Old Nov 23, 2012, 06:45 PM
flo is offline
flo
Find More Posts by flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi Josh,
yes it is.
8 layers of FG and 2 more of Keflar help somewhat too
Flo
flo is offline Find More Posts by flo
Old Nov 24, 2012, 01:50 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Wow! Ive never seen a wing and fuse moulded in one like that! How do you go with boom strength due to having no seam?
It'd be great to open a mould and out comes the whole plane!
josh18 is offline Find More Posts by josh18
Old Nov 24, 2012, 03:38 AM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi,
using the quietness of saturday mornings i finished off the little fella.
Just odds and ends...
Like blocking off the ail linkages so they won`t come off the servo and installing the battery hold down.
This little assembly might have your intrest, a bit fiddely but only a10 mins of work and it weights just about nothing- or even less
(quite important on planks as CoG is quite crucial)
@Josh18
Well as mentioned this is just a cut off Toppits (tailed version).
having such heavy layups (like 5 layers of cf) in the boom always did lead to problems when seaming. for the first 5 or so planes i used peel-py (to roughen the surface ) and seamed it with an aditional layer,... using a ballon while curing..
Sometimes, no matter how hard you tried the layer sneaked out the seam and thus the booms, their joints respectively, where the weak spot of our planes.
Now i just cut the flanges flush and glue in a gf-tube, which is made of two layers of fg "socks".Forward part has an additional layer of 110gr. keflar in betweeen.(peelply on outside to assist glueing).
Lots of (read 2-3 gr. on such a tiny plane) splooge will get the tube centered .
The ballast tube just fits in this tube from the front .
When closing the mould splooge is used to glue the boom together, just like your trad. LE and TE.
So basically the whole plane is solid till aprox 2 cm in front of the ails.
As the splooge goes around the whole perimeter the joint is unlikely to break open -ever
As a side effect this gives a material thickness of 2,5-3 mm (slightly more than 1/10 of an inch) on the boom.
greets
flo
Old Nov 24, 2012, 03:52 AM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Originally Posted by josh18 View Post
Wow! .........
Jup-
only the tailgroup needs to be bagged seperately
a couple of our builds...
(sorry not going to hijack this thread anyfurther)
Old Nov 24, 2012, 03:56 AM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Very cool flo..
Tim.
timbuck is online now Find More Posts by timbuck
Old Nov 24, 2012, 04:09 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Thats my kinda plane!
Old Nov 24, 2012, 01:01 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Flo - cool little plank. I don't know Aying but I have tried the beer!
Shedofdread is offline Find More Posts by Shedofdread
Old Nov 27, 2012, 02:50 PM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi there,
after a quick maiden off the bungee yesturday ( one click of downtrimm - thank you Toni for finding such a sweet setup ) me and Toni took the 2,5 hr. hike today to one of our favorite spots.
Arriving there, we found the wind beeing somewhat off thus making for a very bunpy backside. Also there was just some 15 knots - so Ballast stayed in the backpack.
Anyway, even flying very conservative produced 105 mph.
Not too bad for a first outing.
Handling is just as sweet as the tailed versions - probably not a record breaker but very much fun to fly
Gonna enjoy this plane in future for sure...
greets
flo
Old Nov 27, 2012, 03:50 PM
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Congrats Flo....well done.
Tim
Old Nov 27, 2012, 04:00 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
What's the airfoil Flo?, and did you find you needed to change your trim for different speeds?
Well done by the way, thats a really sexy looking plane!
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Yeah. Well done flo! I am also a fan of using a bungee for first flight, especially if there is no suitable site or wind around at the time.
I hope to get to moulding another of my "Circa" over the silly season break.
I just need to make sure I have all the materials in stock in advance.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Nov 27, 2012, 04:14 PM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Thanks all.
Airfoil is a thinned MH43.
What amazes me most is the fact that a section not meant to fly tailless just works fine. It really is quiet- even when going fast...good sign in my book.
Just proves that with DS nothing really matters (just kidding)
Of course there would be even more efficient/faster sections availible ( especisally if one of your flying buddies is DP ) but it is just a very easy Way to get hold of a fine flying FUN DS plank. A Short cut so to speak....
witch brings me nicely to anounce my decition to name this little Fella:
SHORTCUT
@Josh
Trims change very slight only, i have programmed in a fraction of down for speed and a fraction more for the DS phase. Works without the need of further trim.
greets
flo
Old Nov 27, 2012, 04:44 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Great, seems that flying wing sections are not as critical as we all used to think hey!
I did the same thing with my tailed plane called the scorcher and made a plank out of it. I havn't flown it a lot yet bt so far it seems really good, just needing a bit of reflex.
Old Nov 27, 2012, 05:29 PM
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Shortcut....I like.
Tim
Old Nov 27, 2012, 08:12 PM
jonoashton is offline
Find More Posts by jonoashton
jonoashton's Avatar
New Zealand, Wellington, Porirua
Joined May 2006
Dave did a similar thing and used the flaps for reflex and elevator and the ailerons for ailerons. It went well
jonoashton is offline Find More Posts by jonoashton
Sold Heli garage sale trade for planks or jets kramer Aircraft - Fuel - Helis (FS/W) 0 Aug 16, 2011 09:08 AM
Sold Heli garage sale trade for planks or jets kramer Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2011 09:02 AM
Discussion Boat planks hotshot564 Scale Boats 12 Aug 14, 2011 12:30 PM
For Sale DAW P-40 WARHAWK 32 INCH CRUNCHIE nib steeg Aircraft - Sailplanes (FS/W) 2 Aug 05, 2011 09:59 PM
Video DAW P-40 crunchie TRISME Sailplane Talk 12 Mar 10, 2011 08:17 AM
