This thread is privately moderated by Peter M, who may elect to delete unwanted replies.
Old Mar 06, 2012, 01:25 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
LOL!
Sorry Steve C to cause confusion, I was actually refering to the other Steve aka heliclown!
Peter M is offline Find More Posts by Peter M
Old Mar 06, 2012, 01:48 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Oops, sorry
I'm just looking at 5s batteries. 2650's are probably about right, or 65c 2250's, but those cost quite a bit.
Steve C is offline Find More Posts by Steve C
Old Mar 06, 2012, 03:30 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Steve C,
I've been using Turnigy 30 or 40C batteries for testing and trying out new things because they are cheap, available quickly here locally and have been holding OK voltage under load. ( I note one of the regular and usually very critical F5B RCGroupers have found these cells perform as well as the 65C TP but they had to resolder the tabs to handle the 250+amp loading. Admitedly the TP's are ready to go straight out of the box without modification.)
Best bit is that if my great idea doesn't perform as hoped or the battery just plain doesn't fit, I don't feel like I've wasted too much money!
Please post your 5 cell logs!
Peter
Old Mar 06, 2012, 03:39 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Id hazard a guess and say some of the turnigy 30C cells are good some are absolutely terrible.
I have 3 near new 30C 1800 2S, in a 200W pylon racer, 27A at full load static. If I go full throttle, and then put in full aileron, the LV alarm kicks off! They also dont hold balance at all, probably the worst lipos ive ever bought
http://www.hobbyking.com/hobbyking/s...idProduct=9368
5 star my ass
jackosmeister is offline Find More Posts by jackosmeister
Old Mar 06, 2012, 04:02 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Jacko,
You mean a score of: (__!__) (__!__) (__!__) (__!__) (__!__)
Old Mar 10, 2012, 04:27 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
why would you not use nanotech? seriously they are freaking nuts and cheap as chips.
brosius85 is offline Find More Posts by brosius85
Old Mar 10, 2012, 02:29 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Nano's are what I normally use but because they come from OS, there is usually a two week delivery delay.
I've been using the locally available Turnigy 30C's for experimenting with different sizes since they are cheap and in my letterbox within 3 days.
I actually had my first Turnigy battery failure yesterday when a track on the battery circuit board melted/cracked, causing my Plasma to lose all power and land ungracefully into the swamp! Fortunately no damaged and I've repaired the battery by soldering on a copper wire "jumper".
The weather looks good today so off to do some more "testing" right now!
See ya!
Old Mar 12, 2012, 02:33 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
F5D Folders
More updates: http://www.rcgroups.com/forums/showp...3&postcount=12
Old Mar 13, 2012, 04:47 PM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Good info Peter.
Looks like we'll have lots of options soon.
Old Mar 17, 2012, 11:20 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Old Mar 24, 2012, 03:17 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
I'm always impressed with Mreyello's advice.
Here is a recent post that I found interesting. Not necessarily about geared folder setups, but worthwhile advice on where to spend your money for best effect for budding speedsters: http://www.rcgroups.com/forums/showp...9&postcount=75
Old Apr 03, 2012, 04:30 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Admittedly small but will be significant.
Old Apr 05, 2012, 06:57 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
I've Been Wondering......
I've been wondering how you could run the GM 10x23 blades on a 3100 or higher kV motor with 5.2:1 gearing for a minute continuously and not melt down the motor.
Since no one seems to provide much in the way details for these setups I've been planning on buying my own set to test out.
However a reliable source bought one recently and had this to say:
" I just measured the props from Bulgaria........ Pitch on the blade decreases rapidly to the hub, at 50mm out from center it has only 12” pitch on a 23” pitch prop, surely this must mean they would be flying at large negative angle to the airflow at speed, also the tip pitch reduces a lot, the 23” is only seen for about 5mm of the blade."
Consequently I've stopped waiting for them to come into stock at SUSA and will have to consider a ajaeromodels setup, just use my Koch blades or will wait for something else to come along.....
EDIT 17 April 2012 - Got a second opinion on the GM 10x23's : "...... it's not a great design in that the pitch distribution is unusual. In fact the prop performs more like a 10x21 and drains the battery like a 12x26..."
Old Apr 06, 2012, 04:24 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Current State of the Art - Sawtooth Props
Hunting around indicates that not much appears to have progressed beyond the improvements that Paul S and Co made in 2011. You will recall the blades from the 2010 Muncie WC's used a conventional spinner and blade roots.
I know others have tested similar blades but no one appears to have jumped to the head of desirability queue!
Old Apr 06, 2012, 06:22 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
wow that thing looks EVIL!
i want one! lol
Discussion New F5d airplane: Sporadic F5D thermik-er High Performance 47 Mar 16, 2013 06:19 AM
For Sale Swift hotliners southern180 Aircraft - Sailplanes (FS/W) 5 Sep 17, 2011 05:43 AM
Idea F5B, worth a day trip!!! (all Hotliners welcome) jjmouris High Performance 2 Sep 16, 2011 11:01 AM
Found motors for hotliners josephcharles Aircraft - Sailplanes (FS/W) 8 Jul 24, 2011 07:34 PM
