Old Dec 24, 2011, 04:26 PM
RedTwilight is offline
Find More Posts by RedTwilight
Cobra Driver
RedTwilight's Avatar
United States, NC, Hurdle Mills
Joined Dec 2005
The plane is looking great! Can't wait to see it covered and in the air!
RedTwilight is offline Find More Posts by RedTwilight
Old Dec 24, 2011, 05:16 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Hotchkiss
Joined Oct 2006
Good job, Pat. This one might be so ugly, it's cute!
Randy
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Dec 25, 2011, 05:33 PM
Taildragger55 is offline
Find More Posts by Taildragger55
Taildragger55's Avatar
Anchorage, Alaska
Joined Nov 2008
Pilatuspc12 is right. Ugly airplanes always make beautiful models. Nice build Pat, hopefully we'll get to see the finished model, unlike the Airtractor build. (hint, hint)
Taildragger55 is offline Find More Posts by Taildragger55
Old Dec 25, 2011, 10:58 PM
RandyL is offline
Find More Posts by RandyL
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Pat.. You are going to love flying that thing. I still have my 7.5 ft that I built years ago. A great joy to fly.
Randy
RandyL is offline Find More Posts by RandyL
Old Dec 26, 2011, 12:01 AM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
did you draw the plans your self and if so will make the plans availble
john_53_70 is offline Find More Posts by john_53_70
Old Dec 27, 2011, 07:10 AM
Cobra Driver
Joined Dec 2005
I believe Randy built the 7 1/2 foot Ag Cat from Floyd Fitzgerald's plans.
Randy's plane is awesome from the pics I've seen on his website.
Randy- Did you ever get the smoke / spray bars working?
I have a copy of Floyd's plan also. Just started on the tail feathers for it this past Sunday.
Looking forward to Pat's as a plane to take to the field when I don't feel like the big heavy version. LOL And Pat's design will probably be finished way before the big one!
Old Dec 27, 2011, 09:18 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
John, The AG Cat is a brand new design from the ground up. The plans are original, not a re-work from an earlier design. The Short Kit, which will include plans, laser cut parts, and vac-formed radial engine will be released for sale as soon as the p-type has been flown and trimmed.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Dec 27, 2011, 10:16 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Aileron Servos and Wiring
The aileron servos were glued into the wings with silicone. The extension leads I had were too long, so they were cut down to eliminate the excess wire from wadding up in the wings when they're plugged in.
Old Dec 27, 2011, 10:18 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Covering is Underway and Progressing Nicely
Most of the cover is on. Still need to do the fuselage bottom. Then will get the trim ordered and go to work on the engine details.
PAT
Old Dec 27, 2011, 10:25 AM
Cobra Driver
Joined Dec 2005
LOOKING GOOD!!!! Woo Hoo! Getting closer and closer by the minute!
Old Dec 29, 2011, 02:33 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Pat,
When you install your battery tray and mount on this build, could you please include a few detail shots. I am near the point of installing the battery on my Rapide and I would like to see your standard technique for battery mounting so that I can "borrow" it.
As usual beautiful job of covering and elegant servo wiring solution for upper wing center section (post #39)
Robert R
Robert R is offline Find More Posts by Robert R
Latest blog entry: Hidden Kit Built Projects
Old Dec 30, 2011, 09:03 AM
RandyL is offline
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Red, I never did finish the spray bars, they hang in the garage.. I couldn
t bring myself to cut the covering up to make mounts for the tubes.
Smoke still looks good enough for now. If I ever tear it up and have to do repairs I will make mounts for the tubes.
Randy
Old Jan 03, 2012, 10:08 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Now that the Hillidays are Behind Us, it's Time to get Back to It
The week between Christmas and New Years was a bit hectic, but I was able to sneak in a bit of bench time and make a bit of progress.
Once the fuselage was covered, the next step was to get the canopy assembly in place. The sub-frame was glued in place, then the upper foam block was glued in place and shaped.
The rear side fairings and window frames were made up from File folder paper next. The fairings were glued in place first, then the windows glued to the inside of the frames, and those assemblies glued in place to complete the canopy assembly. All of the fairing and window frame patterns will be provided on the plans, so your's will go much quicker then this one did.
Old Jan 03, 2012, 10:14 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Rigging the Wings
The cabane struts were glued into the fuselage mount blocks, then the wings were plugged in and set up and the center section glued in place. The c-section was tacked in place with a drop of thin CYa, then secured with a small drop of 5 minute epoxy at all four points.
Once the glue was cured, the wings were removed and the top of the C-Section covered and the servo lead run into the fuselage. And wile the wings were off, the trim was added using stock vinyl sheet from Callie graphics.
Finally, the wings were put back on and the Interplane Struts re-fitted and glued in place and the rigging added. Once that was done, the tail section was aligned and glued in place.
Old Jan 03, 2012, 10:20 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Painting the Components
Now that all the rigging is done and the canopy, struts, tail blocks and other small parts are in place, all those items were painted using Model Master Acryl.
Cool Pilot Busts 1/8 Scale and 1/12 Scale MPS86 Slope 27 Oct 30, 2015 12:20 PM
Question New possible kit - 1/16 scale Grumman Goose zbrubaker Waterplanes 65 Nov 04, 2012 04:35 PM
Sold Painted Pilots for Warbirds in 1/5 or 1/6 scale $12.50 unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Dec 16, 2011 05:05 PM
Sold JDB Aerotech Grumman f3f 1/12 scale wirecut foam kit planewrecker Aircraft - Fuel - Airplanes (FS/W) 1 Aug 15, 2011 03:33 PM
Discussion Large Scale Ag-Cat ChrisVon Foamies (Scratchbuilt) 5 Aug 26, 2009 10:31 PM
