Yes Laurence there's still a lot of work to do and I'm doing lightning,weathering,rockets,bombs and bombay doors that work also.
Peter..I think it will be in between both install of the hinges so not so much sticks out and I can make a litho schroud around them. Once I have the FLAPS made in front of me I will get a better idea of just how it will work
United States, CA, Santa Barbara
Joined Jun 2012
Bruce:
Robart hinge points will work fine. That is what I used for both my 81" and 124" Mosquitos. However, if you are not going to use the offset bellcrank as shown on the plans to connect the flaps, you will have to add another (non-scale) hinge to each flap. The full size airplane only had one exposed hinge for each flap section. The portion of the flap closest to the nacelle was supported by the actuation mechanism. I've attached photos of my 81" hinges. Note that the hinge point is well outside the wing profile and note the hinge support "jog" that extends out from the trailing edge of the wing to shift the hinge pin location aft from the flap leading edge. These two offsets are required to achieve a constant gap between the upper aft edge of the wing and the curved leading edge of the flap during flap deployment (see photos and captions). The fairings/shrouds were fabricated from balsa. The hinge arrangement for my 124" Mossie is the same, except that I used the largest Robart Hinge Point available (1/4" shank). You can see the hinges at around the 4:00 mark of the video clip (see my blog for link). Regards, Tom
Tom thank you for showing the photos of your FLAPS they will be very helpful, can you show the internal actuation mechanism that you came up with/ or photos of it while you were making it.
Or did you use the same bent wire that's in Brians drawing? any views here would be very helpful so I can come up w/ something. I just hope mine looks half as nice as yours. Thanks again, Bruce |
Here are the real FLAPS under construction
![]() I think I'll try to make a center post like the real plane had and run it through a nylon bushing that way I will be able to just use one hinge like tom has in his photos. The post will be a piece of heavy gauge music wire w/ wheel collars on the ends this will act as the center hinge. Bruce |
Joined Jun 2012
Hi Bruce:
For the 81" Mosquito, I simply made the bent wire flap actuator as shown on the plans, and it worked fine. For the larger Mosquito, I made up something stiffer because bent wire in that larger size would have been pretty wimply. I've attached a sketch that shows what I did. The geometry matches the plans (pivot point location, offset angles, etc). Something like this would work for the 81 inch bird as well, if it was scaled down appropriately. For my smaller Mosquito I located the flap servos (one for each side of the wing) at the wing center section, with a bellcrank in the wheel well. If you keep the linkages straight, and make sure they are supported, the control setup is reasonably rigid. On the larger Mosquitos, I've seen guys put the flap servo in the nacelle aft of the flap actuator with a very short linkage connecting to the flap horn. There is a scale access panel on the top surface of the wing that can provide access to this area for maintenance. |
Canada, BC, Courtenay
Joined Mar 2011
Flap Servo
This is what I think Tom was referring to about mounting the servo in the back of the engine nodule. I was using this fellow for my build, but there wasn't too much detail so I had to experiment with a lot of the build. Now you came along and have shown me the path to rightness.
![]() ![]() The site is at http://www.mossie.org/models/Jeff_Bo...g_Mosquito.htm. And I've attached a copy of the pic. Ben |
Alright everybody I went back to my first way of trying to drive the FLAPS w/ one servo
but think I will use a actuator like Tom showed my own version of coarse. So the first thing I had to do was make sure I could rout a push rod through the landing gear and have enough room to work the flaps here's what I have come up w/ so far.
Australia, ACT, Canberra
Joined Jun 2012
Hi Bruce and all. Back from my wandering around and started the build. Started the rudder as it was something easy. Also I will be going to NZ on family matters and thought I might catch-up with the the Mosquito rebuild. Finally I found out that Mosquito's were built in Aussie and there is one in the National War Museum. So I am trying to have a close look and take lots of photos.
I have produced, from Bruce's postings, a build log and I am using that as the basis for my build. Below are the photos showing my current progress, see what you think. |
Good luck w / it if you do and I hope you post a build thread! ![]() Bruce |
United States, MD, Frostburg
Joined Aug 2008
Not yet...I actually spent a lot of time camping this summer (in fact, I am going again this weekend) but it looks like building season will start next week with temps dropping into the upper 20's and lower 30's.
I have to decide what to build...I have an almost finished plane that I have totally lost interest in but I feel as though I need to finish it first. I think I could nail it out in a couple weeks if I really focus. Hard to do when I lost interest in the plane! I will start a thread once I start the build...of which ever plane it is
COOL aaron I look forward to see what you choose I know you have many that you can build.
Today I started to assemble the FLAPS, tomorrow I need to run to the hobby store and get some brass tubing and nylon bushings/ straps. Then come up w/ the actuator,I scribed out a few brass parts but that's as far as I got today. |
| Thread Tools | |
| Sold For the Scale Builder: A Set of Brian Taylor Plans Vultee BT-13 W/Cowl & Canopy | stevster | Aircraft - Fuel - Airplanes (FS/W) | 1 | Apr 07, 2011 02:27 PM |
| Question Contact for Brian Taylor Plans | pgleesonuk | The Builders Workshop | 4 | Sep 13, 2006 09:48 AM |
| Brian Taylor Mosquito plans | CraigO | Scale Electric Planes | 11 | Nov 05, 2003 04:43 PM |
| Brian Taylor Mosquito FB Vl electrified | TasMike | Scale Electric Planes | 0 | Nov 05, 2003 05:32 AM |
| FS: 69" P-51 Brian Taylor plans and Parts | Ken Lapointe | Aircraft - Electric - Airplanes (FS/W) | 1 | Feb 05, 2003 06:57 PM |
