Old Sep 05, 2012, 02:16 AM
joneswag is offline
Find More Posts by joneswag
Joined Apr 2012
Got a piece of scrap balsa yesterday and gave it three water based coats of under-coat, sand-papering inbetween coats. Finally I gave it an oil based top coat. Unfortunately you could see the brush strokes, so I bought an air brush as in picture. Specification as follows :
Specifications:
Spray pattern adjusts from l/4" to 5" for maximum versatility.
Includes fine head airbrush, 5ft. vinyl hose, 2oz. Jar, with cover,attached 3/4oz.
jar, propel regulatorand adaptor (I/4" air hose from the compressor to the smaller air brush hose.)
Standard Nozzle Dia.: 0.8mm
Operating Pressure: 15-50psi Price US $5-99.
Would you please advise, if I should use water or oil based paints? What undercoat would you recommend to fill the balsa grain?
joneswag is offline Find More Posts by joneswag
Old Sep 05, 2012, 02:42 AM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Specifications:
Joneswag...Nice airbrush kit do you have a compressor? I use sanding sealer
about three coats I like deft sanding sealer it's lacquer based and has a strong smell but drys really fast it's what the pro's use for wood working and has a high fill content
as far as the paint I've heard people using all kinds of things in this hobby
house paint latex and oil base what I use is rustoulem if you get the basic colors
you can blend any color you want. for example red and yellow make orange more
red and the darker the orange less red and more yellow the lighter the orange.
rustoulem is fuel resistant and a very tough paint.
the other thing I do is after sand sealing I prime w/ rustoulem high fill auto primer
it comes in grey dark grey almost black and a rust color and you may find some in white but it's harder to find when you don't see any grain then you can paint the color.
you have to sand in between coats this is why most people use fiberglass and then paint less steps as long as you do the glass work the right way, people don't like to sand I have been doing it for over 30 years and it doesn't bother me I'm use to the dust and it's good for your arms!
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Sep 05, 2012, 01:39 PM
ctrout is offline
Find More Posts by ctrout
Waiting for the paint to dry.
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
And just for the point Joneswag.. That airbrush can/will drive you nuts!
Its a nice glass jar though :-)
ctrout is offline Find More Posts by ctrout
Old Sep 05, 2012, 02:29 PM
Baltimore MD USA
Joined Jan 2011
OH yea what he said if you keep it VERY CLEAN AFTER EACH USE you should have less trouble I use mine for the small parts mostly and use rattle cans for the primer and my small auto touch up gun for big areas but it will work for painting a 1/8 scale model just be slow and take your time.
Bruce
Old Sep 05, 2012, 03:08 PM
Toast is offline
Find More Posts by Toast
Closed Account
Joined Jun 2003
Yep, like many of us you will learn to love and hate your airbrush. I would not run primer through it as it will clog easily. You should be able to get high build automotive primer from your local paint shop in a spray can. Far cheaper and easier and cleaner.
Toast is offline Find More Posts by Toast
Old Sep 05, 2012, 03:28 PM
motrio is offline
Find More Posts by motrio
Jersey, St Peter
Joined Feb 2012
Keep it going Bruce.All moved in to the new home,building board all set up,Mrs still pissed offMossie on the go.Fuse first.[ATTACH][ATTACH]Name: 006.jpg
Description: Front of fuse R/h.(Beware on the Traplet plan,F10 is cut 1/8,plan uses 1/4 so you might have to make your own.)[/ATTACH][/ATTACH]
motrio is offline Find More Posts by motrio
Old Sep 05, 2012, 08:20 PM
Baltimore MD USA
Joined Jan 2011
Motrio ... glad to see your back at it and she's looking good.
Well I glued the firewall back in this side the left I put in at 0 degrees the right side will get 3degrees this is how Ziroli does his tail draggers, after gluing it in I reinforced it and cut away the extra bits then cleaned it up so it didn't look like a after thought.
Then I installed the throttle servo I went with the KISS method have a look I need a break!!
Bruce
Old Sep 05, 2012, 09:04 PM
Toast is offline
Closed Account
Joined Jun 2003
Yep, that'll do it! Nice one.
