiMH or NiCD rechargeable batteries. Once these batteries are installed, they can be charged though a charge port located on the side of the transmitter. Tactic provides information to indicate what charger must be purchased to charge through the side port. The TTX600 can also be configured for use on a V tail equipped model. The dual rates switch selects between 60% and 100% throws. These are not adjustable. No provision is made for limiting the end points of any channel. Though I do not think that this is a general cause for worry, the Cessna assembly manual does suggest limiting the movement of the flaps to 3/8" down. The rotary knob that is used to deploy the flaps drives them past this 3/8" measurement by a fair amount, if rotated from end to end. It would appear that the only real way to limit the flaps to 3/8" worth of throw is to refrain from rotating the flaps knob fully. This could be a little difficult to control though when one is flying the model and has one's attention focused on the skies overhead.
Final assembly includes mounting the included prop and chrome plated spinner and attaching the win struts. Both steps take but a few minutes and both steps use the same exact small black screws. An extra prop included in the box would be a nice touch and surely couldn't add too much cost to the kit? The wing struts have pre-bent ends. They fasten to the underside of the wing and the sides of the fuselage. Removing the wing for transport will require removing at least one set of the wing strut fasteners.
Control throw recommendations are provided in the manual. The Tactic TTX600 has a switch to select between high rates and low rates. Low rates are a fixed 60%, high rates are fixed at 100%. Many transmitters have programmable throws, end points and dual rates. The only possible way to make these settings on the Cessna would be mechanically, by tinkering around with the holes that the control rods are inserted into on the servo horns and control surface horns. After using the included charger to top the 3S 1800mAh lipo off, I inserted it into the model to check the CG. I was glad to see that the CG was within a millimeter or two of the recommended point.
Recommended Control Throws
Elevator 11/16 in (17.5mm)
Ailerons 5/16 in (7.9mm)
Rudder 13/16 in (20.6mm)
Flaps 3/8 in (9.5mm) down
Before heading out to the field, make sure you top off the lipo. I also like to perform a preliminary radio range check and verify the center of gravity. It is not uncommon for these very important steps to get overlooked in the excitement and anxiety that comes before a maiden flight. The Tactic transmitter does not have a true range check feature as do many full featured 2.4GHz radio system. My range check amounted to placing the model in a foam cradle in my driveway, asking my wife to stand near it with her hand on the rear of the fuselage and then give me visual feedback as I walked away from the model. The same range check should be repeated at the field before you fly the airplane. The preliminary range check, performed when you have no real intent or ability to fly the model, is a good way to verify that there are no obvious problems with the radio system. If any problems are noted, they can hopefully be remedied before you are out at the flying field.
Though this model does come with flaps, I find that best practice is to leave them fully retracted for initial flights and trimming. Once a model is trimmed out and I have performed several landings and take offs without them, I will start to explore how they affect the airframe by deploying them at altitude. This is the safest approach in my opinion. My initial flights took place at a venue that has a running track, with a surface composed of very fine aggregate. The gear on the Cessna is of a small enough diameter that the airplane would bog down in the spots where the gravel was a little on the thick side. I was able to modulate the throttle enough to push through most of the time but occasionally I would have to airlift it to a smoother spot. I do not think it would be possible to fly this model from the typical grass field that most clubs possess. The manual does provide instructions for hand launching the model if a suitable runway is not available for use. I prefer low rates for my take off rolls. The high rate setting can lead to over controlling the steering while accelerating to rotation speed. The brushless power system that comes in the Cessna provides just the right amount of power in my opinion. The Cessna moves out nicely and is ready for liftoff in no time at all. I prefer a deliberately extended scale-like take off roll. The Flyzone Cessna looks really cool performing it!
Adding flaps into the take offs does indeed shorten the space required to get the 182 airborne. The Cessna will fairly leap into the air when the flaps are deployed. In fact, I found myself actually feeding in a bit of down elevator on the take off roll, in order to hold the nose down and keep the Cessna from rotating into too steep of an angle of attack on departure. Though Flyzone recommends limiting the flap deployment to 9.5mm down, the rotary knob on the Tactic transmitter will drive them beyond that point when rotated to the full clockwise position. After several trips around the pattern with the knob at 50%, I went ahead and dialed it to 100%.
