Old Feb 22, 2012, 02:16 AM
yarrumevets is offline
Find More Posts by yarrumevets
Angry Bird ...
yarrumevets's Avatar
Sydney, Australia
Joined Aug 2007
Originally Posted by GavDorro View Post
I assume it is standard practise to mix in down elevator with flaps down to counteract balooning?
I did mix in a little down-elevator, just a couple of degrees. It's interesting because when you hit the flaps switch you get all of your down elevator immediately, but your flaps only descend slowly (as they're supposed to) with the servo-slow installed. So you'll get a momentary down pitch when you hit the switch, but it's not a problem - just something to be aware of if you don't anticipate it.
Do some also mix up elevator with undercarraige down to counteract increased drag?
Nah - it's not significant, or at least not to me. So I didn't bother with that.
Congrats and good luck with everything!
Steve
yarrumevets is offline Find More Posts by yarrumevets
Old Feb 22, 2012, 09:10 AM
Azka Anindya is offline
Find More Posts by Azka Anindya
Indonesia
Joined Feb 2012
Mine just assambled today. Actually I bought also the replacement retract and metal trunnion, but even the trunnion fit perfectly on the original retract but can not close properly because of the stopper too big. Also I also tried put the replacement retract to the chamber but too big also, need modification at the screw holes.
So please upload the images of the retract modification ( with bigger retract replacement ) inside the front chamber and or how to modification the stopper in order to make retract can work perfectly with metal trunnion at original retract . ...
Hopely maiden fly this saturday with modification of front retract. ..
Azka Anindya is offline Find More Posts by Azka Anindya
Old Feb 22, 2012, 02:03 PM
chops3 is offline
Find More Posts by chops3
New Zealand, Canterbury, Christchurch
Joined Aug 2011
Originally Posted by Bloke330 View Post
Chops3,
Are you serious that HobbyKing will sell spare props soooooooooooooooooon?????
Can't wait!!!!....
so thy say.
chops.
chops3 is offline Find More Posts by chops3
Old Feb 22, 2012, 03:09 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Pics for mods required for metal trunnion installation on the stock retract can be found in post #147 in this thread.
As for fitting the larger retract you need to redrill the holes in the top plate of the retract, make up some spacers, readjust steering linkages and remove some material from the retract mount. if your were unable to figure any of that out yourself i suggest you do not try the modifications required to fit the larger retract.
jim350 is offline Find More Posts by jim350
Old Feb 22, 2012, 05:20 PM
rooni79 is offline
Find More Posts by rooni79
Bathurst, NSW, Oztralia
Joined Mar 2011
I got the wiring sorted. Half my battle was that the Orange rx had the sticker on the wrong way, and as a result the bind plug was in the wrong end! Also one of the triple harnesses was not working so I don't have lights at the moment.
Does anyone have any probs with the hatch not shutting properly when the battery is in? I think I will have to carve some foam to get it to shut properly.
rooni79 is offline Find More Posts by rooni79
Old Feb 22, 2012, 05:50 PM
rooni79 is offline
Joined Mar 2011
Oh, and I ordered a MAS 10x5 3 blade prop from a LHS so I can see whether it is a match. Cost me $22 with postage for 1 prop. Ouch.......
Old Feb 22, 2012, 06:33 PM
jim350 is offline
Joined Aug 2011
i carved some foam out of the canopy so that it would close properly.
Old Feb 22, 2012, 07:13 PM
Indonesia
Joined Feb 2012
Chops3,
Can't wait!!!!....
Thanks jim, ooo yea drill the plate. Anyway with the stock retract, which parts broken in nose landing, the plastic trunnion ?
Old Feb 22, 2012, 08:48 PM
jim350 is offline
Joined Aug 2011
yes just the plastic trunnion broke on mine.
Old Feb 22, 2012, 09:40 PM
chops3 is offline
Joined Aug 2011
prop tests
Durafly T-28 Trojan prop tests
tests, measured with my old HK meter.
useing all Master Airscrew propellers.
all test were with full chargers on batterys.
test with STD prop that came with T28.
peak: about 30.4A
with 323 watts give or take
on 3 S 2200ma
10.7 MAS Prop 3 Blade
peak: about 21.4 A
with 226 watts give or take
on 3 S 2200ma
9x6 MAS prop 2 Blade
peak: about 15.3 A
with 165 watts give or take
on 3 S 2200ma
Old Feb 22, 2012, 09:56 PM
balch is offline
Find More Posts by balch
san jose,ca
Joined Jun 2001
Will the MAS fit in the original prop adapter? If not how did you mount the MAS?
Would also be interested on ways to mount a 2 blade. I cut down the original prop and use it as a spacer in the original prop adapter. Must be a better way!!!
balch is offline Find More Posts by balch
Old Feb 23, 2012, 12:45 AM
chops3 is offline
Joined Aug 2011
sorry made a boo boo the 10x7 prop was not Electric
and yes had to use heaps of washers to fill gap.
Old Feb 23, 2012, 12:46 AM
chops3 is offline
Joined Aug 2011
peak: about 30.4A
on 3 S 2200ma
peak: about 21.4 A
on 3 S 2200ma
peak: about 15.3 A
on 3 S 2200ma
Old Feb 23, 2012, 01:17 AM
Indonesia
Joined Feb 2012
thanks again, so the choices are metal trunnion on stock retract or larger retract replacement ? Which one better jim ? Is it http://www.hobbyking.com/hobbyking/s...stem_1pc_.html can handle nose landing well ?
cheers
Old Feb 23, 2012, 03:32 AM
jim350 is offline
Joined Aug 2011
Im my opinion the metal trunnion is better
Discussion MSR upgrades for durability? Next bird? DasFriek Electric Heli Talk 8 Oct 21, 2011 11:29 PM
Discussion Next multiplex bird? ZSimon Electric Plane Talk 9 Aug 19, 2011 10:06 AM
Discussion next plane- trojan or typhoon Kmart Beginner Training Area (Aircraft-Electric) 25 Feb 26, 2009 11:40 AM
Hummingbird-what's my next bird? Want a bigger one... albireo Micro Helis 6 Oct 12, 2003 10:20 AM
