This thread is privately moderated by GooberSB, who may elect to delete unwanted replies.
Old Dec 19, 2011, 12:13 PM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Build Log
16" UFO sport flier
I wanted to build myself an indoor flier similar to the 12" version I built for a friend but without the expensive PZ brick.
It's amazing how fast the weight goes up on a disc shaped aircraft. At 125% the size of the 12" version, the weight is about 300%.
I started out with a 5g hexTronik motor and a 350mah 2S but it couldn't keep it in the air at all. I switched to a 3S battery and could smell the wires melting in the motor after a few minutes of average throttle. I replaced the motor and battery with a hexTronik 2211 (250 size) and a 500mah 2S. That made a big difference.
Now, I've been using the 2211 on wings of various sizes. The 20" and 24" KESL wings (see my blog posts below on those) and a few failed builds fly great with these motors. But I wanted this one to be indoor not a fast outdoor flier. I learned from my Electrifly Pluma that a large motor with a large prop can fly extremely slow so that's the direction I went.
I put a 8x3.8 prop on this motor and went with a 2S to keep the rpms down. I don't want a lot of rpms this time.
Here's a video of the result. I'm flying on low rates because on high rates the axial roll is pretty fast. I think if I increase my expo from 30% to 70% I can fly it normally on high rates and be able to a good hover too.
16" Sport UFO (4 min 32 sec)
GooberSB is offline Find More Posts by GooberSB
Old Dec 19, 2011, 03:25 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
What? Now that is an interesting statement!
Originally Posted by GooberSB View Post
... The 20" and 24" KESL wings (see my blog posts below on those) and a few failed builds fly great with these motors.
I'm not sure how a "failed build" can fly great on any motor, but I am curious how that was done. LOL, OK, kidding aside, I am interested in your smaller builds and want to see if I can make a decent copy. If you have more pictures to post and details, please post them soon. Thanks.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Dec 19, 2011, 04:34 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
haha
Yes, even the failed builds were a good match for the motor. Unfortunately, the rest of the build was sub-par on those. Your jest is taken with humor
I'll post some pictures in a few hours.
Old Dec 19, 2011, 05:26 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Pictures! I love pictures
haha Yes, even the failed builds were a good match for the motor. Unfortunately, the rest of the build was sub-par on those. Your jest is taken with humor I'll post some pictures in a few hours.
Eoouwww (however that is spelled), goody goody! I suppose a guy can see enough pictures in his life time, but I'm not there yet!
Old Dec 19, 2011, 09:45 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Here are some pictures
I use these a lot with the small servos and control horns
http://secure.hobbyzone.com/DUB847.html
The reason is that the thin pushrods bend and bow very easily. The housing sleeve can be glued down and will prevent this. I ususally cut a small channel in the foam so I can glue the sleeve and have it flush with the surface.
I like these too but will use hobbyking stuff when I run out
http://secure.hobbyzone.com/DUB919.html
I normally use these for larger projects
http://www.headsuprc.com/servlet/the...ck-with/Detail
but for this particular build I used one of these because I needed it to be short
http://secure.hobbyzone.com/GWSAP076.html
I cut it in half so I could put the battery between the motor and the CG line. Keep in mind the CG is 25% or 4" in ths case. As much as possible needs to be in the first 4" to avoid adding dead weight to achieve balance.
Old Dec 20, 2011, 06:14 AM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Here are some pictures. I use these a lot with the small servos and control horns. The reason is that the thin push-rods bend and bow very easily. The housing sleeve can be glued down and will prevent this. I usually cut a small channel in the foam so I can glue the sleeve and have it flush with the surface. I like these too but will use hobby king stuff when I run out. ... I cut it in half so I could put the battery between the motor and the CG line. Keep in mind the CG is 25% or 4" in this case. As much as possible needs to be in the first 4" to avoid adding dead weight to achieve balance.
Thanks. The pictures help to explain a lot of details.
Old Dec 20, 2011, 10:28 AM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Dave Reap's mini heart is an interesting design that I want to try soon.
http://www.rcgroups.com/forums/showthread.php?t=1548634
Off Site ufo 4 parts or make a flier crashdumby Aircraft - Electric - Helis (FS/W) 0 Aug 13, 2009 05:00 AM
?First Brushless for sport flier, ..confused No Step Power Systems 18 Dec 01, 2006 10:41 PM
Discussion Can the MM Panic be used as a good windy day sport flier? TGK Parkflyers 12 Jan 31, 2006 04:41 PM
What is a "Sport Flier" BrunswickOH Electric Plane Talk 18 Nov 11, 2005 07:01 PM
I need a 3d trainer....transition from "sport flier" to "3D" Jim_W 3D Flying 12 Nov 11, 2004 03:31 AM