The appearance of the Cessna coming down the glide slope with the flaps in the full down position and the landing lights visible in the leading edge of the wing is just fantastic! Add in a little headwind and the model will slow to a crawl. I found that if you let it get a little too slow, it will stall with a clean, straight-ahead drop of the nose. I botched a few of my landings in this manner but the landing gear did a fine job of absorbing the energy and no damage ensued. Landings without flaps are at a higher rate of speed of course but they are still easily managed. I had a bunch of fun just shooting touch and goes, going around and around the pattern much the same as real pilots would do with their full size 182s. This model can serve as an excellent platform to help a pilot really get his landings perfected. The landings are the hardest part of the entire equation after all!
The suspension strut on the nose gear is a nice feature and it actually does a nice job of soaking up the energy of harder landings. Whether you use flaps or not, this model is well behaved on final. Keep a little power on all the way to touch down and keep holding the model off the ground by feathering in small inputs of elevator. As the Cessna loses forward velocity, it's nose will slowly come up. Put it all together and you will be rewarded with landings where the main gear touch down first, followed by the nose gear. No need to go full stop though ... just ease back into the power and go back up for just one more trip around the pattern!
Though this Cessna 182 is more of a scale model than it is an aerobatic one, it does feature aileron/elevator/rudder controls. The installed brushless power system provides ample power for subjecting the Cessna to any and all aerobatics that you may wish to try, though some will require a little energy management to pull off successfully. While flying the model for the cameras, I had a go at a bunch of maneuvers. Loops, rolls, inverted flight, and even a little effort at knife edge flight that looked more like an extreme slip ... the 182 can do! I thought it notable that inverted flight requires very little down elevator to keep the nose from falling through. Using the flaps opens up an array of flight challenges that can keep a pilot engaged for a long time. The model has a very light feel in the air and I had quite a bit of fun throwing it around in the sky. I particularly enjoyed shooting realistic looking landing approaches and scale looking take offs. The Flyzone Cessna 182 does a great job of capturing the persona of the full size 182 and again, it simply looks awesome coming at you with the flaps down and the landing lights aglow.
This model is marketed as being suitable for a beginning pilot. After flying quite a few batteries through mine, I think that I would agree with the marketing ... with a caveat or two attached. There are very few models available that will enable a rank beginner to teach himself to fly without any assistance from a more experienced pilot. Many years ago, I did learn to fly completely on my own. And I went through more than a few airframes before I stopped destroying them after only a few flights. I would not recommend that approach. Having said that, this model would serve as a good entry level model if you seek out the help of a qualified flight instructor. It may not have some of the attributes of a true "trainer" but it makes these sacrifices at the benefit of being a very nice looking scale model. A few lessons and flight sessions with an instructor should have most beginners flying this model on their own and getting it up and down with minimal damage. I would suggest leaving the flaps alone until you are very familiar with the flight performance of the model. While it is true using the flaps will lower the takeoff and landing airspeed, they will affect the airframe in ways that beginners are typically ill prepared to handle. The Flyzone Cessna is very well behaved at slower airspeeds. This is especially important for beginning pilots. And it makes for lengthy flight times on the 1800mAh lipo flight pack! Once a pilot can handily land and takeoff this Cessna over and over, use of the the flaps will add another entire dimension of flight performance. It is best to deploy and retract them slowly. This minimizes the pitch variations that are commensurate with flap usage. A beginning pilot should not tire of this model like one would of a true trainer, as it's four channel control, flaps and scale looking appearance offer an abundance of flight challenges and capabilities!
There is a lot to like about this version of the Flyzone Cessna 182 RTF. The move to replace the original 72MHz radio system with the Tactic TTX600 transmitter and receiver all but eliminates the chances of losing the model to RF interference or another modeler powering up on the same frequency. The Tactic is a good entry level 2.4GHz spread spectrum radio system that can theoretically be pressed into usage in other models as the pilots skill level progresses. However, this Cessna 182 offers up enough performance and flight options that the you may not be in a hurry to relegate it to a role on the bench. With this being the case, additional Tactic receivers could be purchased for installation into new models. The Tactic transmitter does not possess multiple model memories as more advanced transmitters typically do but it can be bound to more than one receiver. One would have to take into consideration though that the trim settings would change from model to model. The AeroCell foam nicely endures those less than perfect landings. It's somewhat "soft" composition is resilient and yielding when it needs to be. It will "give" on accidental impact with fixed objects before it fractures or cracks. While exploring this models full flight envelope, I subjected it to some pretty crusty landings but the suspension nose strut and AeroCell foam took it all in stride. The scale details really do their part to make this foamy model look convincingly real in the air. The "adhesive-less" assembly is notably unique and allows you to rekit the model back into it's original box at will. One minor improvement would be to make the appropriate LEDs strobe the same as in a real General Aviation aircraft. The red LED on the tip of the vertical stabilizer in my kit was DOA. I fancied a shot at replacing it but decided against it lest I destroy the fin trying to remove this factory embedded component.
