Joined Jun 2011
Aurora 9 Transmitters - great price!
Aurora 9 Systems starting at just $289.99!!!
http://www.servocity.com/html/transm..._packages.html Hitec Aurora 9 (Tx only) - $289.99 Hitec Aurora 9 (Tx and Optima 7 Rx) - $348.98 Hitec Aurora 9 (Tx and Optima 9 Rx) - $369.98 The Aurora 9 is a “pure digital” 2.4GHz system for that “connected” feeling. Featuring a large backlit 5.1 inch touch screen display, 30 Model memory, assignable switches and customizable programming menus, the Aurora is a true 3 in 1 radio with sophisticated programming for sail planes, helicopters and all kinds of power planes. With all these features and a price that can’t be beat, there is no doubt the Aurora 9 will become the radio of choice for the most sophisticated pilots. ![]() SEE ADDITIONAL PICTURES BELOW... Features 9 Channel 2.4GHz Signal 30 Model Memory Dual Ball Bearing Gimbals 5.1” Back-lit LCD Screen 8 Flight Conditions 3 in 1 Programming (Acro / Glider / Heli) Digital Trims Model Name Dual Timer Switch Assignability EPA (End Point Adjustments for Servos) Dual Rates Exponential Fail Safe Throttle Lock Engine Cut Three Flight Modes 2 Open Mixes Gyro Gain Throttle Curves Pitch Curves Revo Mix CCPM Mixing Crow Mixing Camber Reflex Programming Features: 5 Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders) Quick Model Options Select (Dual Engine, Retracts gear, Airbrake, Fuel mixture) 7 Point Throttle Curve* Throttle Cut Idle Down Fuel Mixture* Airbrake Airbrake to Elevator Mix** Aileron to Rudder Mix** Elevator to Camber Mix** Rudder to Aileron Mix** Aileron Differential* Aileron to Flap Mix** Camber Mix** Flap Control* 3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)* Snap-Roll (4-Way Switching Multi Direction)** V-Tail** Delta Mix** Ailevator** Advance ACRO Programming Features: 9 wing Type (6 Main Wings, 3 Flying Wings) Five Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders) Quick Model Options Select (Motor, Retracts Gear, Airbrake) Motor Control (Switch on/off)** Airbrake Airbrake to Elevator Mix** Aileron to Rudder Mix** Elevator to Camber Mix** Rudder to Aileron Mix** Aileron Differential* Aileron to Flap Mix** Launch (Stick Position Auto Cut Function)** Camber Mix** Flap Control* 3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)* Butterfly** V-Tail** Delta Mix** Ailevator** Advance Glider Programming Features: 6 Swash Types (90° Type: 1 Servo, 3 Servos, 4 Servos; 120° Type: 3 Servos; 140° Type: 3 Servos; 180° Type: 2 Servos Quick Model Options Select (Governor, Needle Control, Fuel Mixture) 7 Point Pitch Curve* 7 Point Throttle Curve* Throttle Cut Gyro Sensitivity* Needle Control* Swash to Throttle Mix* Rudder to Throttle Mix* Fuel Mixture* Throttle Hold*** Swash Mix (Swash Rate/Calibration )*** Revolution Mix* Governor (Three Rates)* Advance Helicopter Programming Features: * Capable of a Maximum of 24 rates by 8 flight conditions and 3 switch positions ** Capable of a Maximum of 8 Rates by 8 Flight Conditions *** Capable of a Maximum of 3 Rates Using 3-Switch Positions |
| Thread Tools | |
| Sold Hitec Aurora 9 w/bling + 4 Hitec rx's LOWER PRICE $399 & FREE CONUS Shipping! | JBAZ4 | Aircraft - General - Radio Equipment (FS/W) | 8 | Dec 28, 2011 06:49 PM |
| For Sale PRICE DROP!!! NIB Hitec Aurora 9 TX/RX system | airmcn_3 | Aircraft - General - Radio Equipment (FS/W) | 1 | Dec 07, 2011 04:50 PM |
| Sold Hitec Aurora 9, Very Low Price! $240.00 Shipped! | T3beatz | Aircraft - General - Radio Equipment (FS/W) | 10 | Nov 24, 2011 08:03 PM |
| Sold Price reduced - New In Box Aurora 9 Tranny only add Tragi 705 and pay 950 for both. | FLY F3B | Aircraft - General - Radio Equipment (FS/W) | 5 | Nov 09, 2011 11:01 AM |
| Sold Aurora 9 Stock Battery NEW 7.2V 1300mAh Price REDUCED | ZeekWorld | Aircraft - General - Radio Equipment (FS/W) | 3 | Sep 07, 2011 06:27 PM |
