Old Mar 05, 2012, 01:20 PM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Originally Posted by SumthinsFishy View Post
All in all, while weight does have its place...
Ok, point taken. Now for take off!
Twyl is offline Find More Posts by Twyl
Old Mar 05, 2012, 02:30 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
I would just add that I've flown light planes, and I've flown heavy planes. All in all, while weight does have its place, light planes fly better.
Dave
Isnt that what ballast is for? BOBW. Build em light and add weight later. I would say that of course the plane has to be strong enough for purpose intended.
jimbo320 is offline Find More Posts by jimbo320
Old Mar 05, 2012, 03:04 PM
Big Gas is offline
Find More Posts by Big Gas
Semper Fidelis
Big Gas's Avatar
United States, CA, Redlands
Joined Jul 2005
The idea with the ballast tube is to make the model more versatile. Having owned and flown a lot of moldie 60" models I can guarantee that adding ballast will make this thing more fun in big wind conditions. It will also ds better, however I wouldn't particularly push this one over 150 mph. So I'm thinking 16-20 oz in this plane will be more than enough for heavy conditions. If it isn't then it may be time to pull another model out of the quiver.
Wayne, the 5085 for the elevator is not too friendly in this fuse sideways and won't fit over the inch diameter ballast tube. I will make a tray, maybe even screw it to rails it I have to butt the battery close to it. I'll post a pic when I get it figured out.
Big Gas is offline Find More Posts by Big Gas
Old Mar 05, 2012, 03:34 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
I'm sorry, did you say 1 inch?? Now that picture Twyl posted is coming to mind.
I think ours are a little less then 3/4". But then again our 3/4" with lead will be similar or heavier then your 1" with steel. Hmm... 1", shorter tube, mass more centered.. Might be worth doing.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Mar 07, 2012, 10:36 AM
Big Gas is offline
Semper Fidelis
Big Gas's Avatar
Joined Jul 2005
Yes, same tube as the minivec.
I cut it shorter, it holds 16oz of steel slugs, of course some lead will go heavier if needed.
Just about done.
Thanks twl, I can't help but look at those attractive girls helping that poor Baluga Whale.
Old Mar 07, 2012, 12:38 PM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
Looks great. Do you epoxy the brass fitting into the hollow carbon tube?
macinr is offline Find More Posts by macinr
Old Mar 07, 2012, 01:19 PM
Big Gas is offline
Semper Fidelis
Big Gas's Avatar
Joined Jul 2005
The pushrod?
It is a threaded 2-56 rod that slides into the carbon tube. Gorilla CAed in place. I've never had one come out. I've also used the foaming GG with success too. CA just offers instant gratification. I've also done epoxy with success but its toooo slow.
Old Mar 07, 2012, 01:26 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
I usually put a slight bend on the wire before putting it into the carbon for a little extra friction.
Site Sponsor
Old Mar 07, 2012, 02:21 PM
macinr is offline
macinr's Avatar
Joined Feb 2003
Originally Posted by Big Gas View Post
The pushrod?
yes, exactly what i was after. i thought that you had simply epoxied brass fittings to the end of the tube not realizing it encapsulated the 2-56 threaded rod.
Old Mar 14, 2012, 09:41 AM
Big Gas is offline
Semper Fidelis
Big Gas's Avatar
Joined Jul 2005
Maiden
We got a decent Genesis maiden last weekend at Little Mountain. After a number of flights the cg is closer to 89-90mm. Fist time I threw it off it popped up a bit on launch and tucked in a dive. A little nose weight calmed that down. It is fast! And the elevator response at recommended settings is "very" snappy. It was "flick" tested in what would have spiraled a Destiny. It just kept going and recovered easily.
Be ready for a ton of down elevator compensation during butterfly. It took about five landings before it got close. I think I had close to 80% of the down elevator mixed in during butterfly. The flaps literally drop 90deg. so I backed these off to about 70deg which helped. It's just a matter of setting up a proper elevator curve for the mix to get a nice butterfly mix.
All in all, a sweet 60 incher. I would say the new best bang for the buck in terms of a moldie.
Old Mar 14, 2012, 11:38 AM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Great to hear!
I'm not sure why the Destiny has lasted all of these years when there are a number of great flying planes that don't like to fall out of the sky.
The Genesis loves a good hard turn.. Almost seems to get faster doing it. When set up right she will just pull a beautiful turn, no trauma at all. Like any good plane should.
-Wayne
Site Sponsor
Old Mar 14, 2012, 08:24 PM
bluzharp is offline
Find More Posts by bluzharp
setting CG with ceiling fan on
bluzharp's Avatar
USA, CA, Bakersfield
Joined Apr 2010
Do you have much up aileron in your landing setup? A bit more should reduce the ballooning without using up a lot of elevator travel.
bluzharp is offline Find More Posts by bluzharp
Old Mar 14, 2012, 11:29 PM
Big Gas is offline
Semper Fidelis
Big Gas's Avatar
Joined Jul 2005
I think they were about half to 3/4 up deflection. I didn't want too much as to keep roll authority while having no rudder. Once the down is dialed you can pretty much parachute it in.
Old Mar 15, 2012, 02:51 AM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
Hey Wayne, do you have any pictures of Miro's Raptor where he sanded out the black or was it red paint from the wing? Heck, while you're at it throw in some from your's and Shadows.
-Jonathan
Old Mar 15, 2012, 11:24 AM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
-Jonathan
Miro sanded out all of the red from the top of his Genesis wing and replaced it with white Monokote. I only got a junky cell phone picture. He did a very impressive job of sanding the paint back to the top layer of glass without damaging the glass. Nice to see the very clean construction and balsa core material for the wing. But covering it in Monokote seemed silly. Miro wanted higher contrast for his vision.
-Wayne
Site Sponsor
Careful! Phill Collins give away aka genesis eckace1 Batteries and Chargers 4 Dec 19, 2011 08:08 PM
Build Log Bass Plug flying fish wing build log masson74 Slope 23 Sep 23, 2008 09:07 PM