Cool scale details, flaps, a spread spectrum 2.4GHz radio system, a lighting system and flight times of upwards of 6-9 minutes (depending on throttle settings) using the included 3S 1800mAh lipo all combine to make this Cessna a worthy introduction to the thrills of electric flight. The included balancing charger can be connected to either an AC or DC power source, though it will require a little time and patience to replenish the lipo flight pack. Pick up a spare battery or two and you are can probably keep the Cessna in the pattern non-stop!
  • Quick assembly with only a small tool or two required
  • Scale looking appearance
  • Lighting system included
  • Flaps included
  • 2.4GHz Tactic radio system
  • AeroCell foam is resilient and stands up well to rough handling
Dislikes:
  • Red LED on the tip of the vertical stabilizer was dead out of the box
  • Any desired control throw changes must be achieved mechanically
  • Included LED lighting kit is cool but wingtip lights do not strobe as a real 182's would
Old Jan 06, 2012, 07:57 PM
Bajora is online now
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
Reserved
Bajora is online now Find More Posts by Bajora
Old Jan 07, 2012, 01:58 AM
furballll is offline
Find More Posts by furballll
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
Nice reveiw
I have flown my dads older version of the plane lots of times and have to say i really enjoy flying it. The only complaint my dad has for the stock configuation is that the front nose gear is a bit light and bends really easy if the landing isnt perfect. He has his on skiis now and its a blast, even off grass it get up fast and really halls butt. A freind of mine tried putting his on floats, stock motor and stock set up it is a bit on the sluggish side and he had a hard time getting off the water.
furballll is offline Find More Posts by furballll
Old Jan 07, 2012, 06:05 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
That looks fun. Wonder what the price is on the RX ready? Does the RX ready come with the charger and battery too or just the plane?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Jan 07, 2012, 10:40 PM
FNFAL is offline
Find More Posts by FNFAL
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
This really is a good plane. While not perfect, I liked it enough to regret selling it back when.
Minuses:
Battery compartment needs some more thought.
Prop shaft is soft and bends easy.
Wheels are a little cheap, wear quick, and upgrades are hard to find.
Nose suspension could be a little more robust.
Elevator needs reinforcement.
Nose up during flaps
Too much added metal nose weight from factory. Go bigger battery instead.
Pluses:
Great scale looks.
Great ground handling.
Working flaps.
Parts easy to get from Tower.
Well performing plane - Reasonable power, great speed and great in-air handling.
Good size for park flyer - removeable wings.
Electronics work well.
Good solid subframe inside foam.
Overall, I think a great 3rd plane. The only reason it's not a beginner is that landing her can be a little trick especially without a headwind. She can come in a little hot as the wing cross-section is nice and slim. You can't lose with a little power all the way to touchdown - sparing you the dreaded bunny hop. With a little practice it quickly becomes very rewarding.
She has a heavier feel at the controls but nothing fustrating. And she'll do most any scale aerobatics you would like to do with her too. Power is adequate, although those in higher elevations may be left a little wanting.
But in closing, I think some look at the low cost and foam contruction and think 'cheap' and 'starter plane'. And the reality is that it's much more.
And the lights at dusk are priceless.
FNFAL is offline Find More Posts by FNFAL
Old Jan 07, 2012, 10:46 PM
KA6KHM
Bajora's Avatar
Joined Sep 2004
Originally Posted by FNFAL View Post
Overall, I think a great 3rd plane. I disagree with the author about this being a beginner plane unfortunately. The only reason is that landing her can be a little trick especially without a headwind. She can come in a little hot as the wing cross-section is nice and slim. You can't lose with a little power all the way to touchdown. With a little practice it quickly becomes very rewarding.