Old Sep 06, 2012, 02:20 PM
Baltimore MD USA
Joined Jan 2011
Thanks toast...I moved on today to the fuel tank and filler,
I didn't want to mount the filler in the cowl so I put it where it really goes on the full scale plane, there are four fuel fill spots on the wings two will be real on this model.
At first I tried to hing the cover and that's just not going to work very well so I made it removable w/ a screw I'm going to make new ones though because the first one I sanded down trying to make the hing work and I'm also going to get a hex drive screw that counter sinks.
There will be a hatch on the under side of the wing where the filler is and there will be the servo for the flaps at this same place, this is not scale but it has to be done.
The fuel tank cradle was fairly straight forward and simple and it's easy to remove for repair or if you should need to get to the throttle servo.
The fuel tank is turned around to make it a shorter distance to the filler the line to the carb will come from the filler,and the tank has an angle toward the klunk.
so check out the progress.
Bruce
Old Sep 06, 2012, 02:26 PM
motrio is offline
Jersey, St Peter
Joined Feb 2012
I love the little touch with the fuel filler!Impressed!Sorry back to popcorn.lol.
Old Sep 06, 2012, 02:38 PM
motrio is offline
Jersey, St Peter
Joined Feb 2012
Been looking through the build threads that you,PeterF and Rob have submitted,Im just going through the throws of building the first half of the fuse.Noticed you and Peter reinforced the front and wing area with extra stringers.Great idea.Looked at Robs thread and saw what happened when he dropped it.Keep up the good work!
Old Sep 06, 2012, 03:48 PM
motrio is offline
Jersey, St Peter
Joined Feb 2012
Progress today.Half fuse ready for sanding then planking!Name: 001.jpg
Description: Used extra stringers on the front end.1/4x1/4.Used3/16 to continue the floor.Sliced 2 lengths of 1/4 and ran it from nose to tail.Should be nice and strong!
Description: Ass end
Description: Full length stringer running through the top.
Description: Dodgy bit on former 10.Traplet laser kit supplies 2x1/8 F10 formers.Plan shows 1/4.You will need to make your own.
Old Sep 06, 2012, 04:05 PM
Toast is offline
Closed Account
Joined Jun 2003
Bruce, nice work on the fillers! Must remember that trick...
Have you modded the tanks so the clunk is still at the back of the tank? This is very important as if the clunk is at the front it means an almost certain engine failure towards the end of the flight on a climbout - usually on a go around. about the worst possible place
Old Sep 06, 2012, 04:11 PM
Baltimore MD USA
Joined Jan 2011
Motrio ...it's looking really good looks like you got some really nice laser cut parts this time, I can see why the missis is not happy w/ you your in her kitchen!
BRAVE MAN yea if you think it needs reinforceing do it any place where the wing meets the fuse.
Your doing it in two pieces like I did? (RIGHT)
are you going to glue the second side straight to the first side?
joneswag has done that and I would if I had to do it over trying to line up the two haves is a real pain in the and should be avoided!!
God luck looking forward to some more progress shots.
Bruce
Old Sep 06, 2012, 08:48 PM
joneswag is offline
Joined Apr 2012
Need some help again please. Have started to have a go at building the tail wheel assembly, but cant work out how area 1 - 1A are supposed to work , Also the wire path is difficult to follow in this area. Finally area 2 is the wire recessed into the balsa?3 and 4 are the parts I have made so far,
Re painting, I have decided that I will use " rattle cans " as you call them for the undercoat and leave the decission on the final coats till later. We in Australia just call them "spray paint cans" prefer your term for them
Sold For the Scale Builder: A Set of Brian Taylor Plans Vultee BT-13 W/Cowl & Canopy stevster Aircraft - Fuel - Airplanes (FS/W) 1 Apr 07, 2011 02:27 PM
Question Contact for Brian Taylor Plans pgleesonuk The Builders Workshop 4 Sep 13, 2006 09:48 AM
Brian Taylor Mosquito plans CraigO Scale Kit/Scratch Built 11 Nov 05, 2003 04:43 PM
Brian Taylor Mosquito FB Vl electrified TasMike Scale Kit/Scratch Built 0 Nov 05, 2003 05:32 AM
FS: 69" P-51 Brian Taylor plans and Parts Ken Lapointe Aircraft - Electric - Airplanes (FS/W) 1 Feb 05, 2003 06:57 PM
