Old Nov 22, 2012, 04:38 PM
Mrgeorgedoors is offline
Find More Posts by Mrgeorgedoors
Mrgeorgedoors's Avatar
United Kingdom, Warrington
Joined Nov 2012
Will have a proper look at it over the wk end. Want to make sure it's right before I take it out. Hope it's something simple. Just have to make do with the funfighters for now
Mrgeorgedoors is offline Find More Posts by Mrgeorgedoors
Old Nov 22, 2012, 04:43 PM
Markbinim is offline
Find More Posts by Markbinim
United Kingdom, England, Leighton Buzzard
Joined Apr 2012
If you do find your retract unit is duff ive a spare here i can post on to you,save you waiting for that slow boat from china
Markbinim is offline Find More Posts by Markbinim
Old Nov 22, 2012, 05:03 PM
GavDorro is offline
Find More Posts by GavDorro
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
Yeah I bought this as a quick replacement for my pz t28 because my ar500 failed and plane crashed into trees and pretty much killed it, i have another to rebuild with the upgraded parts from the crashed one just not got round to doing it yet. Now I have a damaged set of wings I was going to practice the flap mod on them 1st. Just thought these durafly ones were supposed to be decent.
Having seen both the PZ and HK T28 side by side I would have to say the Durafly unit is the pick of the two. PZ one is a bit "floaty" where the durafly one flys with lots of authority. It has a real punch through the air in the heaviest of winds. I consistently fly it in 25km/h +. And importantly, it is fun to fly in those conditions.
How much $ to get the PZ one to the same spec as the durafly?? And it still wouldnt fly as good!
Stick with it. It will be worth the wait!
GavDorro is offline Find More Posts by GavDorro
Old Nov 22, 2012, 05:18 PM
Joined Nov 2012
That would be awesome mate. I'm out flying tomorrow so will deffo look at it over the wk end
To be honest I bought my pz cheap 2nd hand practically new condition. Then a month later i bought another one with uprated motor and turnigy 60esc for 80 and bought some 4s batteries. Only flew it once on 4s before ar500 decided to die and so did the plane but it was fast and just climed and climed like you wouldn't beleive. So looking forward to rebuilding that one just not lookin forward to painting it again.
But I agree side by side the durafly is the better looking bird and can tell it will fly much better with the weight although my pz did have quite a bit of weight added to it with the heavier motor and had to upgrade the mount also as that snapped 1st time out once I'd changed it.
I will stick with it and hopefull get it sorted ASAP as it doin my head in just looking at the thing.
Old Nov 22, 2012, 07:28 PM
rooni79 is offline
Find More Posts by rooni79
Bathurst, NSW, Oztralia
Joined Mar 2011
Hi Gents,
In around March, I had a nose in due to brown out, and that snapped my front retract. I replaced with a metal trunnion etc, but it never worked well after that.
I bought a parkzone tricycle retract set and pt the nose one in the durafly. I just used the dremel to cut out the posts etc and screwed the pz retract straight into the base. pretty straight forward and hopefully will have me flying this bird again
rooni79 is offline Find More Posts by rooni79
Old Nov 23, 2012, 07:29 AM
Joined Nov 2012
Well I got a reply from hk saying they couldn't view the video I sent so have just done another and sent that over. Backlog of complaints apparently.
Had another quick look while I was doing it not still not sure where the play is coming from and it doesn't quite extend fully. Hope this gets sorted by them or I could have fixed it myself and be flying it nice day today for it too
Old Nov 23, 2012, 07:31 AM
J_Cunny is offline
Find More Posts by J_Cunny
Austin, TX.
Joined Feb 2008
Hi guys
I received my durafly t-28 last Friday and was well chuffed, very nice plane and feels a lot sturdier than my pz t-28. However, after putting it all together and then as you do, you want to test the retracts, I did and noticed than one of them doesn't quite look straight, the retract seems to extend fully but has a little play in it..and the flap servos are very noisy and kept chattering
I feel your pain. I had same issue and end ponts and expo did nothing to solve it. I ended up replacing them with a very reasonably priced HiTech servo on both wings ( I don't remember the model number but they are the clear Blue ones.. About 10 bucks apiece). As far as the "slow/reduced servo speed" thing goes, my Futaba 7c uses a rotary knob for flaps, so I have control that way of speed, I also have dual rates if I want to play around with it.