Thanks for adding your comments. They certainly add another impression and opinion for others to read and benefit from.
Please reread my comments in the "Is this plane good for a beginner?" section ... I attached several "strings" to my opinion that this plane would be suitable for a rank beginner.
Old Jan 09, 2012, 11:31 PM
Matt D. is offline
Find More Posts by Matt D.
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
Great review. Great looking plane and the pictures were very nice.
Not a fan of the artistic looking video, but the video was excellently shot and edited.
I like that there were close flybys and not the usual spec in the sky.
Also liked that you were flying it slow a lot and used flaps and not the usual wot we see so much.
Heck, I liked just about everything about it!
How much headwind did you have on the landings?
Matt D. is offline Find More Posts by Matt D.
Old Jan 10, 2012, 01:34 AM
jonathan7x70 is offline
Find More Posts by jonathan7x70
President @ Acadian RC Club
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
WOW looks nice! To bad its a foam plane. If it only came in balsa Arf kit I would be interested. Dont like foam and dont like being forced to buy cheap radio gear.
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Jan 10, 2012, 08:56 AM
KA6KHM
Bajora's Avatar
Joined Sep 2004
Winds were light that day ... they did came up a little as the afternoon wore on. I would guess 5-8 MPH max?
There are plenty of options out there. I am sure you can find a conventional built up Cessna if you look around. I just reviewed a 152 that is balsa composition. If I had stalled it on landing like I did this foamy Cessna (see it in the video), I probably would have punched the landing gear up through the bottom of the fuselage and had to make repairs! So, that is one benefit of foam construction to consider.
There is a difference between "cheap" radio gear and inexpensive radio gear. The Tactic is the latter IMO. I have yet to have any problems with the transmitter, servos or receiver. Thus far, they have functioned dependably, with no loss of signal experienced.
Old Jan 10, 2012, 09:27 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
I learned to fly on one of these and later moved to the more powerful Apprentice. I agree with the review except using the term ample to describe the power. Adequate would be a fair term. This plane flies aerobatics reasonably well with a bit more power. The included power system, of course, is just fine for scale flying. My only complaint about the model is the use of single servos for both the ailerons and flaps. But I understand the need to keep the price down. It is a very good looking scale model. Here's a shot of mine on the ground to show how much detail it offers. Note the detail in the nose gear and at the point where the wing struts meet the fuselage.
fmw is offline Find More Posts by fmw
Old Mar 19, 2012, 09:43 PM
mds47588 is offline
Find More Posts by mds47588
mds47588's Avatar
United States, MS, Picayune
Joined Dec 2011
I purchased one of these as my very first (read: totally noob) R/C plane. My first flight didn't last too long and I still have the remnants ready to rebuild into another plane. However, I liked the looks of the plane so much that I got another that was RXR and merely put my old receiver into it. It did fly (the replacement) once and looked great doing so, but it wasn't me at the sticks.
Since then, I had really learned to fly with a Champ and Micro-Cub and now I stepped back up added a Sensei to my qwik growing hangar. I'm waiting on decent weather to maiden it and waitng til my skills are ready for me to fly the Cessna myself. As good looking out the box as it is...I modded mine some and painted some white on the prop ends, stripes on the wheel pants, red wing-tips and a cut-to-size screen where the air filter element is.
mds47588 is offline Find More Posts by mds47588
Old Apr 25, 2012, 10:50 PM
Mr.Firemouth is offline
Find More Posts by Mr.Firemouth
Sir-Crash-a-Lot
Mr.Firemouth's Avatar
United States, IL, Edwardsville
Joined Jun 2011
Mine just came in yesterday and buddy Paul is putting it together. We might get to fly it this weekend. The servo for rudder/nose wheel had bad hardware and Tower is sending out new parts. Hopefully we see it before the weekend! If not we will be flying our Helicopters! 120sr and Mcpx! I may also buy a Stratos Firebird. May buy is more like definitely!
Mr.Firemouth is offline Find More Posts by Mr.Firemouth
Old Jun 15, 2012, 02:21 PM
Pilot420 is offline
Find More Posts by Pilot420
Can't Afford the Real Thing
Canada, ON, Oshawa
Joined Apr 2012
Minuses:
Pluses:
Great scale looks.
Working flaps.
