Old Dec 21, 2011, 08:54 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Top Wing Began with the Center Section
The wings will plug in in pairs, with the center section being permanently attached to the cabanes. Again, there's nothing fancy here, just the standard "egg-crate" style spar and rib set up.
P. Tritle is offline Find More Posts by P. Tritle
Old Dec 21, 2011, 09:02 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Top Wing Panels
The wing panels are also of the "egg-crate" style construction, so they go together quickly. The tips are set up so that for those who want to go with the rounded style tips can by using the supplied tip plates. But if the preference is for the squared off style, simply cut the spars off outside the last rib and glue a 1/32 balsa skin over the end rib to stiffen it so the cover won't draw it in when shrunk.
Old Dec 21, 2011, 09:04 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Filling In the Ailerons
The ailerons are built into the panels and will be cut out and shaped once the assembly comes off the board.
From here we'll shape up the top wing assembly, then get the bottom wing framed. Stay tuned, things are moving along quickly now!!!
PAT
Old Dec 21, 2011, 09:45 AM
RedTwilight is online now
Find More Posts by RedTwilight
Cobra Driver
RedTwilight's Avatar
United States, NC, Hurdle Mills
Joined Dec 2005
Lookin Great! When can I order! LOL
One thing about the wing tips though. For the squared off version shouldn't that be another bay at the end of the wing instead of just cutting the spars flush with the last rib? That's the way I am going to do it. But it's no problem for me to cut out an extra wing rib. So that is what I'll be doing.
I am enthralled by the look of the extended tail/ rudder. So I may have to modify the plans and build that tail.
Got my card in hand waiting to order as soon as it's all finished up and ready to go!
RedTwilight is online now Find More Posts by RedTwilight
Old Dec 21, 2011, 11:51 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
WOOHOO! Can't believe I missed this one.
SteveC68 is offline Find More Posts by SteveC68
Old Dec 21, 2011, 01:11 PM
bassfisher is offline
Find More Posts by bassfisher
The Balsa Farmer
bassfisher's Avatar
United States, AR, Sherwood
Joined Jul 2005
Pat - looking great, Are you going to try to bring it to SMALL in 2012?
bassfisher is offline Find More Posts by bassfisher
Old Dec 22, 2011, 01:49 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Framing the Bottom Wings
The bottom wings go together just like the top except thet're quicker and easier without the servo mounts. The parts were all laid out and assembled, then pinned in place ofer the plans and glued.
Old Dec 22, 2011, 01:51 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing the Wing Assembly
After the major components were in place the leading and trailing edges were added. The root fairings were added last so that the wing conforms to the curvature in the fuselage when the wings are plugged in.
Old Dec 22, 2011, 01:54 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Aileron Assemblies
The ailerons were assembled into the wing panels before the wings were lifted from the board. Then the last addition was the leading edge turbulator spars. At this point, the top and bottom wings are framed and ready to shape and sand.
Old Dec 22, 2011, 01:56 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing the Wings
The leading edges were carved and sanded to shape, then the entire assembly was rough sanded. The ailerons were removed and the final shaping done. The ailerons were then hinged and dry fitted onto the wing panels. The last step was then to add the brass joiner tubes on all four panels.
Old Dec 22, 2011, 02:00 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Building Up the Cabane and Interplane Struts
The interplane struts were framed using the laser cut parts and sanded to shape. The Cabanes were vent to shape, jigged up and soldered together. Now we're ready to fit the wings.
Old Dec 22, 2011, 02:04 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Wings
The top wing C-section jig was cut from artists foam board and pinned to the fuselage centerline. The cabans struts were plugged in and the C-section taped to the jig. The wings were plugged in and the interplane struts dry fitted and the alignment checked. So far, so good. At this point, all those parts are starting to look like and airplane -- and a BIG airplane to boot!
Next up is to get the wing servos mounted and the wiring run in, then she'll be ready for the final detail sanding and cover.
PAT
Old Dec 22, 2011, 07:11 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Pat,
The Ag Cat has big, burly, junkyard dog good looks. Loved how you made the root rib fit up with the fuse. This is a remarkable job on a remarkable subject.
Robert
Robert R is offline Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old Dec 23, 2011, 07:28 AM
old navy is offline
Find More Posts by old navy
memphis TN
Joined Sep 2003
SMALL could be expensive this next year. An Ag Cat and a Storch (hopefully) and a ? and a ? and a ?. I can hardly wait!
old navy is offline Find More Posts by old navy
Old Dec 23, 2011, 10:01 AM
expat flyer is offline
Find More Posts by expat flyer
Toulouse
Joined Jan 2007
If anyone wants to give it the Maltone treatment, try this link
http://www.primeportal.net/hangar/do...ag-cat_n8882h/
Jerry
expat flyer is offline Find More Posts by expat flyer
Question New possible kit - 1/16 scale Grumman Goose zbrubaker Waterplanes 66 Apr 08, 2016 08:15 AM
Cool Pilot Busts 1/8 Scale and 1/12 Scale MPS86 Slope 27 Oct 30, 2015 11:20 AM
Sold Painted Pilots for Warbirds in 1/5 or 1/6 scale $12.50 unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Dec 16, 2011 04:05 PM
Sold JDB Aerotech Grumman f3f 1/12 scale wirecut foam kit planewrecker Aircraft - Fuel - Airplanes (FS/W) 1 Aug 15, 2011 02:33 PM
Discussion Large Scale Ag-Cat ChrisVon Foamies (Scratchbuilt) 5 Aug 26, 2009 09:31 PM
