Old Jan 04, 2012, 05:49 AM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
MMMMMMMMM pies....so many pies...drooooll
timbuck is offline Find More Posts by timbuck
Old Jan 04, 2012, 06:59 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Originally Posted by Jantar2A View Post
Here is my lateset pair of molded planks
The red and white one is my light all arounder at 11.0 oz. AUW. and it seems to like wind up to 30 mph and still penetrates fine,I DS'd this plane in 20 mph winds and it loved it.
The black and white one is span ballasted with 3 oz. in each wing tip and has a spread tow carbon lay-up on the wing. the AUW came in at 17.6 oz.
I expect it will be a bit more fun in bigger air.
Nick
Nice ships, Nick.
Too much of that Newcassa Broon & you'll be span-loaded too.
dsman is offline Find More Posts by dsman
Old Jan 11, 2012, 08:45 AM
Jantar2A is offline
Find More Posts by Jantar2A
Just chillin @ 403 MPH
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
chevron wing
Originally Posted by Gordysoar View Post
For you guys interested in a serious thermal flying wing, this one is it.
I own the Flying Rainbow (pictured below) which seems to be the forerunner to the ZupAir and it flies fantastic and about 4 times the weight.
Just ordered a ZupAir - Take a look at the video showing using flaps, its amazing!
I pity the fool doesn't get one of these ships! :-)
Gordy
http://www.zupair.com/
It may be a nice plane but I don't feel it fits into the crunchie plank class of airplane.
It's a chevron wing configuration not what I consider a plank.
Jantar2A is offline Find More Posts by Jantar2A
Old Jan 11, 2012, 09:36 PM
Gordysoar is offline
Find More Posts by Gordysoar
Gordysoar's Avatar
USA, KY, Louisville
Joined Oct 2002
Get "bent" :-)
You're right, its not really a plank like some of the amazing ships shown in this thread, but its all I had to offer :-).
You guys have made some real beauties.
Gordy
Gordysoar is offline Find More Posts by Gordysoar
Latest blog entry: Check out my YouTube Channel
Old Jan 11, 2012, 10:12 PM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
How does it DS?
1000MPH is offline Find More Posts by 1000MPH
Old Jan 11, 2012, 10:23 PM
Gordysoar's Avatar
USA, KY, Louisville
Joined Oct 2002
Crank'd Plank DSing
Not sure how it will do in DS, should be interesting but the shortcoming of cranked planks has been wing twist....but that was always with non composite heavy constructions.
The ZupAir is pretty light and stiff.
Our slope in Frankfort Kentucky has a very nice DS band, it has a flat backside, so no back side that you guys would recognize but the zone develops nice enough to cause some moldies and foamie wings to flutter.
I'm guessing only in the 100mph range...but a very easy to groove zone, so even newbies pick it up after just a few circuits.
It depends on a SW wind and tomorrow they are calling for snow...so it may be a while before we can do any slope soaring around here.
I'll keep you posted.
Gordy
Old Mar 26, 2012, 03:56 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Plank Maiden!
I finally got to maiden my new plank. See post #51. It was 2 kg AUW by the time I ballanced it, wing loading around 65 - 70 g/sq.dm.
I flew it out at Mt. Borah in gusting wind around 20 knots and it went fantastic first toss! Much faster than I anticipated with huge pumps and loops etc. It flies neutral inverted- no down elevator needed! And surprisingly quiet for such a fast plane. The only thing that I will change is the elevator deflection, I had too much and was only using about 10% of the stick movement. Just a bit twitchy. I managed to land it ok without any drama.
Very happy with it, I hope to have someone to video it next time up on the mountain.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Mar 26, 2012, 04:00 AM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Very nice Jim..glad it all went well. Quiet means efficient... well done.
Tim
Old Mar 26, 2012, 12:22 PM
dsman is offline
dsman's Avatar
Joined Mar 2007
Jim.
Seems perfect, must be immensely satisfying.
Old Mar 26, 2012, 03:37 PM
Joined Aug 2008
Yes, it sure was. It shows that carefull attention to measuring up and setting up on the bench, ballancing etc. certainly pays off!
Old Mar 26, 2012, 03:56 PM
josh18 is online now
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Well done Jim!
josh18 is online now Find More Posts by josh18
Old Mar 29, 2012, 06:02 AM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Hi Jim
Good to here that it went well with the plank , where did the cg end up & what was the throw on the elevator ?
getting the Avalanche ready for paint in the next week or so ( finally)
Rick
BMtech is offline Find More Posts by BMtech
Old Mar 29, 2012, 02:55 PM
Mike the Snake is offline
Find More Posts by Mike the Snake
RC LIFER
santa rosa California
Joined Aug 2005
I built quite a few planks a while back, and I discovered the same thing, that elevator deflection/travel is very minimal.
I found that the sweet spot CG-wise, was to keep moving it back until the plane flew hands off inverted, which it sounds like you are at, but at that CG, the elevator travel was maybe 1-2mm up and down, while the aileron throws were normal. As the CG moves back, the elevator response gets ultra touchy.
Jim.
Mike the Snake is offline Find More Posts by Mike the Snake
Old Mar 29, 2012, 03:54 PM
Joined Aug 2008
Cg
Originally Posted by BMtech View Post
Hi Jim
Rick
Rick,
The CG started and will stay at 22% MAC. I used the online CG calculator here: http://www.scaleaero.com/CG_Calculator.htm after measuring up very carefully. I no longer believe the idea of starting "conservatively" (forward) as it is described, and them moving it back! Maidening a plane with a forward CG is counterproductive in my opinion, and only compounds the pilot work load. It raises the stalling speed and makes the plane more sluggish (if it will fly at all that is, often a plank will not!).
The elevator deflection rates are now around 2 mm. up and down. This is the only thing that I changed after the maiden flight, I had them too high and was only using about 10% of elevator stick movement.
Jim.
Last edited by Jim.Thompson; Mar 29, 2012 at 04:57 PM. Reason: correction to information.
Old Mar 29, 2012, 09:21 PM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
I have only just discovered this thread and am chiming in to tell you all that planks are the work of the devil, and they're not real planes. Like helicopters they can't fly and they only stay up because of satanic forces. You guys need to publicly repent and renounce your planks, and along with gyros they should be sacrificed on a funeral pyre as an offering to the god of real planes (that have tails).
AvB is offline Find More Posts by AvB
Sold Heli garage sale trade for planks or jets kramer Aircraft - Fuel - Helis (FS/W) 0 Aug 16, 2011 09:08 AM
Sold Heli garage sale trade for planks or jets kramer Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2011 09:02 AM
Discussion Boat planks hotshot564 Scale Boats 12 Aug 14, 2011 12:30 PM
For Sale DAW P-40 WARHAWK 32 INCH CRUNCHIE nib steeg Aircraft - Sailplanes (FS/W) 2 Aug 05, 2011 09:59 PM
Video DAW P-40 crunchie TRISME Sailplane Talk 12 Mar 10, 2011 08:17 AM
