Old Nov 04, 2012, 04:52 AM
Markbinim is offline
Find More Posts by Markbinim
United Kingdom, England, Leighton Buzzard
Joined Apr 2012
Originally Posted by yarrumevets View Post
I put 1800 mAh 4S nanotech batteries in it - they weigh almost exactly the same as the 2200 mAh 3S types so I'm not changing the wing-loading or CoG at all. I keep the high-speed bursts to about 15 seconds duration and it's really good fun. It cruises at about 60% throttle. Highly recommended.
The only hassle I've been having is with my nosewheel retract - I did the metal trunnion upgrade and have had four faultless flights since, but today on the fifth flight the nosewheel decided to jam about one-third the way down when I was extending the gear to land (the mains where fine). I tried them up and down another three times, then inverted to see if that could free the jam - nothing doing. I had to put the mains up and bring her in for a gear-up belly-landing. Don't know what the problem is - when I got back from the field I was tired and it has been a really warm day so I got into the beers - the plane can wait until tomorrow
could be that the leg has slipped up a fraction and is catching the traveler bit on the worm gear??
Markbinim is offline Find More Posts by Markbinim
Old Nov 04, 2012, 05:01 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I plan to fly mine with Rhino 2250 3S. I've now got some 2200 4S that weigh almost the same so I may try these.
Can the stock setup handle 4S?
I've got an uprated ESC spare but not a motor...
SilentPilot is offline Find More Posts by SilentPilot
Old Nov 04, 2012, 05:02 AM
yarrumevets is offline
Find More Posts by yarrumevets
Angry Bird ...
yarrumevets's Avatar
Sydney, Australia
Joined Aug 2007
Cheers Mark - it's possible, for sure. I'll be sure to look for that as soon as I get the little devil open for inspection.
yarrumevets is offline Find More Posts by yarrumevets
Old Nov 04, 2012, 05:04 AM
Angry Bird ...
Sydney, Australia
Joined Aug 2007
Here you go mate ... and your French is probably better than mine:
http://www.bungymania.com/imageshome...rf1.php?id=134
Old Nov 04, 2012, 06:02 AM
BMFA 190658
Joined Mar 2007
My French is quite poor too!
The table came in handy though, cheers. I'm not keen on dropping to 2blade prop so it looks like I'll have to sacrifice some speed. Good thrust though!!
Tony
Latest blog entry: Spitfire mk1a
Old Nov 04, 2012, 06:17 AM
Angry Bird ...
Sydney, Australia
Joined Aug 2007
I just stuck with the stock prop Tony, and no regrets - however, I've been too lazy to look seriously at alternatives, I must admit.
Cheers,
Steve
Old Nov 04, 2012, 09:43 AM
BMFA 190658
Joined Mar 2007
Yeah same here, too lazy!
Plus the stock prop really suits this plane so it's staying
Old Nov 04, 2012, 10:15 AM
Flying By is offline
Find More Posts by Flying By
Canada, MB
Joined Feb 2012
Originally Posted by pghosh View Post
For those of you who have tried the metal trunion, how effective of a solution is it? Do you still suffer broken front retracts with with the metal trunnion?
I sent away for the metal trunion from PW. By the way, if you ask, they will file the pieces for you so they fit when you get them. (o ring) I never completed the installation since the ledes on the wire came off the board on the retract.
Second question: Does anyone know which replacement shaft is needed to fit a single blade prop??? Would think it has to be a replacement shaft without the hex on it. What is the best way to fit a single blade and what have people tried? Was thinking 10 8.
So far I have had great success with the metal trunnion mod. Probably have 60-70 flights with it.
Flying By is offline Find More Posts by Flying By
Old Nov 05, 2012, 06:59 PM
AlphaWhisky is offline
Find More Posts by AlphaWhisky
Alpha Whisky
Queensland - Australia
Joined Jan 2006
I bought one of these recently as an impulse buy and it has become a can of worms.
I note that many are having problems with the nose retract but I haven`t got that far yet .... My problem is that I just can`t get it to fly.....!
Our regular strip is 'grabby' grass - not like the sealed strips and country roads in much of the video here - and although that certainly is not a positive. The model will get up to a decent speed but just will not rotate. I reckon the nose leg is too short and the angle of attack sitting on the deck is all wrong....
My first reaction with the model back on the bench was to put a packer, say 6mm thick, under the retract unit, but I suspect from reading about front retract problems here that it might not be as simple as that...
I`ve spent quite some time in this thread looking for clues but not found a solution as yet.
Has anyone else had this problem and come up with a practical fix?
Alan W
AlphaWhisky is offline Find More Posts by AlphaWhisky
Old Nov 05, 2012, 07:10 PM
Canada, MB
Joined Feb 2012
Alan W
That is strange...this bird pops into the air quickly and flies like a dream. Something must be amiss with yours.
Try with flaps down?
Sure the elevator is moving properly, direction and amount?
Old Nov 05, 2012, 07:36 PM
Joined Apr 2012
Alan W
i fly off quite rough grass and have had a few flights(when the grass is quite nasty)where my t28 has traveled a long way down the field before its got up,but its never not made it
i guess it must be the grass in my case as when its freshly cut she jumps in the air real quick.
mark
Old Nov 05, 2012, 07:57 PM
Angry Bird ...
Sydney, Australia
Joined Aug 2007
I usually fly off very short grass and it's never wanted to stay on the ground.
Whisky - you do have a point when you talk about the front leg appearing to be short though. If I place my PZ T-28 next to it so I've got them both side-by-side, the Durafly does seem to have a negative incidence. I'm going to give that some attention when I get around to pulling mine all apart after last weekend's foray.
Old Nov 05, 2012, 10:05 PM
Force10 is offline
Find More Posts by Force10
Australia, NSW
Joined Mar 2011
Alan W
I takeoff from the grass runway as well never had any issue with TO. I would suggest to look at the thrust angle of your aircraft ,have you touched the firewall or motor since you bought it. It hardly need 3 -4 meters to get in the air .
Force10 is offline Find More Posts by Force10
Old Nov 06, 2012, 12:42 AM
Alpha Whisky
Joined Jan 2006
Thanks for the input guys - some food for thought among it. I was right - the packer thing didn`t work. Although the model sat better on the ground, and the AOA thing looked better, the nosewheel would not fully retract into the well and the doors wouldn`t shut. I removed packers and went back to original.
I had previously noted that both the rudder and elevator servo arms were both set up on the middle of three holes and the throw on both surfaces was less than I would usually settle for so I have changed both of them to the outer holes. Elevator throw now looks better but the rudder could maybe use more, but that is not the problem here.
I haven`t played with the motor thrust line in any way, but if pressed I might reckon there is a hint of downthrust there. I`ll worry more about that after I have another go tomorrow with the increased elevator throw and this time I will try with some flaps down......
Alan W
Old Nov 06, 2012, 02:55 AM
BMFA 190658
Joined Mar 2007
Would it sitting low at the front be such a problem?
Surely it would just rotate onto the mains for a short while then takeoff, like the big boys do...
Discussion MSR upgrades for durability? Next bird? DasFriek Electric Heli Talk 8 Oct 21, 2011 11:29 PM
Discussion Next multiplex bird? ZSimon Electric Plane Talk 9 Aug 19, 2011 10:06 AM
Discussion next plane- trojan or typhoon Kmart Beginner Training Area (Aircraft-Electric) 25 Feb 26, 2009 11:40 AM
Hummingbird-what's my next bird? Want a bigger one... albireo Micro Helis 6 Oct 12, 2003 10:20 AM