As far as the gear goes,THAT is the major issue with this bird!!! Why on earth would anybody would think that the plastic trunion would hold up, in all honesty, is truely "special". Couple that with the fact the metal unit has to be created, is also a pain. I have fixed mine, after all it is a "mechanical" hobby after all. However, it is disappointing to get one out of the box and have issues. I would think they will get back with you on this...eventually, again however, you might not get the resolution that you are after...
My thoughts,
JC (fellow Platinum level member at HK)
Austin, Tx
J_Cunny is offline Find More Posts by J_Cunny
Old Nov 23, 2012, 10:54 AM
Joined Nov 2012
As far as the gear goes,THAT is the major issue with this bird!!! Why on earth would anybody would think that the plastic trunion would hold up, in all honesty, is truely "special". Couple that with the fact the metal unit has to be created, is also a pain. I have fixed mine, after all it is a "mechanical" hobby after all. However, it is disappointing to get one out of the boxy and have issues. I would think they will get back with you on this...eventually, again however, you might not get the resolution that you are after...
My thoughts,
Austin, Tx
Well If it comes to it I can take mark up on the offer of the retract and I have servos I could use off my pz t-28 that I totalled a few wks back I'm sure they'll do the job. What's the other main issues with this bird apart from the servos and the faulty retract? Seem to have seen a few mention the nose wheel too?
Old Nov 23, 2012, 05:44 PM
J_Cunny is offline
Austin, TX.
Joined Feb 2008
The mains are fine, the nose gear sucks!!!!
Old Nov 23, 2012, 11:00 PM
Joined Nov 2012
In what way? And what's the alternative?
Cheers
Rod
Old Nov 23, 2012, 11:16 PM
Joined Apr 2012
Cheers
Rod
the servo in the nose wheel has a plastic trunnion,even with the worlds best landings this will break eventually.it will need to be swapped for a metal trunnion but this will require further modding
Old Nov 24, 2012, 04:17 AM
buellbruce is offline
Find More Posts by buellbruce
buellbruce's Avatar
Australia, NSW, North Richmond
Joined May 2011
Mine lasted about 5 landings before breaking Just did the metal trunnion mod to the original mechanism and with a bit of filing and fiddling, it works great!!
Flew it this morning and landed heaps of times and no problem. Wish Hobbyking would just do the mod before selling it!!
buellbruce is offline Find More Posts by buellbruce
Old Nov 24, 2012, 05:21 AM
Joined Nov 2012
That's a bit poo. So what u guys replacing it with ? I may as well try get these done while its still grounded.
Old Nov 24, 2012, 05:43 AM
buellbruce's Avatar
Joined May 2011
go back to #734 thats the part i used and worked fine. I also bought two of the complete hobbyking retracts but didnt use them as it was pretty easy to swap the trunnion over on the original unit.
Old Nov 24, 2012, 05:47 AM
buellbruce's Avatar
Joined May 2011
Video from cockpit and above cockpit on Durafly T28 Trojan (0 min 0 sec)
Flight from this morning, viewed from inside the cockpit and on top of the cockpit. This is one fun plane to fly ) Video should be on in an hour...
Discussion MSR upgrades for durability? Next bird? DasFriek Electric Heli Talk 8 Oct 21, 2011 11:29 PM
Discussion Next multiplex bird? ZSimon Electric Plane Talk 9 Aug 19, 2011 10:06 AM
Discussion next plane- trojan or typhoon Kmart Beginner Training Area (Aircraft-Electric) 25 Feb 26, 2009 11:40 AM
Hummingbird-what's my next bird? Want a bigger one... albireo Micro Helis 6 Oct 12, 2003 10:20 AM
