Old Jan 15, 2012, 02:11 PM
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
Originally Posted by miketre View Post
I am quite surprised that this is the slowest moving thread among the threads on the Durafly warbirds. Is it really not as popular as the others?
Well the T-28 is the only one that's out of stock, if that's any indication...
herk1 is offline Find More Posts by herk1
Old Jan 16, 2012, 05:30 PM
Joined Aug 2011
Received my T28 Trojan yesterday and assembled it last night.
Quality of this kit is excellent. Went together very easily.
Only modification required was a little foam removal to fit my battery and adjustment of the elevator linkages.
looking forward to the maiden this weekend.
Durafly T28 Trojan (0 min 34 sec)
Hope to get some video of the Trojan on the weekend
jim350 is offline Find More Posts by jim350
Old Jan 20, 2012, 09:20 PM
Joined Aug 2011
Maiden of the trojan went reasonably well.
Take off on grass was not a problem with then stock gear. Got up in the air and It only needed a little left trim and was all good.
This trojan flys really nice. Nice and stable in the air and will happily fly around at just half throttle.
Tested out the flaps for landing and they do slow the plane up nicely.
Landing needs a little throttle so that you can keep the nose up.
Maiden flight had a perfect landing, second flight's landing had the front gear touchdown first and broke the front retract :-(
I have been able to repair it and will see how it holds up, however i think it will need a stronger unit like the main retracts.
Front retract has plastic pivot point where as the main gear has metal.
Overall this is a great plane and flys beautifully out of the box. Highly recommend too anyone looking at getting a t28 trojan.
T28 trojan maiden (5 min 1 sec)
Old Jan 20, 2012, 09:58 PM
Perth, WA
Joined Jul 2006
Jim,
I just got around to prepping my Durafly T-28 for a maiden maybe later today as it's gusting like crazy right now despite it being close to 40 degrees Celsius...
As with the FMS T-28 I have I have notice my flaps do not move all that much, from your video my maximum flap position seems to be around where yours are in position one.
Perhaps it is me doing something wrong and I was told I might have to rehinge the flaps on the FMS version but now I see it just might be an error on my part. BTW I have set the throw on the flaps to 100% in radio
Any help will be much appreciated!
Same is offline Find More Posts by Same
Old Jan 20, 2012, 11:16 PM
Joined Aug 2011
I noticed the same thing when setting mine up.
on my dx8 if i set the wing type for normal, i get full travel for the flaps.
if i set the dx8 to 1 aileron/ 1flap i get half the travel like you have indicated.
i think they have designed the plane this way to be used on a standard radio and as such the flaps don't need to be configured in my dx8.
if i were to change the flap servos to standard units i suspect they would operate as they should under the correct 1 aileron / 1 flap setting.
good luck with your maiden.
Old Jan 21, 2012, 06:25 AM
Angry Bird ...
yarrumevets's Avatar
Sydney, Australia
Joined Aug 2007
Same and Jim - have you maxed out the mechanical gain by putting the control rod in the outermost hole on the servo arm and the innermost hole on the flap horn?
yarrumevets is offline Find More Posts by yarrumevets
Old Jan 21, 2012, 06:35 AM
I don't want to land yet!
Strike3's Avatar
Adelaide, Australia
Joined Jan 2010
Jim350's maiden from a different view...
http://youtu.be/J4gWknDjtx8?hd=1
Strike3 is offline Find More Posts by Strike3
Old Jan 21, 2012, 06:56 PM
Flying from Vic Park
Australia, SA, Adelaide
Joined May 2011
Strike3, what is the Adelaide Arena site like to fly at? Does the council give you any grief?
Great_Goose is offline Find More Posts by Great_Goose
Old Jan 21, 2012, 07:27 PM
Perth, WA
Joined Jul 2006
Yes, using 125% throw on the radio now still not a whole load but it'll do.
Old Jan 21, 2012, 09:29 PM
Angry Bird ...
Sydney, Australia
Joined Aug 2007
OK - thanks for the reply.
Old Jan 22, 2012, 07:26 AM
Perth, WA
Joined Jul 2006
Okay, so here is how much the flaps move at the moment
Untitled (0 min 27 sec)
Should I leave it at this and be done with it?
Old Jan 22, 2012, 07:44 AM
phoenix racing's Avatar
United Kingdom, England, Ipswich
Joined Mar 2007
Just move the servo arms backwards of you want more, I must admit, I didn't really use any more when I test flew it.
phoenix racing is offline Find More Posts by phoenix racing
Old Jan 22, 2012, 07:52 AM
miketre's Avatar
Joined Dec 2010
Same, that looks like half flaps only.
You can try to program a mix for Flaps to Flaps.
If you put this on a different switch, you can effectively get 1 more additional level of flaps.
miketre is offline Find More Posts by miketre
Old Jan 22, 2012, 07:55 AM
Joined Mar 2007
No, look at the position of the horns, it looks like an assembly error, they are neutral rather than at the rear....programming won't help.
Old Jan 22, 2012, 08:03 AM
miketre's Avatar
Joined Dec 2010
yes, you are right. I just went back and look at the my P-51, and it was installed incorrectly too.
Programming may still help depending on which Tx it is.
On my DX8, the flaps channel don't give as much travel as the other channels.
The flaps control rod on Same's T-28 also appears to be connected to the outermost hole on the flap horn - move it to the innermost hole.
Discussion MSR upgrades for durability? Next bird? DasFriek Electric Heli Talk 8 Oct 21, 2011 11:29 PM
Discussion Next multiplex bird? ZSimon Electric Plane Talk 9 Aug 19, 2011 10:06 AM
Discussion next plane- trojan or typhoon Kmart Beginner Training Area (Aircraft-Electric) 25 Feb 26, 2009 11:40 AM
Hummingbird-what's my next bird? Want a bigger one... albireo Micro Helis 6 Oct 12, 2003 10:20 AM
