Fitting the Hull Frames
The frames and stern formers are aligned and glued in place on the keel. The stringers are laid in next. A bit of trimming was needed at former 1, though I'm not sure whether it was my fault or a slight mismatched former. Either way, just be sure the stringers flow nicely into the stem.
Let the Planking Begin
Actually, in spite of the fact that laying planks can be tedious work, I really like doing it. The challenge of fitting each plank and then making it flow around all those compound curves and angles is really fun. And when it's all done, you can know you've accomplished something.
Meanwhile, the instructions are very clear as to the planking sequence, and so far, the plan has worked -- with one exception.... The first 3 planks were laid with the keel/former assembly on the kit provided jig. The vertical transom planking was done next. Then the hull was then removed from the board to start the bottom planking. That's when i discovered that there was a slight, but very noticeable twist in the hull, so before the two center planks went on, the frame was hot glued to the building board to insure it would be straight one the remaining planks were in place. To start the bottom planking, the two center planks were fitted and glued in place next to the keel. |
Pessing On
As the planking progresses, it becomes necessary to start tapering the front and rear ends of the planks. Dimensions are given for the amount of taper, so you'll have a good starting point. The planks are fitted by trial and error, sanded into contour, then glued in place. To make the curves with less effort, the planks were wetted on the outside only, which induces a natural curl that maked the bends easy to form.
The planks are glued together using Elmer's Carpenters Glue between the planks, but are attached to the frames with CYa. Work from side to side so that the load is symmetrical so's not to induce any uneven loads as the planks go on. Also, select the balsa strips so that the firmness of the wood is similar from side to side as planking progresses. From here we'll get the last of the planking on, then turn her over and get started on the decks. PAT |
Monterey Bay California
Joined Feb 2004
![]() Quote:
I was not a fan of the plastic hulls and did not see myself buying one of those any time soon. So glad to see Dumas going back to wood - Laser cut frames too!
Joined Feb 2004
Edge gluing the planks makes building the hull and fairing so much easier-"Carpenter" type glues are easy to use and seem to sand much better than CA. Edge gluing planks on a model with epoxy would be overkill and less fun.
| Thread Tools | |
| Discussion Dumas George W. Wasburn | skipperfrank | Scale Boats | 69 | Jan 07, 2012 03:33 PM |
| Cool USS George H.W. Bush Departs Naval Station Norfolk for Maiden Deployment | Rmay | Dock Talk | 1 | Dec 02, 2011 06:06 PM |
| New Product I just received my Dumas George W. Washburn from Tower Hobbies | rlboats2003 | Scale Boats | 16 | Oct 25, 2011 06:03 AM |
| For Sale Washburn Flame V Guitar | avoidingexpert | Non R/C Items (FS/W) | 0 | Dec 10, 2008 07:41 AM |
| Discussion Vendo Guitarra Flying V Washburn Grafitti!Baixei pra 800 | Pithan20 | Brazil | 11 | Apr 28, 2008 09:19 PM |
