Espritmodel.com Heli Air
Old Dec 17, 2011, 09:39 AM
Joined Dec 2011
what charger parameters for AA batteries with orion advantage charger
hi all,
I would like to charge my GP2700 AA batteries
with my orion advantage charger
do you think I could charge them at 2A or more with a delta peek at 0.5 ?
regards
LV
le varan is offline Find More Posts by le varan
Old Dec 17, 2011, 10:27 AM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
If you want NiMH batteries to last, you should never charge them any faster than you have to.
That said, it's not a good idea to charge below a 0.3C rate if you're using a delta V charger because the charger might not detect the delta below that rate.
And it's widely accepted that you should never exceed a 1C rate.
For 2700mAh cells, 0.3C = ~.8A and 1C = 2.7A.
If those were my cells I'd charge them at 1.3A and set the delta at 4mV/cell. If the charger false-peaked I'd go to 5mV.
Pete
PGR is offline Find More Posts by PGR
Old Dec 17, 2011, 10:33 AM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
You should be able to do 1/2-1C OK so 2A may be fine. I'd watch them for heat the first couple times.
No idea on Delta-v setting for that charger. Looks like you have a thermal probe? If so, I'd use it and keep the temp under observation.
Lots of info here.
http://www.hangtimes.com/rcbattery_faq.html
flydiver is offline Find More Posts by flydiver
Old Dec 17, 2011, 01:16 PM
Joined Dec 2011
Thanks guys,
I've 6 charging at 1.4A peek 0.5 (0.3 and 0.4 didn' work) and tempreature is aprrox 24°c, have got a 12v fan blowing on them !
next 6 pack will be at 2A just to try.
I'll keep you updated.
LE VARAN
Old Dec 17, 2011, 01:27 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
Be aware that being 2700mA in a AA they've tried to cram a lot of energy into them making for high impedance. My experience with this kind of hi-cap AA has been disappointing - high self discharge rate, and low performance. About the only AA cell that seems to live up to those specs is the Sanyo 2700. GP is generally a good name so I'll be interested in your take on them.
For Sale POWEREX C9000 Wizard One Charger/ Analyzer for AA & AAA Batteries - REDUCED GoRgOyL Aircraft - Electric - Batteries & Chargers (FS/W) 1 Oct 06, 2011 05:48 PM
Discussion New To Electric, what batteries and charger for a PZ Stinson Reliant? 4075aaron Beginner Training Area (Aircraft-Electric) 7 Sep 28, 2011 12:36 PM
Discussion What Attchment Needed For AA NiMH Batteries On Hitech X4 Charger? itsme2 Batteries and Chargers 1 Mar 21, 2011 08:58 PM
Help! best AA rechargeable batteries? And best charger for 7.4v 800 mAh li-po batteries? RocketSnail Batteries and Chargers 10 Dec 31, 2010 11:18 AM
For Sale Team Orion Advantage Charger SRM Cars - Cars and Parts (FS/W) 0 Dec 01, 2007 05:13 PM
