Old Jun 09, 2012, 04:57 PM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Hi guys
Great team work. Good feeling flying your model for the first time. Love the spots you guys have. Amazing. Seemed to be very smooth DS zone and a clear shear. Well done. Congrats.
Now you do need to buy a RADAR.. So you can chase records.
What was the wind speed that day.? OH and where are those spots
Tim
timbuck is offline Find More Posts by timbuck
Old Jun 09, 2012, 06:04 PM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
Originally Posted by MatejO View Post
We do not have it. Do you have a crunchy plank that goes near 200?
Well over 200, Closer to 300mph
Forrest12 is offline Find More Posts by Forrest12
Old Jun 09, 2012, 06:20 PM
MatejO is offline
Find More Posts by MatejO
Sketchy builder
MatejO's Avatar
Slovenija, Kamnik
Joined Jul 2011
I was thinking about home brewed plank.
Any how...
Tim! Thank you for support. Really means a lot to us
Yes I know. I want to buy a decent gun(700$+). But brother wants to invest money in gear and materials. So now he is thinking in pocket radar
The wind was blowing 8 to 10 meters/second. Not much
Spot is near our house. 40minute drive to the spot + 15min of hiking.
Web page of the mountain: http://www.velikaplanina.si/Home
MatejO is offline Find More Posts by MatejO
Old Jun 09, 2012, 07:35 PM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Way to go , that looks like a great place to have in your b/yard !!
The storm chaser looks good in the air & does a mean 1 point landing
what elevon travel & CG have you got ?
Rick
BMtech is offline Find More Posts by BMtech
Old Jun 09, 2012, 07:53 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by ibuild View Post
Apply the butterfly patiently, using only a very small deflection for only a short time in the beginning.
Gradually apply it for a little longer, and eventually perhaps with just a little more deflection.
This is what I did not try!
I've just re-read this thread and the point above only "sunk in" then.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jun 09, 2012, 08:22 PM
Joined Aug 2008
Exponential.
When a servo's operation is "geared down" by using the shortest possible servo horn and a long control surface horn, some positive exponential has to be programmed in to cancel the positive exponential effect.
This is something that I often forget to do and had some bearing on the elevator sensitivity (twitchyness) of my plank on the maiden flight reported in an earlier post.
On the second flight, I reduced elevator deflection rates too much, and I was not getting sufficient control in pitch to pull the plane up at times. I landed my plane rather hard in (fortunately) soft soil this way!
My take home conclusion here? The elevator deflection rate (most often referred to as "throws") needs to set very carefully and with some degree of judgement. And some exponential is very usefull.
Jim.
Old Jun 10, 2012, 12:38 AM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Hi Jim.
All our planks are set up this way , and I don't know any that use expo. The main reason for this is to get resolution (100%) so it makes planks fly a lot smoother. And you dont have to run you elevator at low % of travel. Keeping resolution.
Just have to be a bit carful with negative expo. Can make it Very responsive around 50% stick travel. Thus causing pitching at speed.( depends on % of expo..??)
Depending on the hight of your control horn , easier to set up no expo and fly triple rates. Also are you sure you CG isn't fractionally aft..?? .5mm does make a difference.
Tim.
Old Jun 10, 2012, 01:16 AM
Joined Aug 2008
Negative/positive expo.
Tim,
Yes, I should have said positive exponential. I'll edit my post.
edit: The CG on my plank might be a bit aft. I'll try trimming it very slightly forward.
Old Jun 10, 2012, 02:54 AM
BMtech is offline
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Gyro settings
Well made some steps forward with the Gyro set up, I re watched AVB 's video & got the general Idea of what will happen , Ian has this set up on his D60 for roll, so I sort of just copied that for pitch
1. have been able to get an off position on my right slider middle de-tent, have mixed aux3 to rudder @ 15% both pos (HH)& neg( Rate) , some of my earlier problems where never using gyro's & not quite understanding how the settings work
2.then there was the big problem of the centreing of the elevators, this turned out to be easy , I have turned them OFF so they don't move opposite the flap , so I run the flaps down for brakes & the Gyro's in HH/Rate mode will move elevators to compensate the pitch change , this is like a conventional plane with tail but it all happens on the wing
well that's the theory anyway !
even though the Gyros are small it will be a pain in the butt to get them in the fuse on the CG or close to it, as this is the only place that they will fit side by side
Rick
Old Jun 10, 2012, 09:06 AM
two stroke is offline
Find More Posts by two stroke
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
Rick
Hi
I got CG 3,5cm from the LE that is 20% ,the elevon travel are about 6mm up and down...
Thank you guys for congrats,now its time to build havyduty one and get the radar
Simon
two stroke is offline Find More Posts by two stroke
Old Jun 10, 2012, 05:01 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Originally Posted by two stroke View Post
Hi
Simon
That's along way forward , and 6mm is that for ailerons ??. What's elevator travel ??.
In a big front side dive that must be pulling up buy it's self a lot.??
Old Jun 11, 2012, 04:08 AM
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
The front side test dive show a straight line,ailerons and elevator are the same and got 25% expo..
Simon
Old Jun 11, 2012, 12:31 PM
Warren Peterson is offline
Find More Posts by Warren Peterson
Warren Peterson's Avatar
Brea CA
Joined Aug 2006
Felt like doing something different. Still not sure she will fly.
Warren Peterson is offline Find More Posts by Warren Peterson
Old Jun 11, 2012, 01:16 PM
A10FLYR is online now
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Nose is too long!!
A10FLYR is online now Find More Posts by A10FLYR
Old Jun 11, 2012, 02:24 PM
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
Sure it will,joust make sure the CG is right
Nice one
Simon
Sold Heli garage sale trade for planks or jets kramer Aircraft - Fuel - Helis (FS/W) 0 Aug 16, 2011 09:08 AM
Sold Heli garage sale trade for planks or jets kramer Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2011 09:02 AM
Discussion Boat planks hotshot564 Scale Boats 12 Aug 14, 2011 12:30 PM
For Sale DAW P-40 WARHAWK 32 INCH CRUNCHIE nib steeg Aircraft - Sailplanes (FS/W) 2 Aug 05, 2011 09:59 PM
Video DAW P-40 crunchie TRISME Sailplane Talk 12 Mar 10, 2011 08:17 AM
