Old Jan 25, 2012, 07:13 AM
mazz738 is offline
Find More Posts by mazz738
Joined Feb 2011
Are the wheels rubber?
mazz738 is offline Find More Posts by mazz738
Old Jan 25, 2012, 02:32 PM
simo71 is offline
Find More Posts by simo71
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
Yes Tires (tyres) are rubber
simo71 is offline Find More Posts by simo71
Old Jan 25, 2012, 03:37 PM
mazz738 is offline
Joined Feb 2011
Lol, I like that two spellings you wrote there for tyres
all the more reason to grab this bird!
Old Jan 25, 2012, 07:29 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Happy to report that the beefier front retract has held up to 4 successful landings on grass today.
The rear retract will be perfect for the front if HobbyKing make it available.
On a side note if you fly from grass all the time remove the rear wheel covers as they can cause trouble when cycling the landing gear.
I had to belly land on one of my landings today as the retract would not open all the way due to catching on the wheel over when opening.
Happy to report that the prop is pretty durable. It held up to a belly landing as well as a mid air collision where it chopped the front off of a p51 mustang. :-0
jim350 is offline Find More Posts by jim350
Old Jan 26, 2012, 03:54 AM
turbinefancy is offline
Find More Posts by turbinefancy
wish for Tomcat....granted!
turbinefancy's Avatar
United States, CA, Irvine
Joined Jun 2009
HK Review Video by Scott
Nice aerobatic in-flight footage. Looks quite lively. Thanks Scott.
HobbyKing Skunkwerks Series - Durafly 1100mm T28 & Skyraider (9 min 55 sec)
turbinefancy is offline Find More Posts by turbinefancy
Old Jan 26, 2012, 04:12 AM
simo71 is offline
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
Brilliant video, the way Scott describes the T-28 is spot on.
Old Jan 26, 2012, 06:32 AM
mazz738 is offline
Joined Feb 2011
finally a review!
Old Jan 26, 2012, 11:15 AM
Bernard is offline
Find More Posts by Bernard
Bernard's Avatar
24100 Sainte Foy des Vignes / France
Joined May 2001
Hi all
material is EPS, EPP or EPO ?
tkanks
Bernard is offline Find More Posts by Bernard
Old Jan 26, 2012, 02:38 PM
simo71 is offline
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
Originally Posted by Bernard View Post
Hi all
tkanks
It's EPO
Old Jan 26, 2012, 02:43 PM
chops3 is offline
Find More Posts by chops3
New Zealand, Canterbury, Christchurch
Joined Aug 2011
Specs:
Originally Posted by yarrumevets View Post
Mine arrived this afternoon, but I had to go out to mow our grass runway so I didn't have time to give the kit a good going-over beforehand. A couple of points which were obvious in the quick look I took were ...
Correct, squeeker - the instructions spend several pages dealing with safety and pre-flight issues (which, we know is important of course) but there's absolutely no information included which deals with wiring to the receiver.
The assembly manual doesn't discuss fitting the linkages between servos and control horns and although someone with experience will work it out, it's probably going to cause some consternation for a complete newb.
Overall, the build quality looks as good as has been reported - very slick surface finish and detailing, general assembly and parts look good. The motor is a "GC 3536 - 850 kV" which sounds about right, but I've not yet put the prop on and fired it up with the Wattmeter included.
Looks good ... more details to follow as I get time tomorrow to put it all together and run it up with a few tests.
750kv Brushless Outrunner
chops3 is offline Find More Posts by chops3
Old Jan 26, 2012, 08:30 PM
chops3 is offline
Joined Aug 2011
props
Hi all what is the size of this prop? and will it take a 2-Blade Prop to Spares arrive? thanks.
steve.
Old Jan 27, 2012, 12:30 AM
yarrumevets is offline
Find More Posts by yarrumevets
Angry Bird ...
yarrumevets's Avatar
Sydney, Australia
Joined Aug 2007
Sorry mate - the prop doesn't have any markings on it at all, or the one on my plane doesn't anyway (which is a bit unusual). I don't have any way of attempting to measure the pitch either.
Yes, you could stick a two-bladed replacement on it however there's a nut on the shaft of the prop adapter which recesses into the stock prop and that would mean that your two-bladed replacement would sit a bit proud. You'd have to do a little experimentation with a selection of props and a wattmeter - certainly have to keep the diameter of a replacement down so that you can maintain ground clearance.
Not a very helpful reply in summary, I'm sorry to say.
yarrumevets is offline Find More Posts by yarrumevets
Old Jan 27, 2012, 01:58 AM
chops3 is offline
Joined Aug 2011
something in the size of a 12x5 or12x8 would be to big?
thanks.
Old Jan 27, 2012, 03:14 AM
Angry Bird ...
Sydney, Australia
Joined Aug 2007
Yep - way too big! The stock prop has a 10" diameter (and I suspect something like a 6.5" or 7" pitch, but that's a guess). As it is, with the stock prop, there is only about 20mm ground clearance. Those props are probably also too big in the electrical sense as well as the mechanical but that too is a guess, because I don't know the KV or maximum current rating of the motor.
You'd be better off with something like a 9.5" x 7.5" - the stock Parkzone T-28 prop would go well.
Old Jan 27, 2012, 02:56 PM
chops3 is offline
Joined Aug 2011
thanks will have to order some of these and try.
the motor is a 750kv will put it on a wattmeter and see what i get.
Discussion MSR upgrades for durability? Next bird? DasFriek Electric Heli Talk 8 Oct 21, 2011 11:29 PM
Discussion Next multiplex bird? ZSimon Electric Plane Talk 9 Aug 19, 2011 10:06 AM
Discussion next plane- trojan or typhoon Kmart Beginner Training Area (Aircraft-Electric) 25 Feb 26, 2009 11:40 AM
Hummingbird-what's my next bird? Want a bigger one... albireo Micro Helis 6 Oct 12, 2003 10:20 AM
