Old Dec 18, 2011, 11:45 AM
Fandango Gary is offline
Find More Posts by Fandango Gary
Clovis, California, USA
Joined Oct 2009
Question
Building board magnets
I am a scratch and kit builder...old habits are hard to break! Lately I have seen builders using magnets to hold balsa peices to a metal building board in stead of pins on a traditional building board. They are used to hold ribs in place while glueing the ribs tothe spars, etc. They are also used when laminating balsa strips to create curved pieces, etc.
Does anyone have a source for magnets that can be used for thi purpose. The ones I have seen in builders photos look like cabinet latch magnets without the plastic cases.
Fandango Gary is offline Find More Posts by Fandango Gary
Old Dec 18, 2011, 01:55 PM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
I will try to find an old post of mine that had good source for them.
BlazerB52 is offline Find More Posts by BlazerB52
Old Dec 18, 2011, 01:58 PM
derogg is offline
Find More Posts by derogg
What's my age again ?!
derogg's Avatar
United States, CA, Aliso Viejo
Joined Jan 2004
I think you need fairly strong magnets. Like rare earth or neodymium magnets. With smaller pieces you probably could use regular magnets. Most hardware stores or craft stores have magnets.You can also take apart an old computer hard drive and salvagethe magnets that are in there. I have never used them to build an entire model. Hopefully someone who has can chime in and give a better account of how to do that.
- Dirk
derogg is offline Find More Posts by derogg
Old Dec 18, 2011, 02:03 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
Here is what I used.
http://www.allelectronics.com/make-a...-MAGNET/1.html
Old Dec 18, 2011, 02:09 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
I pitched the base plate. What is nice is the holes make it easy to attach to your uprights ect.
Here is helpful links:
http://www.airfieldmodels.com/inform...d/fixtures.htm
http://www.airfieldmodels.com/inform...oard/index.htm
Hope this helps.
Old Dec 18, 2011, 03:05 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
supermagnetman.net
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 18, 2011, 09:27 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Try this: http://www.magnetsource.com part number CA41LWH
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Dec 19, 2011, 04:05 AM
wattmeter is offline
Find More Posts by wattmeter
Joined Oct 2008
TRY THIS ONE http://www.magnetsource.com/airfieldmodels/
BILL
wattmeter is offline Find More Posts by wattmeter
Old Dec 19, 2011, 05:06 PM
leaktech is offline
Find More Posts by leaktech
Balsa + glue + bluesky= fun
leaktech's Avatar
Phoenix AZ USA
Joined Jan 2009
Hope this helps.
Blazer, Did you make fixtures? Clamps for the fixtures? What size metal building board are you using?
leaktech is offline Find More Posts by leaktech
Old Dec 22, 2011, 11:52 AM
leaktech is offline
leaktech's Avatar
Phoenix AZ USA
Joined Jan 2009
I paid about 57 bux for 150 of these shipped. Just need some sheet steel, cut out some 1/4" ply triangles, and bolt them together. Just one magnet will pick up my bread toaster. It weighs 27oz. So two magnets bolted on one triangle will have a hold down force of 3.3 lb's. Not bad and it's possible to add more magnets with a longer bolt.
Old Dec 22, 2011, 12:07 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Originally Posted by leaktech View Post
...Just one magnet will pick up my bread toaster....
WOW that's a strong magnet. I need to get some. I got some in a kit designed as a magnetic building board. The magnets won't even stay on the board if I tilt it more than 45 degrees... so I gave up on building with them...although the idea seems like such a good one
rcav8r2 is offline Find More Posts by rcav8r2
Old Dec 22, 2011, 02:41 PM
leaktech is offline
leaktech's Avatar
Phoenix AZ USA
Joined Jan 2009
rcav8r, Your weak magnets are many times stronger if you have steel plates on both flat sides. These magnets here will only hold 4.5oz without the plates. The plates allow the magnetic field to increase strength. Someone with a physics background will know why it works better with the plates, I sure don't. One thing's for sure, I'm having fun in the man cave and the flying field.
Old Dec 22, 2011, 03:13 PM
Mecha is offline
Find More Posts by Mecha
Joined Jul 2008
The original creator was Eldon J Lind company, which apparently got bought out by Great Planes who produce Magic Magnet Building Board System now discontinued
places to buy magnets
http://www.kjmagnetics.com/
http://www.hobbylinc.com/htm/gpm/gpmgpmr7025.htm
DIY board systems
http://www.airfieldmodels.com/inform...f_cottrell.htm
http://www.rcuniverse.com/forum/m_91...tm.htm#9122050
hope this helps
Mecha is offline Find More Posts by Mecha
Old Dec 22, 2011, 08:08 PM
jonquinn is online now
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
for the steel sheet, look in your yellow pages (or internet search) for steel processors near you. these are businesses that cut up steel coils to sheets (or slit them into narrower widths). they may give you a scrap sheet, or maybe only have to pay a minimal amount. Just let them know you need something pretty flat. They almost always cut off and scrap some of the metal on the outside of the coil, or maybe they cut out some minor defects (that won't hurt for your purposes). You might be able to get some galvanize sheet from an HVAC fabricator/contractor too.
Galvanize or painted would be good, won't rust as soon.
the thicker the gauge of the sheet, the better the magnets will hold, but that means it will be heavier and thus more difficult to move out of the way.
jonquinn is online now Find More Posts by jonquinn
Old Dec 22, 2011, 10:57 PM
TheRealMrEd is offline
Find More Posts by TheRealMrEd
Joined Aug 2011
magnets and boards
Second the galvanized sheet metal from a/c and heat ducting. Contact cement the thin steel to a sheet of MDF an you're good to go. I don't find the magnetic force in any way diminished.
By the way, I recommend 8 lb. cabinet latches ( rectangular w/two metal plates). I have 2 lb. and 12 lb. styles and with some of my fuse jigs wouldn't come off the board with 4 12. lb magnets -- had to cut back to two on each fixture.
The lighter magnets are useful for holding ribs vertical in close proximity to other ribs. If you use stronger magnets very close together, they all fly into really big piles of stuck-together magnets!
TheRealMrEd is offline Find More Posts by TheRealMrEd
Found Wanted a magnetic building board setup MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 2 Jul 27, 2011 01:25 AM
Discussion Building Board xljedi The Builders Workshop 24 Jun 02, 2011 07:00 PM
Wanted magnetic building board hailo01 Aircraft - General - Miscellaneous (FS/W) 1 May 07, 2011 12:58 PM
Discussion Do Magnets Interfere with On Board Electronics DaGuy Electric Plane Talk 8 Apr 21, 2008 07:18 PM
