Old Nov 09, 2012, 06:36 PM
Yablonsky is offline
Find More Posts by Yablonsky
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
I actually just got all the balls in today....picked up my scale from the house...
Also for the weight of my "balls"....I've weighed each in turn and they all weigh 281g or 0.9oz each.
The wooden balls however have different weights...all being wood and wood weighs different...are all about 26g each. Some more, some less.
The Post-It doesn't weigh anything....
Also, here is a pic of the proposed ballast tube design...very basic, but you should be able to get the idea.
Ken
Yablonsky is offline Find More Posts by Yablonsky
Old Nov 09, 2012, 06:45 PM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Weight efficiency forgotten, I really love the idea of balls Ken. Just thought I'd make that clear.
For the wooden balls you might consider drilling some holes through them to either further lighten them or to at least give them uniform weight if the difference is that great.
Additionally, you might want to add in or create a ramp/emergency exit in front of the tube for the case of an extreme landing. Not sure if it's even possible for the Genesis or not, but on my one severe landing my ballast rather rudely ejected my servo tray and destroyed my switch (The water it landed in destroyed the servo and Rx ). The 3M plane I have has the ballast exit above the tray though so in the case of extreme failure, the slugs will shoot out the canopy and not the tray. Anyways, just saying, and no real reason to listen to me either
Keep them build posts coming!
-Jonathan
who talks a lot but says little
Twyl is offline Find More Posts by Twyl
Old Nov 09, 2012, 06:58 PM
67econoline is offline
Find More Posts by 67econoline
Nothing to see here...
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
Or follow the Rubio Plan...
Buy plane...
Buy gear
Make ballast tube
Make ballast
Finish up tube
Cut one hole to start wiring
Continue building PSS foamie's
Rubio
Who is still buildin those foamies and looks at the Genesis...
67econoline is offline Find More Posts by 67econoline
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
A ramp sounds like a great idea....I was going to fully epoxy the whole tube inside the fuse.
I may have to move my servo around to accommodate...or perhaps just build that into the tube itself....hmmmm...
Ken
Old Nov 09, 2012, 06:59 PM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
LOL....
I really like the building part...almost more than flying. Keeps my mind and hands busy.
I'd love to get enough of a rep to build for others....some day.
Ken
Old Nov 12, 2012, 11:09 AM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
Picked up one of these twisting switchjacks for charging/powering up the plane.
http://www.canuckengineering.com/new...s/switch-jacks
Also found these...if you want just the bare jacks...
http://www.minute-man.com/acatalog/O...202.html#a2160
Will post more pics of the switch install and the ballast tube when I get them.
If anyone wants to pitch in together to buy just the bare jacks....The minimum is $20...I'd be interested.
Ken
Old Nov 15, 2012, 12:12 AM
oletimer is offline
Find More Posts by oletimer
Dang!....What else did I bring
oletimer's Avatar
Orange County, S. Cal
Joined Oct 2009
Switch jacks!
Ken...you can go to Marvac, or this other electronics place like that off the 405 fwy & 2 exits past beach. Same price & no min!
Jeff
oletimer is offline Find More Posts by oletimer
Old Nov 18, 2012, 10:28 AM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
Here are a few pics of the start of the ballast tube.
Description:
Description:
Ken
Old Nov 18, 2012, 10:29 AM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
And some close ups
Description:
Description:
Description:
Ken
Old Nov 18, 2012, 12:14 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Ahh, they're shy..
(Hiding in their little cave.)
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Nov 18, 2012, 01:12 PM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
I started with 3/4" dowel and covered that with wax paper, then pushed that through the carbon Kevlar sock and pinching one end with a wire tie, I pulled the sock tight, twisting the other end and clamping it off with another wire tie.
I finally painted on the epoxy and stood the whole thing up to dry overnight.
Ken
Old Dec 08, 2012, 08:59 AM
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
Where exactly is the CG Calculated on the wing?
In one of Jordan's first post shows 91 mm, But where on the wing is that measured?
Ken
Old Dec 08, 2012, 10:58 AM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Ken
From the leading edge at the fuselage. More suggested settings can be found near the bottom of this page:
http://www.alofthobbies.com/genesis-60-slope-racer.html
-Wayne
Site Sponsor
Old Apr 05, 2013, 11:14 AM
scale_sloper is offline
Find More Posts by scale_sloper
United States, CA, Hollister
Joined May 2011
Wayne,
I must say it again, this ship is very nicely done for the money and I can only hope it flies as well as it looks. Although wanted the red on the bottom at first I think it looks better on top.
Thanks again for the excellent job of choosing such nice plane for a great price!
Scale_sloper
scale_sloper is offline Find More Posts by scale_sloper
Old Apr 05, 2013, 12:24 PM
jatan231 is offline
Find More Posts by jatan231
Slope fanatic
South Africa, WC, Paarl
Joined Jan 2012
Hi
If anyone has some decent figures for crow setup I would appeciate it.
I'm having a hard time dialing in the crow (flaps down and ailerons up) setup as I still have massive nose up with nearly max down elevator.
All the throws are based on what is given at aloft webpage.
Suggestions will be appreciate.
Tokkie
jatan231 is offline Find More Posts by jatan231
Careful! Phill Collins give away aka genesis eckace1 Batteries and Chargers 4 Dec 19, 2011 08:08 PM
Build Log Bass Plug flying fish wing build log masson74 Slope 23 Sep 23, 2008 09:07 PM
