Old Jan 17, 2012, 01:24 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Cool, really nice, well done!
regards Martin
MaHö is offline Find More Posts by MaHö
Old Jan 17, 2012, 11:33 AM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Originally Posted by cbalgra View Post
It is such a beautiful aircraft that is so anonymous.
Perhaps the Fury is anonymous because it never went to war?
The little Fury had another outing today and at times I was craving more power. It is time to replace noseweight with a 3rd cell
I'm slowly getting more comfortable about using the kp24 on 3 cells but there will be no ground running and plenty of throttle use. The Turnigy 1015 has the benfit of full cooling as the kp24 only has a facplate, none of the casing is covered by plastic.......................this must help to keep things cool?
Steve
stegla is offline Find More Posts by stegla
Old Jan 17, 2012, 02:12 PM
PEDANTIC is offline
Find More Posts by PEDANTIC
'Sit vis nobiscum'
PEDANTIC's Avatar
United States, KY, Union
Joined Jun 2008
Sweet little jet!
Nice Job!
Matt
PEDANTIC is offline Find More Posts by PEDANTIC
Old Jan 17, 2012, 04:46 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Steve, I remember I drilled cooling holes in the end caps of my 1015 and it dropped the running temp significantly.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 17, 2012, 05:44 PM
cbalgra is offline
Find More Posts by cbalgra
cbalgra's Avatar
Orange, CA
Joined Jun 2007
pdawg and turbonut,
You are both correct. Took my day off yesterday and paid a visit to Yanks. I was already at the airport and since this thread started, I have become very interested in the Fury, so I had to see it in person. The museum claims to maintain their aircraft in airworthy condition, (which most are) but the Fury seemed to be just shy of flying. It was missing its' wingtips and a large panel on the belly of the aircraft. All the plumbing and electrical are in better shape than some of the planes I have flown. Also, its' air intake and exhaust openings were covered which led me to believe the engine was intact. This aircraft has only a total of 257 flight hours, so I'm holding out hope that they will make it airworthy and we may soon see it fly at the Chino airshow. I would be there in a flash!
cbalgra is offline Find More Posts by cbalgra
Old Jan 17, 2012, 07:10 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Thanks for the pics cablegra. They really show how well Stegla did in terms of the scale fidelity of his micro fury.
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Jan 18, 2012, 09:11 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Indeed, many thanks for the pics cbalgra.
My model has true scale outlines but the nose is a little out of shape now after a repair and also the fuselage would have benefitted from some decent cross-sections.
An airworthy FJ-1 would be incredible! That would really get the aeroplane some well deserved attention.
Steve
Old Jan 29, 2012, 06:10 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Flew the Fury this weekend on 3 cells...............no shortage of power
Steve
Old Jan 29, 2012, 06:30 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
GREAT Job!!!....The outline kinda reminds me of a BearCat without the prop...Again, great job!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 17, 2012, 07:29 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Just a quick update.
The Powertrain has been upgraded with an Eflight edf motor and a 12A esc. I'm still using the kp24 fan and a 3s 240 pack. The fan was dynamically balanced using Nitro's sticky-tape trick.
The little Fury now has almost unlimited vertical performance...........just wish there was a rudder to keep things tidy.
Steve
Old Mar 07, 2013, 12:53 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
I've been investigating the forward cg anomily that I had with this model, namely, it had to balance on the leading-edge to fly nicely
It seems that the problem all along has been that the model is very sensitive in pitch................ that I confused for tail-heaviness.
The elevator throws have been reduced considerably and plenty of expo was introduced, this has allowed the model to fly with a more sensible cg position. However, the cg position still needs to be way forward, probably due to the smallness of the model
The model itself is still joy to fly and punches well above it's weight
Steve
Old Mar 08, 2013, 11:59 AM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
How Sharp is your LE Steve? A sharp LE can really mess up a perfectly good airplane. I once had a very snappy test flight on an Electrolyte. After rounding the LE (at the field) the 2nd flight felt like a completely different, well behaved model.
Old Mar 08, 2013, 12:49 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
The front of the Jedelski wing is made from 3/16 balsa. Once the wing was carved to shape the le became 1/8" thick then the le was sanded to a round.
A similar wing on my 32mm Gnat (RIP, must make another) behaved well.
Nevertheless, a 1/8" le could be considered sharp! so maybe?
Steve
Old Mar 08, 2013, 07:13 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
theres a coupel factors playing in here, the first beeing, this is a relatively tiny model, they like the cg fwd, on top of that, youve got that big fat fuse, and it toys with the cg a little. 1/8" raious le should be sufficient
corsair nut is offline Find More Posts by corsair nut
Old Jun 07, 2013, 07:49 PM
xscott is offline
Find More Posts by xscott
Joined Jun 2013
What plans or drawings did you base the FJ-1 on?
Scott
xscott is offline Find More Posts by xscott
Discussion 40mm FJ-4 Fury stegla Micro EDF Jets and Power Systems 80 May 17, 2013 08:19 AM
Sold F-86F Sabre/FJ-2/3 Fury by Jet Hangar Hobbies $350 sagomon Aircraft - Fuel - Jets (FS/W) 0 May 04, 2011 06:45 PM
FJ-1 Fury Niels Electric Ducted Fan Jet Talk 4 Apr 11, 2003 09:28 AM
