Old Aug 01, 2012, 03:27 PM
MatejO is offline
Find More Posts by MatejO
Sketchy builder
MatejO's Avatar
Slovenija, Kamnik
Joined Jul 2011
Not yet.
Two stroke is building Carbon one for flying (making hinges and instaling gear)...
And building SC's for Austrian customers. Not enough time for flying.
Today I ordered servos for my model. Eventually we will have some more time to get video material.
And. We are buying a used Stalker pro2 or Decatur's Prospeed radar gun if someone know somebody to have one for sell. We are interested.
But for now we only have "data" from second Stormchaser's flight:
MatejO is offline Find More Posts by MatejO
Old Aug 09, 2012, 05:54 AM
two stroke is online now
Find More Posts by two stroke
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
Stormchaser crash test
Stormchaser crash test (0 min 46 sec)
two stroke is online now Find More Posts by two stroke
Old Aug 15, 2012, 04:50 AM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
A couple from about 9 years ago, carbon, foam, steel, alloy, wood.... not pretty but fun. The big one carried a lot of energy, I would never build that big and heavy again without brakes.
Antonsoarer is offline Find More Posts by Antonsoarer
Old Aug 28, 2012, 06:45 AM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Avalanche wing rod
Ok its just about done ,
needs the top fairings for the linkages
check out the wing rod 5/8 chrome moly tube
2 gyros fitted &ready
final cg balance , its set at 50mm at the moment & she tips the scale at 3200grams
Rick
BMtech is offline Find More Posts by BMtech
Old Aug 28, 2012, 04:59 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Its looking impressive Rick, I'm looking forward to seeing it next month out at Borah. Where did you get that joiner bar?
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Aug 29, 2012, 12:17 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
Got it from here.
ZIPPER is offline Find More Posts by ZIPPER
Old Aug 29, 2012, 03:15 AM
Joined Aug 2008
Thanks Glenn.
Old Sep 07, 2012, 05:26 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Here is my first foray into crunchy planks. Its a foam filled scorcher wing and a cut down fuse. I chose the foam filled wing for the plank because I know its probably going to crash and what better wing to test than solid foam! It's not a flank foil (rk40) so I have no idea if it will fly- I'll just set the cg foreward and use a bit of reflex and see what happens. Looks cool at least though I reckon!
josh18 is offline Find More Posts by josh18
Old Sep 28, 2012, 08:47 AM
Joined Aug 2008
Totall destruction of my moulded plank!
I flew my moulded plank Circa at the Bora Slopefest last week and it went very well. My festival flying buddy Pismo took the sticks a couple of times and did some fine trimming and gave me some much needed flying coaching at the same time. It was very fast, carried its energy fantastically in huge pumps. In short: it did all the right things that a good flying plank should do.
However, on our last day when we had really good wind gusting up to 30 knots with huge lift, I flew it one more fateful time. I was circling it inverted at high altitude and decided to pull up elevator to do a slow half loop pull out into upright position, losing height while doing so. I have done this many times before. However, this time, it began the first part of manouvre ok, rotatiing through about 90 deg. before it stopped responding to tx. control commands. (I was continuing to pull the elevator stick back!). This meant that it continued to plummet vertically at terminal velocity, or nearly so, into the face of the mountain. When we found it, it was a mess of debris with little salvageable. A sad loss!
The only explanation I can think of is that it was a rx. failure. However, there is no way to be sure. The battery pack checks out ok.
The good news is that I have the moulds and I now know it is a well proven design. It handles fine with no vices apparent. So I will be laying up a light one or two sometime in the near future.
All part of the hobby I guess!
Jim.
Old Sep 28, 2012, 11:13 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Rick
What news of the Avalanche?
Has it flown yet?
What gyros did you use for the elevon set-up, & did you mount them angled slightly off the centreline to obtain also a relatively modest ( c.f. roll axis) amount of operation in pitch?
dsman is offline Find More Posts by dsman
Old Sep 29, 2012, 12:51 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Bad luck Jim, like you said though, at least you have the moulds
Old Oct 22, 2012, 11:49 AM
8thelephant is online now
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
Been drooling over lots of nice models here :-)
And I'm finally looking to acquire my 1st crunchy plank (as economically as possible) for the 8-20mph slopes. Any suggestions for retailers or individuals in the US?
-8th
8thelephant is online now Find More Posts by 8thelephant
Old Oct 22, 2012, 03:50 PM
Joined Aug 2008
Some discussion about the likely reason for the crash has been posted on the ManillaFest thread.
I'm now fairly convinced that the servos stalled! I won't repeat what was posted already, except to say that the new replacement plank will have some stronger and better servos than this one had!
Jim.
edit: discussion starts here: http://www.rcgroups.com/forums/showt...36870&page=155
Old Oct 23, 2012, 08:54 AM
fabmaster911 is offline
Find More Posts by fabmaster911
Clinton, Utah
Joined Apr 2008
Sub'd
fabmaster911 is offline Find More Posts by fabmaster911
Old Oct 23, 2012, 03:44 PM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Finnish my new warhead 30 fuse molds...
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Sold Heli garage sale trade for planks or jets kramer Aircraft - Fuel - Helis (FS/W) 0 Aug 16, 2011 09:08 AM
Sold Heli garage sale trade for planks or jets kramer Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2011 09:02 AM
Discussion Boat planks hotshot564 Scale Boats 12 Aug 14, 2011 12:30 PM
For Sale DAW P-40 WARHAWK 32 INCH CRUNCHIE nib steeg Aircraft - Sailplanes (FS/W) 2 Aug 05, 2011 09:59 PM
Video DAW P-40 crunchie TRISME Sailplane Talk 12 Mar 10, 2011 08:17 AM
