Old May 13, 2012, 01:14 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Hey Andrew, did you ever try it after a big dive with some height left? I reckonthat would look pretty cool!
josh18 is offline Find More Posts by josh18
Old May 13, 2012, 04:42 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
I don't remember Josh! I think I just tried it on the Shorncliffe slope. But I remember some of the older more experienced guys viewed it with great suspicion ... I think they thought it was a dumb idea and that I should learn to do a proper "slide up the slope and turn into wind and plop it in" landing. But it really worked well. Better than stuffing it up and cartwheeling into the fence or on the road. It just completely stopped right where it was and fell down.
AvB is offline Find More Posts by AvB
Old May 13, 2012, 04:17 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Makes me think of setting a Ninja Star on a switch for DS, as my rates always seem too low for it. You wouldnt want to hit it during the lap though!
Old May 13, 2012, 06:39 PM
Rhys Porter is offline
Find More Posts by Rhys Porter
Planes dress doors...
Rhys Porter's Avatar
Australia, QLD, Kippa-Ring
Joined Mar 2011
Ah Josh - I think that's called a self destruct button if you hit it during a lap lol
Rhys Porter is offline Find More Posts by Rhys Porter
Old May 13, 2012, 06:43 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Haha, I can do that on my own! Too often...
Old May 16, 2012, 12:01 AM
Gordysoar is offline
Find More Posts by Gordysoar
Gordysoar's Avatar
USA, KY, Louisville
Joined Oct 2002
Using brakes instead of guessing about them
As most you may know I have flown rc sailplanes in more places with more guys than anyone else on Earth....
Its one of things that seperates my comments from the rest...I try stuff where most talk about what might be.
Take a look at the Zupair Z1 plank. There are NO FLAPS on it. as I mentioned in my first post here on the topic....it has landing brakes that look like flaps. They pop; down 90 degrees and cause little or no pitch change.
90 Degree flaps are not camber, they are simply big flat devices that cause a lot of drag.
The wings you guys are flying are not thermal ships...so why does the topic of camber, or crow come up in the discussions?
Yes you can put mulitple surfaces on any slope wing....they'd have the same benefit as an 8 track tape player.
Slope planes are for going fast and zooming around looking cool. Brakes allow you to avoid scarfing up the skins or causing chaos on the slope trying to do some cool crabbing manuever to burn off speed and lift in order to plop down.
But if you could cause the model to come to a near slop yet have full control....you could simply pick it out of the air.
Check out the Zupair's video showing the 'flaps' in flight action.
Gordy
Gordysoar is offline Find More Posts by Gordysoar
Latest blog entry: Check out my YouTube Channel
Old May 16, 2012, 12:40 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Hey gordy, wth the zupair being a sweps high aspect wing, if the flaps or brakes are at the inner part of the wing then they would be acting very close, possibly even foreward of the cg due to the wing sweep. This, to me is the reason they have little effect on pitch. Try this on a propper plank and see what happens. Considering a well tuned pw51 plank can need only a couple of mm elevator travel, even if the brakes snapped to 90 degrees "instantly", you would be in the ground or at least out of control before you could blink. Feel free to prove me wrong if you have a video of it but I cant see it at all possible to brake a plank using only down flaps. Maybe some form of spoilers near the cg would do a similar job to what you discribe.
Cheers, Josh
BTW, it looks like a great plane!
Old May 16, 2012, 12:55 AM
vespa is online now
Find More Posts by vespa
First pull up, then pull down
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Zupair is not a "plank". The substantial sweep greatly increases pitch damping and the location of the flaps greatly lessens their pitch effects.
90 degree flaps are absolutely camber. Not only by definition but in practice. I use 90 deg on most of my (tailed) planes and the pitch effects are enormous -- increasing nearly linearly throughout the entire flap deflection range.
What I have found useful for some planks is to setup a switch to put both ailerons nearly all the way up. Surprisingly I have never been able to loop like this, no matter how I try. The stall is so immediate that they simply go right into a slow, stable, bobbling "hyper-stall" descent from any speed or attitude, even inverted. Unfortunately, roll control is limited, pitch control is non-existent, and the descent is very steep so it's not be suitable for all planes.
vespa is online now Find More Posts by vespa
Old May 16, 2012, 01:09 AM
Joined Mar 2011
That was the same wing I was talking about earlier - Now I see it's very different to a Windburner at Cactus!
Z1 With Flaps (0 min 40 sec)
Old May 16, 2012, 01:39 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Swept wing - not a plank!
I'm with Josh here Gordy! Your very nice model is no plank, that's for sure.
Very impressive though!
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old May 16, 2012, 02:55 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
If you want proof that a 90deg flap IS camber, look a the 'Gurney' flaps on the TE of racing car wings and the reason we put them there.
Years ago, I had a plank based on the Kowalski (?) Phonix - that had a 'letterbox' airbrake in the middle of the centre panel. Worked OK.
I'd love to see someone try this
Scan Eagle Landing (0 min 38 sec)
with a model. But failing that, the net has the 'spectacular' effect
Shedofdread is offline Find More Posts by Shedofdread
Old May 16, 2012, 03:23 AM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
This is how I land my planks.....no brakes..
This is a back side landing....at cactus ridge a few days ago..
Composite Plank Hand Catch... (0 min 35 sec)
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old May 16, 2012, 03:55 AM
Joined Mar 2011
Haha Tim that's crazy... To stand in the face of a warhead 60 and catching the damn thing is truly nuts...
Old May 16, 2012, 04:04 AM
Nothing is easy
timbuck's Avatar
Joined Aug 2008
WARBURNER 48... 1.1kg..
Windburner wing with warhead fuse.
Old May 16, 2012, 04:20 AM
ibuild is offline
Find More Posts by ibuild
closed due to popular demand
Joined Jul 2011
ibuild is offline Find More Posts by ibuild
Sold Heli garage sale trade for planks or jets kramer Aircraft - Fuel - Helis (FS/W) 0 Aug 16, 2011 09:08 AM
Sold Heli garage sale trade for planks or jets kramer Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2011 09:02 AM
Discussion Boat planks hotshot564 Scale Boats 12 Aug 14, 2011 12:30 PM
For Sale DAW P-40 WARHAWK 32 INCH CRUNCHIE nib steeg Aircraft - Sailplanes (FS/W) 2 Aug 05, 2011 09:59 PM
Video DAW P-40 crunchie TRISME Sailplane Talk 12 Mar 10, 2011 08:17 AM
