Old Dec 19, 2011, 10:38 PM
C-5 Flight Engineer
PANTHERFLYR's Avatar
Joined May 2005
wicked 60 mm fan inrunner motor options
Hi-will be powering my 4 engine smaller c-5 with 4 dons 60mm's and wanted to use the aft fairing, because it looks very scale(ish) for the c-5 tf-39 engine. Are there any options for the fan that create ok thrust in no thrust tube?? Thanks
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Dec 20, 2011, 10:29 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have no recommendation on inrunners because I do not sell them so have no knowledge on how they perform in this fan unit other than I can say similar KV inrunners will get similar watts as I get on the outrunners. But the real issue is what watts will the inrunners be able to run at with no cooling inside the aft fairing? That I can not tell you.
The Don is offline Find More Posts by The Don
Old Dec 21, 2011, 10:55 PM
C-5 Flight Engineer
Joined May 2005
Thanks Don!
Old Dec 26, 2011, 02:31 AM
Horten Heretic
Au_Arbiter's Avatar
nowhere, Australia
Joined Dec 2004
I tested a Het-2w in that fan a while ago and got about 400w on 4s
Au_Arbiter is offline Find More Posts by Au_Arbiter
Sold Don's Wicked motor and WeMoTec 50 mm fan bruff Aircraft - Electric - Jets (FS/W) 0 Nov 23, 2010 06:08 PM
For Sale Brand new dynamically balanced Wicked 5400 in 60 mm fan. The Don Aircraft - Electric - Jets (FS/W) 0 Sep 16, 2010 12:10 AM
Sold Alpha 60/25 fan and Don's Wicked 4800 motor tailslide5_0 Aircraft - Electric - Jets (FS/W) 4 May 12, 2010 10:18 PM
Sold New Wicked 4800 installed in 60 mm 5 blade fan. The Don Aircraft - Electric - Jets (FS/W) 11 Jul 31, 2009 07:34 AM
Question Plane for 60 mm fan / Don's wicked 4800kv lammy1000 Foamy EDFs 0 Jun 26, 2009 03:38 PM