Thanks for this post! I got my flyzone Cessna last week and have taken out the nose weights, upgraded the ESC and BEC. I shaved out 3 mm of foam in the battery compartment to fit 3s 20c 3000mah. Changed the prop to a MAster airscrew 8 x 4. Now waiting for time and weather to fly!!!
Pilot420 is offline Find More Posts by Pilot420
Old Jun 15, 2012, 04:36 PM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
I ordered this plane from Tower Hobbies and expect it sometime next week. I would encourage you to get the Firebird Stratos. It is a great plane and I enjoy the heck out of mine. I also have an HZ Champ and the HZ Super Cub. I can't wait to get my new Cessna in the air.
chucksolo69 is offline Find More Posts by chucksolo69
Old Jan 05, 2013, 12:53 PM
shannondan is offline
Find More Posts by shannondan
Dan S.
Joined Jan 2013
Great Airplane
I just got the Flyzone Cessna 182 and it is my first 4-channel airplane, having previously flown a small 3-channel foamie cub. I can't explain it but when I saw the previous version of this, which had 72 MHZ electronics and a different engine, I just had to have one. Tower Hobbies has the new version on special now for $129 US and I bought it.
Assembly wasn't too bad, I think my greatest challenge was just learning to be patient and careful. Although a pro might put one of these together in 30 minutes I spent 10 hours carefully checking all the settings, servos, and actually ended putting it together twice because I didn't know how to use threadlock and didn't secure the rudder pushrod well enough the first time. I also noticed that the CG, when assembled was significantly behind the recommended setting. I added 2 ounces of adhesive racing weights made for wooden cars to the nose to bring it in line.
My first flight was nightmarish. First, the "field" was a small unused parking lot next to an empty building. The Flyzone Cessna does indeed fly "scale" and the takeoffs and landings were hairy, to say the least, because of a lack of room. I had programmed my Spektrum DX6i to have three flap settings but failed to dial down the throws and when I got the plane in the air it was trimmed so "nose up" that it porposed around while my heart tried to stop. Also, the wind was 7MPH with gusts to 11-12 aloft. I brought the plane in for two hard landings, getting the trim a little better each time, and on the third landing broke the horn on the nose gear. Fixing the gear took me 3 hours but wasn't too bad because there were two holes remaining on the unbroken portion of the nose gear horn.
Today I took the Cessna up in the morning with no winds and a better field and it.. was... a... dream. Properly trimmed and with reduced throws on the tx (70% and 50%+ exponential for elevator and ailerons) it takes off, flies, and lands like a real plane. You'll need significant roll out space (60-75 ft) without flaps but with 10% flaps you can get aloft in much less that that. Previous posts about needing full power for takeoffs and not being able to hang it on the nose are right on.
While fixing the nose gear I had moved the pushrod to the innermost hole which enables the Cessna to turn very smartly, as if using differential brakes. I love the effect when taxiiing out for takeoff. In order to have better control for the roll out I programmed the TX to have only 30% throw until I move the switch back when I'M in the air.
I know this is an old thread but I thought I would add all of this here because I think this is a terrific plane and probably will have many more enthusiasts like myself.
Lastly, I would agree that this probably isn't a "first" plane for a total novice unless they like to learn through hard knocks and have some knowledge about flight.
shannondan is offline Find More Posts by shannondan
Discussion Help a noob out - Hobbico FlyZone Cessna 182 Skylane Select EP RTF 47.5" RCGDave Electric Plane Talk 14 Jan 25, 2012 07:06 AM
Sold FlyZone Cessna 182 Skylane EP PNP 47.5" Trade ? kramer Aircraft - Electric - Airplanes (FS/W) 0 Nov 28, 2011 11:02 PM
Sold REDUCED!!Hobbico FlyZone Cessna 182 Skylane EP PNP 47.5" Trade ? kramer Aircraft - Electric - Airplanes (FS/W) 6 Nov 22, 2011 04:15 PM
For Sale REDUCED!!Hobbico FlyZone Cessna 182 Skylane EP PNP 47.5" with SPARE PARTS!! Trade ? kramer Aircraft - Electric - Airplanes (FS/W) 9 Oct 09, 2011 10:02 PM
Discussion NEW 47.5" wingspan Hobbico Flyzone Cessna 182 Skylane 5 channel jonathanjhl Parkflyers 5 Aug 15, 2009 10:05 AM
