Old Dec 19, 2011, 11:45 AM
Air Cooled is offline
Find More Posts by Air Cooled
gravity is strong where I fly
Air Cooled's Avatar
United States, NY, Rochester
Joined Jul 2011
Does cold weather affect planes flight?
I was flying my Clouds Fly glider and my Cessna on Monday when it was 55 degrees out and calm. Both planes were all trimmed out and flying great!
On Sunday I went out with both planes again, only this time it was 25 degrees out and calm. Now both planes needed down elevator trim (lowering the nose) to keep the planes flying level again. The glider required ALOT of down elevator and the Cessna not so much....but both needed the down elevator trim.
Is this the result of flying in the colder air?
Air Cooled is offline Find More Posts by Air Cooled
Old Dec 19, 2011, 11:50 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
More apt to be the fact that your control rods changed length with temperature (some have a high coefficient of expansion) than from any effect of the more dense colder air. Now, if using an ignition motor or glow motor, the higher density of the air has a slight effect on performance as you get more oxygen per liter of air intake into the combustion chamber.
Rodney is offline Find More Posts by Rodney
Old Dec 19, 2011, 01:13 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
denser air is more lift and such. I have retrimmed my Jug for more down elevator than usual as well.
JDMJim is offline Find More Posts by JDMJim
Old Dec 19, 2011, 01:16 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Air Cooled,
I also do notice a difference with flight on cold days as my foamies seem to "tighten up" a bit with the ailerons, elev., & rudder. I found the pushrod slots also to be a bit tighter, although did not affect movement & the batteries definitely had a shorter flight time. There was nothing with the cold that really affected flight characteristics that may jeopardize control movement resulting in a crash. I noted my normally 10-14min. flights reduced to 7-8min.. I simply adjusted my times & kept my spare batteries in my jacket pocket.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Dec 19, 2011, 01:36 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
I agree. Someone took pics of an Easy Star control surfaces in warm and cold weather. The difference was very noticeable and pronounced
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Dec 19, 2011, 01:46 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
But if you trim your plane, that shouldn't matter. There is a definite air density effect with a 30-degree shift in temperature. The effect is compounded by the fact that cold days are usually not as humid - further increasing the air density. You might not see any change in the power system, but all your airfoils are more effective - so, the prop, the wings, the tail - it's all increased effectiveness on a cold day. We have pretty radical shifts around here, and I do have to adjust my gyros for the season - more gain in summer. On a hot day, maybe 100 degrees and 70% humidity, the feeling is like the air just isn't there anymore - fast planes feel really slippery and slow stuff feels under-powered. Once you have eliminated for trim issues, I think it really is the density shift that you're noticing.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 19, 2011, 04:05 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I'm with Jasmine on this one. If control rods did change length they would tend to be shorter with colder temperatures. Since most elevator control horns are mounted on the bottom of the elevator that would pull the elevator down and up trim would be needed to compensate, not down trim.
Colder air is more dense so the propeller, flight surfaces and control surfaces are more effective. So for the same power level the airplane would be faster and tend to climb. That alone would require down trim to compensate for the change in temperature.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Dec 19, 2011, 09:11 PM
Air Cooled's Avatar
Joined Jul 2011
Originally Posted by jasmine2501 View Post
But if you trim your plane, that shouldn't matter. There is a definite air density effect with a 30-degree shift in temperature.........Once you have eliminated for trim issues, I think it really is the density shift that you're noticing.
Yes, I was able to trim it back out, but I was trying to figure out the "why" part
The Clouds Fly glider took ALOT more correction, but I could still trim it out. This plane does have the elevator horn on the bottom surface, so a colder "shrunken" rod would be the opposite of what I'm seeing.
Old Dec 19, 2011, 11:13 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I would be inclined to think that the foam airframe would contract more than the metal pushrod, which would explain this pretty well. I could be wrong.
Piece is offline Find More Posts by Piece
Old Dec 20, 2011, 05:50 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Your right TP. Plastic expands and contracts very much with temp change. If the pusrods were made from metal, wood or carbon fibre, there would be a big difference. Had a 200 cc Quadra motor with a plastic timing ring turning on an aluminum collar. Couldn't figure out why the engine wouldn't run right in the colder weather. Turned out the plastic ring shrunk onto the collar and wouldn't change the timing. I turned down the inside of the ring a few thou and everything was cool. I wonder what some of the things are that have to be done to compensate with the high altitude jets.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 20, 2011, 10:58 AM
Rocket Programmer
Joined Jul 2007
It's a glider, so it probably has a flat-bottom and very efficient wing design. A glider which can take advantage of tiny thermals, can definitely take advantage of a change in air density, even a small one. With the wing generating more lift, you could fly slower, or you could put the CG forward a bit - but it's definitely going to change things. It's specifically designed to be able to use small variations in the air, and the density shift from getting 30 degrees colder is not a small variation.
Old Dec 20, 2011, 11:00 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Here I disagree with Jasmine. The difference in the amount of trim is most likely due to a larger static margin. In other words, the CG is farther away from, or in front of, the airplane's neutral point. This makes the elevator less sensitive. The less sensitive elevator would require more deflection to effect the same amount of pitch change. Moving the CG back a bit would compensate for that. It would also make the glider react more readily to changes in air currents making it easier to find thermals.
Larry
Old Dec 20, 2011, 11:12 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Damn... There really is a complex answer to everything, isn't there?
Old Dec 20, 2011, 11:43 AM
Rocket Programmer
Joined Jul 2007
Yes, and you would not see this effect with symmetrical wings or profiles if they are properly balanced. If they are not correctly balanced, then the change in the lift would cause a trim problem.
Old Dec 20, 2011, 12:22 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
"Back in the day", temp and air density made a big difference in how many fully loaded marines a CH-46 would be able to lift off and fly with. The temps were 20 degreees lower at 6:00 a.m. than at 10:00 a.m. and the crew chiefs were constantly recalculating so they could take off with as full a load as possible during a big operation. This could mean a two person difference between early morning and mid day. Lift was always higher the the cooler it was.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Discussion Does cold weather affect Lipos? hidaven Electric Plane Talk 24 Feb 09, 2015 08:42 AM
Question using hot glue to glue servos - does this glue stay in cold weather? Charlescd Electric Sailplanes 8 Mar 12, 2013 03:06 PM
Discussion does cold weather affect receivers? b-29er Electric Plane Talk 2 Mar 22, 2009 11:12 PM
Discussion Does Cold Weather Affect Electronics? mondo1948 Electric Warbirds 43 Feb 04, 2008 01:12 PM
Does cold weather affect the performance of NiMH Batteries? neonbutterfly Batteries and Chargers 4 Feb 12, 2003 03:09 AM
